Old 04-08-2016, 07:36 PM   #15
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Originally Posted by EssJay View Post
Could I achieve -2/similar rear camber w/out these bushings?
You don't need the rear bushings or lower control arms with the RCE yellows or TRD springs.
Get the springs and camber bolts for the front. Have the person doing the alignment dial in as much camber as they can up front with the bolts, 0 out the toe front and rear, and enjoy your car!
asdf is offline   Reply With Quote
The Following 2 Users Say Thank You to asdf For This Useful Post:
EssJay (04-11-2016), Tcoat (04-11-2016)
Old 04-09-2016, 04:13 AM   #16
ed_423
ed_423's Avatar
Drives: 2016 BRZ Limited
anyone running RCE springs or STI springs, and set the camber to stock settings instead of going more negative? i don't want too much camber and i feel like with such a modest drop, the stock camber setting should be fine?
ed_423 is offline   Reply With Quote
Old 04-11-2016, 01:46 PM   #17
EssJay
Drives: '16 FR-S Halo White
Originally Posted by Gunman View Post
My Hotchkis 1" springs gave me -2deg camber in the rear with no other adjustment.
Some say I need rear control arms/bushings for neg. camber, some say it happens on its own. I guess I'll have to live dangerously and chance it..
EssJay is offline   Reply With Quote
Old 04-11-2016, 03:18 PM   #18
asdf
asdf's Avatar
Drives: #0517
you'll gain some camber in the rear with a drop using all oem parts (minus the springs) but you will not be able to adjust it.
unless there's something else wrong, you should be OK w/ the resulting figures.
make note though that there are multiple users on here who have reported slightly different amounts of camber for right vs left in the rear. unless you need to have that adjusted to a specific number, you will be fine. have the alignment tech straighten the toe and you should not notice any excessive tire wear for your daily driving/occasional fun drives.
*making the assumption here that anybody who is looking for competition use would not be asking this question and would be making adjustments to their own specified specs.
The Following User Says Thank You to asdf For This Useful Post:
EssJay (04-11-2016)
Old 04-11-2016, 04:03 PM   #19
renfield90
The Stig's German cousin
+1 to this, and I've run the TRD springs. Rear camber was damn near perfect. Unless you have a freak of a car it shouldn't be very different.
On lowering springs for and stock shocks, time for new shocks... Basket Case Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-16-2015 08:31 AM
Really need ADVICE: Buy out LEASE? Or Lease New Car again? PoRco Scion FR-S / Toyota 86 GT86 General Forum 83 09-02-2015 06:15 PM
2013 Hot Lava FRS $23,860 or Lease for $406.80 Per 37 month Lease Employee Canada Classifieds 19 03-18-2014 09:34 PM
2013 FRS Mild STX Build. feldy Tracking / Autocross / HPDE / Drifting 2 01-24-2014 02:29 PM
Tire/Wheel + mild drop help dalli Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-18-2014 11:05 AM
