Old 04-10-2016, 06:32 AM   #7001
Dream20b
Y u do dis?
Originally Posted by sam69 View Post
So had this happened before the 335 went on or has it only just gone pear shaped since fitting ?
I think I flooded it trying to start it and then either bent a rod or valve.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 04-10-2016, 07:48 AM   #7002
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Has this happened with other motors before? Could the starter even crank hard enough?
This is a dire circumstance. If a flooded motor means bent rods then we're all screwed.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 04-10-2016, 05:47 PM   #7003
Dream20b
Y u do dis?
It was losing fuel pressure immediately after starting, i'm told, causing these issues.
Dat Hot Lava Doe
Old 04-10-2016, 09:28 PM   #7004
riboyster
riboyster's Avatar
Running too lean, you mean?
While on the topic, anyone else have a much harder time cranking on hot starts?
Old 04-10-2016, 10:11 PM   #7005
sam69
Drives: GT 86
Hot or cold starts makes no difference with mine starts easy as .
sam69 is offline   Reply With Quote
Old 04-11-2016, 01:25 AM   #7006
riboyster
riboyster's Avatar
Must be my battery...
Old 04-11-2016, 10:04 PM   #7007
SlowShifter
Drives: Toyota 86 with supercharger
Originally Posted by calispec View Post
Right now I am working through the issue with my tuner. I want to say its something mechanical because it started out of nowhere.. but everything I can come up with points back to a tuning issue.. I will keep you posted with what I find. If this lasts for a year I will go insane and end up replacing everything. I hate it when I can't figure out what is wrong.
Just an update, put in a K&N air filter and the problem still exists. But it did seem to improve overall performance a little bit, but could be placebo! Think I may change out the fuel filter next.
SlowShifter is offline   Reply With Quote
Old 04-11-2016, 11:03 PM   #7008
riboyster
riboyster's Avatar
What's the smallest pulley you guys have run without intercooler? Thinking about upgrading while I save for IC and monitoring knock
Old 04-12-2016, 07:31 PM   #7009
quiksiv
quiksiv's Avatar
Drives: 2013 FRS
I just bought a Sprintex, with intercooler.
I was curious what do i need to get started?
oil catch can?
injectors?
oil cooler?
quiksiv is offline   Reply With Quote
Old 04-12-2016, 07:38 PM   #7010
sam69
Drives: GT 86
oil catch can?
injectors?
oil cooler?
Catch can on rear crankcase vent is not a bad thing but I don't have one as yet.
Stock injectors and pump are fine for pump gas.
Oil cooler with thermostat is very worthwhile imo .
Old 04-12-2016, 07:56 PM   #7011
quiksiv
quiksiv's Avatar
Drives: 2013 FRS
Brand recommendations?
Old 04-13-2016, 07:35 AM   #7012
Harro
Drives: 2014 Toyota 86
I run a mishimoto oil cooler with thermostat, works incredibly well in Queenslands hot 35 degree C Summers. If it's cooler where you're at maybe something with a smaller radiator would help.
Harro is offline   Reply With Quote
Old 04-13-2016, 10:29 AM   #7013
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
My install is on the 26th and I'm trying to remember something I read in this thread about when adding boost to our cars, clamps need to be added to specific hoses that will eventually come loose and disconnect causing loss of power as there are no clamps from factory, due to not being boosted initially. Does anyone know what this would be specifically that I can tell my mechanic?
Chad86 is offline   Reply With Quote
Old 04-13-2016, 02:35 PM   #7014
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Originally Posted by Chad86 View Post
My install is on the 24th and I'm trying to remember something I read in this thread about when adding boost to our cars, clamps need to be added to specific hoses that will eventually come loose and disconnect causing loss of power as there are no clamps from factory, due to not being boosted initially. Does anyone know what this would be specifically that I can tell my mechanic?
This is an issue on turbo cars. Particularly the evap solenoid line under the intake manifold.. The sprintex manifold replaces your OEM intake manifold, and relocates the problematic lines, thus eliminating that problem.
In other words, no, don't worry about it.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
Chad86 (04-13-2016), chaoskaze (03-07-2020)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
