Old 04-12-2016, 12:42 PM   #29
Kerune
Kerune's Avatar
Drives: Lexus RC-F
Look, we can bring skipping 4th gear back. That I will tell you, we're bringing it back okay? I understand what you're saying, and I get that from so many people. "Is it okay to skip gears?" They are asking me the question, "is it okay to skip gears?" And the transmission is in trouble. Okay? It's in trouble. But we're going to use every gear and do some real shifting too.
Kerune is offline   Reply With Quote
The Following User Says Thank You to Kerune For This Useful Post:
h8meh8ers (04-12-2016)
Old 04-12-2016, 12:57 PM   #30
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
lmao.
No such thing as skipping gears. If you are going a certain speed at a certain RPM, there is a correct gear for that situation. C'mon now guys.
I would love to see you guys try to quickly stop the car from 100MPH and hit every gear on the way down then calmly go to neutral at the end.
#sequentialswap #yolo
GeorgeJFrick is offline   Reply With Quote
The Following User Says Thank You to GeorgeJFrick For This Useful Post:
MisterSheep (04-12-2016)
Old 04-12-2016, 01:17 PM   #31
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
7th
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
Tcoat (04-12-2016)
Old 04-12-2016, 01:47 PM   #32
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I do 6th to 4th if I'm going from the highway to a fun offramp, and 4th to 6th if I'm going from a fun onramp to the highway.
JazzleSAURUS is offline   Reply With Quote
Old 04-12-2016, 02:03 PM   #33
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
I don't skip gears, I run through them like if they were running out of style
fumanchu1 is offline   Reply With Quote
Old 04-12-2016, 02:17 PM   #34
Koa
#allgearsmatter
The Following 3 Users Say Thank You to Koa For This Useful Post:
MisterSheep (04-12-2016), STV3 (04-12-2016), Tectoniic (04-12-2016)
Old 04-12-2016, 02:19 PM   #35
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Skipping gears won't kill your transmission but it does increase wear on the syncros in certain circumstances. In particular, because 1st and 3rd and 2nd and 4th share syncros, you should avoid skipping those gears. Additional wear on the syncro happens on these shifts because the syncro it will still be spinning too fast for the next gear when you are trying to go into it. Obviously, this can be avoided by sitting in neutral long enough for the syncro to spin down before you try going into the next gear but that kind of defeats the purpose. If you try to go straight from 1st to 3rd or 2nd to 4th right away, you'll feel resistance as the syncro spins down until it's slow enough to pop into gear. As you feel that resistance, you are pushing against the spinning syncro causing additional wear.
Will it kill your transmission? Not right away but it should be avoided if you can help it. I will note that I'll sometimes skip 2nd when the car is very cold to avoid grinding but I wait plenty of time before pushing it into 3rd.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
Tcoat (04-12-2016)
Old 04-12-2016, 02:25 PM   #36
STV3
Seρor Member
STV3's Avatar
STV3 is offline   Reply With Quote
The Following 4 Users Say Thank You to STV3 For This Useful Post:
Bowen (04-12-2016), Koa (04-13-2016), Tcoat (04-12-2016), Thorpedo (04-12-2016)
Old 04-12-2016, 02:37 PM   #37
ARTBRZ
Aloha!
ARTBRZ's Avatar
Skip from 1 to 6 all day all day.
Just kidding. I love going through my gears. I have skipped some gears in the past but I've tried not to because sometimes I hear a loud clunk when I don't use the clutch properly.
ARTBRZ is offline   Reply With Quote
The Following User Says Thank You to ARTBRZ For This Useful Post:
Tcoat (04-12-2016)
Old 04-12-2016, 02:55 PM   #38
Kerune
Kerune's Avatar
Drives: Lexus RC-F
Originally Posted by STV3 View Post
Lol if anyone missed it, it's Donald Trump.
Old 04-12-2016, 03:45 PM   #39
mazeroni
Drives: 2013 Scion FR-S Series 10
On downshifts, I think I ignore 4th a lot. It is usually 6 > 3 or 5 > 3.
On up-shifts, not enough torque. I feel like you must use every gear to keep acceleration linear. If I did a 4 to 6, I would feel like the engine just died. Going to 5th first prepares me for the disappointment of lugging around in 6th.
With my GTI I always skipped 5th because there was a 200-ish rmp difference between 5th and 6th. In the frs all the gears feel useful to me.
mazeroni is offline   Reply With Quote
Old 04-12-2016, 05:35 PM   #40
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
LOL now I get it! Sorry for the delay
Bowen is offline   Reply With Quote
Old 04-12-2016, 08:33 PM   #41
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
Yea i rarely skip gears with the occasional miss shift. Only time I would ever skip gears is when im feeling rev happy and suddenly see a cop, in which im 3rd =>6 lol
ig:Vinshiin
Vincenttam is offline   Reply With Quote
Old 04-12-2016, 08:37 PM   #42
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
2nd
Auto gear slippage on 2nd n 3rd gear shantha Scion FR-S / Toyota 86 GT86 General Forum 2 11-19-2015 08:26 PM
Skip the dealer and do your own 15K maintenance for $55.87! YourFearlessLeader Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 38 11-20-2013 11:54 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 09:39 PM
Buying a new FRS / BRZ-skip the dealer wash! 911fanatic Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 19 09-02-2012 12:00 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
