Old 04-05-2016, 04:57 PM   #57
empower-auto
Kouki-Monster
empower-auto's Avatar
Originally Posted by nickw14 View Post
What do you mean how? 12.5:1 compression, moderate boost, and a good tune is how. Considering people regularly see ~300 on 9psi, 350 on 11 isn't unreasonable.
It's absolutely insane. I make 260 on 9 and my tune is not shit, nor is the hardware. 94 octane
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 04-05-2016, 10:04 PM   #58
BRZFRSSTORE
Drives: 2013 brz
Originally Posted by texasbound972 View Post
I'm on my 2nd built block, I feel your pain bro. Best of luck!!
Sent from my SAMSUNG-SM-N920A using Tapatalk
second built block, that not good
BRZFRSSTORE is offline   Reply With Quote
Old 04-06-2016, 09:56 AM   #59
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This was on 93, no "playing myself" here. But, does it really matter? The engine blew up anyway. Next stop: 500+ on pump. Tell me it won't happen, and I'll be glad to post the dyno sheet when it's done in a month or so
I have no doubt it can be done. Just be sure to post when you blow your motor again
texasbound972 (04-07-2016)
Old 04-12-2016, 08:42 AM   #60
nickw14
Drives: Built FA20
Lol ok, I will be sure to do that...
I would urge you to do some research on Accelerated Performance and their BRZ. My information is coming directly from the builder of their kits and of their 700+whp 1/4 mile car. In fact, the kit that is on my car is directly off of their BRZ with the exception of a few newer parts including the turbo. Don made 550whp on pump gas at ~22-24psi, which the new engine will be able to handle no problem.
nickw14 is offline   Reply With Quote
The Following User Says Thank You to nickw14 For This Useful Post:
p1l0t (04-12-2016)
Old 04-12-2016, 08:47 AM   #61
nickw14
Drives: Built FA20
I made 290 on 9psi spike and holding 8psi. 91 octane tune running 93.
Old 04-12-2016, 09:51 AM   #62
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I am well aware of Accelerated Performance and their initial work with Visconti. Good luck.
Fred E (04-12-2016)
Old 04-13-2016, 07:22 PM   #63
mad_sb
Drives: 2013 Asphalt FR-S
TLDR:
Spiked 20psi on the dyno a week and a half ago, PROBABLY bent a rod then. Just this past weekend the engine decided to give out during a top of 5th gear pull. Sucks.
Those boost spikes I did the same thing on my Evo 10 when I first put the upgraded turbo on it (we were doing development work with Blouch). I Had it all tuned nice and pretty on the dyno but I had not fully dialed in the EBC. Laid into it in 4th gear at low rpm on the interstate, boost spiked to 27 - 28psi before i got out of it. 1 week latter it let go on the dyno at the rev limiter. Turns out the spike had cracked a piston, it took the week and a few dyno pulls to work a chunk loose that took out a valve.
Sorry for your loss man.
Old 04-13-2016, 07:29 PM   #64
mad_sb
... Visconti...
Lol, thats enough to get you banned on EvoM, at least it was when he got chased off the forum a few years ago.
The Following User Says Thank You to mad_sb For This Useful Post:
nickw14 (04-14-2016)
Old 04-13-2016, 08:33 PM   #65
DrWill
DrWill's Avatar
Drives: whiteout FR-S
A similar situation happened with a friend of mines car. While tuning the boost controller failed and caused a spike and the failsafes set in ecutek didn't kick in and a rod bent. Seemed obvious in that case that it was a software glitch in ecutek that set the entire situation off as the boost controller was being controlled by the ECU. Luckily another friend of ours had his motor in the shop getting built with forged internals so he agreed to give his stocks to our friend and our tuner didn't charge any labor for the rebuild sense it happened while he was tuning it so my friend was able to get his motor back in for the cost of the gaskets which were wholesale sense at the time my wife was working at toyota. So we were all able to band together and turn a fucked situation into something that sucked a lot less.
DrWill is offline   Reply With Quote
The Following User Says Thank You to DrWill For This Useful Post:
SoCal80six (04-13-2016)
Old 04-14-2016, 11:38 AM   #66
nickw14
Drives: Built FA20
John and I do not get along on a personality level, due to his customer service views. Other than that, he is a very good tuner. Don trusts him a lot, and that's enough for me. I've never had a tuning related issue, only customer service related issues.
Another One Bites the dust jph11 BRZ First-Gen (2012+) — General Topics 19 02-23-2016 06:30 PM
Another one bites the dust joergasm CANADA 2 06-24-2014 11:44 AM
And another one bites the dust.... Rinn310 Scion FR-S / Toyota 86 GT86 General Forum 58 05-20-2014 11:04 AM
Another car bites the dust? RaceR Other Vehicles & General Automotive Discussions 10 12-17-2012 12:20 PM
Another One Bites the Dust kanundrum Scion FR-S / Toyota 86 GT86 General Forum 68 08-17-2012 02:30 AM
