Old 02-10-2016, 10:22 PM   #281
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Originally Posted by kevinchavarria View Post
Interesting. I want to take my FRS since my driver side windows was squeezing and scratching, they said they couldn't since it wasn't under warranty.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Ah, that isn't a recall level problem, so I can see why they would refuse to do the work if you are out of warranty. Usually when there is a safety recall, the work can be done regardless of warranty status. The TSB is merely Toyota's instructions for how to fix the specific issue, not a command to fix every car with that issue. I know that isn't what you wanted to hear, I'm sorry...
aegisdrgn is offline   Reply With Quote
The Following 4 Users Say Thank You to aegisdrgn For This Useful Post:
Dadhawk (02-11-2016), HotLeopardMama (02-26-2016), Sigh-on-Rice (02-11-2016), Tcoat (02-11-2016)
Old 02-11-2016, 02:15 PM   #282
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Originally Posted by FRSBRZGT86FAN View Post
@Sigh-on-Rice
This is info and pdf on the Recall effecting 2013-2016 involving the ignition interlock, interesting enough it was a simple plug under the dash everyone can check, mine was disconnected and I noticed it in the summer not realizing what it went to
Thank you. I just added it to the original post.
The Following 2 Users Say Thank You to Sigh-on-Rice For This Useful Post:
FRSBRZGT86FAN (03-04-2016), Ultramaroon (02-11-2016)
Old 02-11-2016, 02:28 PM   #283
Are TSB'S only done during the warranty?
Yep^
TSB stands for "Technical Service Bulletin" and it is simply the instructions to the Techs on how to fix the problem.
It should not be confused with a Recall which means they have to fix the problem.
Old 02-11-2016, 03:19 PM   #284
Yep^
Exactly, and if you need proof look at my "weeping" tail light that was not fixed per the TSB because it started less than 200 miles after the warranty period.
Old 02-15-2016, 03:41 PM   #285
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
Originally Posted by Sigh-on-Rice View Post
FR-S TSB
S-SB-0009-12 : DRL Customization
S-SB-0019-12 : Dash Mounted Speaker Grille Appearance
S-SB-0023-12 : Chirping Noise from High Pressure Fuel Pump
S-SB-0023-12-Rev2 : Chirping Noise from High Pressure Fuel Pump
S-SB-0002-13 : Condensation in Rear Combination Lamp
S-SB-0014-13 : Rattle Noise From MT Shift Lever
S-SB-0033-13 : Hard Start, Rough Idle, Camshaft Sensor or Misfire DTCs
S-SB-0040-13 : Intermittent RPM Drop
S-SB-0041-13 : Taillight Lens Cracking
S-SB-0001-14 : Window Freezing, Losing Initialization
S-SB-0009-14 : Outside Door Weatherstrip
S-SB-0021-15 : Idle Fluctuation in Park or Neutral
S-TT-0043-12 (Not a TSB): Body panels that aren’t flush. LINK to DIY.
BRZ TSB
15-158-12 : Navigation/GPS Antenna Changes
12-131-12 : Condensation in Rear Combination Lamp
09-54-12 : Chirping Noise from High Pressure Fuel Pump
09-54-12R : Chirping Noise from High Pressure Fuel Pump (Revised on 5/9/2013)
09-54-12R2 : Chirping Noise from High Pressure Fuel Pump (Revised on 10/28/2013)
02-132-12 : DTCs Relating to the AVCS (Active Valve Control System)
12-140-12 : Popping Sound from Trunk / Rear Shelf Area
11-130-13R : Difficulty Starting, Rough Idle, Cam Position, Misfire
11-136-14 : Idle Stability
07-79-13R : Frozen Power Windows
02-136-12R : Oil Seepage Diagnosis and Repair Procedures
FR-S Recall
Recall_G0E : Ignition Key Interlock System
BRZ Recall
WQC-39 : ECM Reprogramming for Coolant Thermostat
Other Information
01-168-09R : Replacement Key and Immobilizer Information
07-68-12 : Alternate Procedure for Removal of Front Side Marker Lamp
Passenger window auto up/down switch
P0351-P0354_ Ignition Coil _A_ Primary _ Secondary Circuit
This is a big help! Thanks OP! I noticed nasty vertical scratches on both side windows. ... The dealer has to replace a bunch of parts. This reminded me to inspect my car before the warranty goes out later this year.
Fenix is offline   Reply With Quote
The Following User Says Thank You to Fenix For This Useful Post:
Old 04-15-2016, 04:13 AM   #286
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Hey again
I just wanted to add this one
FOR SUBARU BR-Zs:
It is TSB #16-96-15
TCM Reprogramming File Availability for Engine Idle RPM Fluctuation on 6AT- Equipped Models
This bulletin announces availability of reprogramming files for optimizing the Transmission Control Module (TCM) on all 2015 and some early-production 2016MY vehicles to control an engine idle speed fluctuation condition when in Park or Neutral. The cause is incorrect operation of a back-up program the TCM uses in the event of a turbine speed sensor problem. Affected vehicles may see a fluctuation of approximately 200 rpm (between 600 – 800 rpm idle speed).
I don't have the proper documentation pdf for this one as I don't have access to the Subaru equivalent of techstream, but the issues this fix are the same as 2015-2016 owners were experiencing including myself here:
http://www.ft86club.com/forums/showthread.php?t=96615
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
Sigh-on-Rice (04-15-2016), treminaor (06-03-2016)
Old 04-15-2016, 03:17 PM   #287
Sigh-on-Rice
Hey again
FOR SUBARU BR-Zs:
It is TSB #16-96-15
Thanks. I just updated the 1st post to add 16-96-15 linking to your post for now. I'll update the link to PDF when we get one.
Old 05-16-2016, 07:56 AM   #288
Southeast Toyota/Scion Recall of some 2016 FR-S
Another minor recall.
The Capacity Modification Label is incorrect in some models, including the FR-S manufactured 1/28/2016 to 3/14/2016.
Details here.
Now don't be overloading those vehicles!
SUMMARY:
Southeast Toyota Distributors, LLC (SET) is recalling certain model year 2016 Toyota Yaris, Rav4, Land Cruiser and 4Runner vehicles, and Scion FR-S, iM, and TC vehicles manufactured January 28, 2016, to March 14, 2016. The Load Carrying Capacity Modification Label may not reflect the correct added weight of the installed accessories. As a result, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard number 110, "Tire Selection and Rims for Passenger Cars."
FRSBRZGT86FAN (06-03-2016)
Old 05-16-2016, 05:14 PM   #289
Sigh-on-Rice
Details here.
SUMMARY:
Thanks. I added it to the first post.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
Dadhawk (05-17-2016)
Old 06-01-2016, 11:55 PM   #290
FX86
my stealership never called me back about the ignition key recall after i contacted them several times..so i gave up trying to get them to look at it especially after i tried to remove the key in another gear than Park and it seems to work as intended
Old 06-02-2016, 01:52 AM   #291
Astral Abyss
Drives: 2016 Halo FR-S
I finally thought to look at this thread and was so happy to see:
This is the problem I've just been silently dealing with for almost a year. Armed with this TSB and a video I made of the problem, I'm getting this taken care of... FINALLY!
Astral Abyss is offline   Reply With Quote
The Following User Says Thank You to Astral Abyss For This Useful Post:
chaoskaze (06-03-2016)
Old 06-03-2016, 01:15 AM   #292
Lastexile
Lastexile's Avatar
Drives: 2013 Firestorm FR-S
So with all of those problems listed can I take my FRS to my Toyota dealer to get them fixed? I just bought a 2013 FRS.
Lastexile is offline   Reply With Quote
Old 06-03-2016, 07:37 AM   #293
Since none of these are really safety recalls (well there are a couple but they are minor, a sticker on the car and one that applies to AT cars if you can pull the key out while in a gear other than park) it would have to be under warranty, and showing the problems.
A car purchased used can still be under warranty. A 2013 is very unlikely to still be under the 36 month/36K bumper to bumper warranty, although I suppose its possible if it were purchased late in the 2016 model year (the 2013 first went on sale in 05/2012). The powertrain warranty (60/60) may still be in place, and would cover a few of them.
If you aren't the original owner and have no proof of when it was originally purchased the dealership will use the VIN to determine the start of warranty, which will be the day it was originally sold.
One I would consider getting done is the fuel pump one, but I would put it off until near the end of the warranty period. Not so much because it's a real mechanical issue but because it ends up giving you a new fuel pump.
Old 06-03-2016, 02:27 PM   #294
FRSBRZGT86FAN
Bear in mind this is for the auto only
chirping, high pressure fuel pump
Recall I think so!!!! RWD-boxer Issues | Warranty | Recalls / TSB 16 10-07-2012 10:39 AM
FRS recall? totally Issues | Warranty | Recalls / TSB 8 08-30-2012 12:01 AM
Recall! already earthsscum BRZ First-Gen (2012+) — General Topics 1 06-07-2012 07:00 PM
Owners Manual Recall Opie BRZ First-Gen (2012+) — General Topics 8 06-05-2012 10:09 PM
Did anyone get a call from toyota about a recall yet? AustinTCLN Scion FR-S / Toyota 86 GT86 General Forum 2 06-04-2012 11:45 PM
