Old 08-09-2015, 01:44 AM   #225
Ro_Ja
Drives: TOYOTA
Originally Posted by Kostamojen View Post
A good example was a large bump (wasn't there before) in the middle of a corner. When the car hit it, it didn't get airborne or get upset, the weight just shifted. I was able to counter it with a slight lift of the gas and turn of the wheel and the car just stayed in the lane and kept going
Interesting. A few of the roads I drive have some nasty dips and bumps that, to me, really seem to unsettle the car (it feels like I lose traction, but I'm not entirely sure, but really makes me feel unconfident in the car) and make it feel slightly unpredictable whereas the stock suspension seemed to have no difficulty handling it. My alignment is setup to be pretty much on-par for a good street/light track setup, so I wonder if it's the bumps/dips (angle of attack, size, etc.), my tires (PSS), suspension, my inexperience with the car/RWD (I come from years of driving FWD on the same roads), or a combination of these things.
Ro_Ja is offline
Old 11-11-2015, 02:19 AM   #226
nimble
nimble's Avatar
Drives: 2013 WO FR-S
@Kostamojen What are your wheel and tire specs?
nimble is offline
Old 04-17-2016, 03:32 PM   #227
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Getting popping noise when moving slowly on these. Nothing hitting, both front and rear are right in the middle of recommended range, everything else suspension wise is stock except OEM camber bolts in front. Mounting nuts are tight. Sounds like it's coming from front passenger side. Have tried uninstalling and reinstalling a couple times. What's going on?
xxBrun0xx is offline
The Following User Says Thank You to xxBrun0xx For This Useful Post:
kevaughan (04-16-2024)
Old 04-17-2016, 03:49 PM   #228
mpross
mpross's Avatar
Drives: 2015 Scion FRS
Popping or knock/rattle? Front or rear?
Sent from my SAMSUNG-SM-G928A using Tapatalk
mpross is offline
Old 04-17-2016, 09:24 PM   #229
xxBrun0xx
xxBrun0xx's Avatar
Definitely popping. Both front and rear. Only happens at low speeds (<10 mph) and seems to happen over small bumps, bigger bumps don't cause popping.
Have been under the car +10 times trying to fix this. Everything is torqued to spec, have tried disconnecting sway bars and doesn't go away. Sounds like popcorn being popped slowly. I tried to take a video, but didn't turn out well.
Old 04-17-2016, 09:28 PM   #230
mpross
mpross's Avatar
Well my friend it appears we're in the same boat except mine clunks instead of pops... Are yours pillow ball front and rear?
mpross is offline
The Following User Says Thank You to mpross For This Useful Post:
Old 04-17-2016, 09:45 PM   #231
xxBrun0xx
xxBrun0xx's Avatar
Stock top hats, stock end links, stock sway bars, stock everything except front camber bolts. My popping sound seems to happen on small bumps only and almost sounds like it happens on rebound rather than compression, but hard to tell. When I first got these, I set them WAY lower than Bilstein recommends (didn't realize there was a recommended range of adjustment, first coilovers, thought the whole threaded body was fair game, oops!). I drove on them for about a week before I realized they rode like shit and made the same popping noise I'm getting now. Readjusted to 120 mm front/155 mm rear and still getting the same noise :S
Old 04-17-2016, 09:56 PM   #232
mpross
mpross's Avatar
So how much lower than stock are you now? I'm thinking my issue is the rear end links (mostly. I do get some pops along with clunks). The front end links can hit the control arm if you're fairly low and the rear end links get preloaded and bound up if you go too low and still use the stock ones. I've got white line end links in the mail as we speak to try and remedy the sound. That may be your issue
mpross is offline
Old 04-17-2016, 10:03 PM   #233
xxBrun0xx
xxBrun0xx's Avatar
Unfortunately, I'm as high as Bilstein recommends. I've got slightly less than 2 finger wheel gap in front and slightly more than 2 in back. No idea how that compares to stock, but it's 120 mm from center of top strut bolt to collar in front, 155 mm from center of strut bolt to top collar in back. Do I need an adjustable sway bar or end links? Nothing seems to be hitting, nor does this sound like anything hitting anything else :S Think I'm going to give Bilstein a call tomorrow and see what I need to do to get them revalved.
Old 04-17-2016, 10:17 PM   #234
mpross
mpross's Avatar
Hmm, I wouldn't think so because that's not that low. If it's not end links, torque specs, top nuts, or incorrect preload that's pretty much every possibility I've read about on here :/ coilovers are kind of a PAI I'm realizing lol
mpross is offline
Old 04-17-2016, 10:50 PM   #235
Kostamojen
I had to use adjustable front endlinks with mine to prevent the swaybar from hitting, thats my first guess.
Kostamojen is offline
The Following User Says Thank You to Kostamojen For This Useful Post:
Old 04-18-2016, 07:01 AM   #236
xxBrun0xx
xxBrun0xx's Avatar
With the front end jacked up and both wheels off, I've used a jack to fully compress each side one at a time and can't see any contact anywhere. From the reading I've done, seems like lots of people go back to OEM end links because the aftermarket ones tend to hit the front control arms (although this doesn't make much sense to me). It's definitely not clunking and ride is not bouncy at all, so guessing they aren't blown.
Not sure if this helps, but seems to happen after I make turns at low speeds, they start popping like mad and keep popping for a short time after straightening the car out. Can feel it in the steering wheel. It's not particularly loud, but you can definitely feel it.
Have tried to tighten the strut nuts, but the passenger side allen key is stripped pretty bad. Can't go in or out with it and my impact gun does nothing :S
Old 04-18-2016, 10:51 AM   #237
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
That might be your issue. I've had three suspension noises: camber plate rubbing on itself, sway bar endlinks, and loose top nut on the struts.
I figured out the loose top nut by jacking the car up, taking off the wheel, grabbing the strut and lifting it up and down and boom there's the noise.
You may have screwed yourself by the allowing the damper to strip. There might be ways to fix it, sending back to Bilstein might be an option. I don't like using the impact on the struts, always used a pass through wrench and torqued by hand, with the exception of the one shop that's worked on them, I know they used an impact.
Edit the curse of posting your problem in two places, confusion.
In any case jacking the car up and shaking stuff by hand, a good hearty pull like you're trying to pull the car off the jack stands, has so far been my must effective diagnostic tool, once I get my rear sway bar end link shins for my aftermarket LCA my Bilstein setup will be quiet, and it's almost as frankensteined as Kosts.
ineedyourdiddly
strat61caster is offline
Old 05-10-2016, 02:37 PM   #238
SG02WRX
SG02WRX's Avatar
Drives: SWP WRX HATCHBACK
Any one have any suggestion for front camber plates, besides Raceseng. Although the Raceseng plates are nice. They're quiet pricey.
Thanks in advance
SG02WRX is offline
Bilstein Damptronic pics. DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 202 10-08-2014 08:13 PM
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 11:26 AM
Bilstein Damptronic on an FRS DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-10-2013 12:15 AM
All Bilstein and Muteki 10% off during month of July! Infamous Performance Brakes, Suspension, Chassis 24 07-31-2013 01:52 PM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
