Old 04-09-2016, 09:34 PM   #351
NahumCC
Drives: 2013 FR-S 10 Series
Originally Posted by zeal86 View Post
Just take a weekend to do the heavy cleaning then focus on the details the following weekend... Once you have that accomplished, wipe it down every 3 weeks to a month to maintain. If you do car shows, you won't be too far off from being show ready... or if you are just showing a friend or relative, you won't get sad... lol
Haha. Oh I do know what needs to be done but 3 boys ages 2 to 9 and a 4th that is about here and has put momma on strict bed rest doesn't leave me time to keep an engine bay clean (not white glove inspection clean like yours).
Maybe one of the nicer spring days when the Ohio and the Midwest gets its act together.
NahumCC is offline   Reply With Quote
Old 04-09-2016, 09:38 PM   #352
zeal86
zeal86's Avatar
Drives:
Put that 9 year old to work! lol Have it professionally done once then keep up with it the best you can.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
Old 04-09-2016, 11:30 PM   #353
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 04-09-2016, 11:31 PM   #354
ottoyu34
ottoyu34's Avatar
Drives: Mazda3
This is gonna be epic, keep it up.
ottoyu34 is offline   Reply With Quote
The Following User Says Thank You to ottoyu34 For This Useful Post:
zeal86 (04-10-2016)
Old 04-10-2016, 12:54 AM   #355
G-awesome
Drives: 2015 Firestorm Scion FRS
That shiny stock overpipe looks aftermarket! 👍
G-awesome is offline   Reply With Quote
The Following User Says Thank You to G-awesome For This Useful Post:
zeal86 (04-10-2016)
Old 04-11-2016, 01:48 AM   #356
zeal86
zeal86's Avatar
Drives:
Changed out my OEMs to HKS today...I'm in the middle of a bunch of installs so I had removed a lot of what was necessary to do the FSM method anyway... so I went with it. Well, kind of... there were a few things I did different but close enough..
Here are some pics from my install...
The Bottle Jack was great for this swap. My 86 is currently on jacks (14" off ground) so I was able to place the bottle jack on the ground... Luckily I hoarded a bad axle from the landing gear of a C550 because I used it to extend the jack while maintaining a solid jacking point.
I was able to torque the plugs and coil packs... the FSM method really made the swap almost frustration free.
Engine lifted on the passenger side...
You could see the work space created with the engine angled in these pics...
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
8R6 (04-13-2016), Koj (11-12-2016)
Old 04-11-2016, 01:57 AM   #357
zeal86
zeal86's Avatar
Drives:
Almost took care of business today... All I have left to do before beginning on the provisions for my supercharger is place my exhaust manifold and torque down my exhaust system.
Had to do this before installing the exhaust manifold... might pick up some more for the over pipe. The pictured sheet came with the HKS exhaust manifold.
8R6 (04-13-2016), Koj (09-06-2016)
Old 04-11-2016, 02:20 AM   #358
Irace86
Drives: BRZ + Ducati M796
@zeal86 is the stock pipe stainless steel? like the other pipes?
Irace86 is offline   Reply With Quote
Old 04-11-2016, 02:42 AM   #359
zeal86
zeal86's Avatar
Drives:
I'm not sure about it being stainless... lol but it is steel.
Old 04-13-2016, 12:54 AM   #360
zeal86
zeal86's Avatar
Drives:
I finished up my exhaust system installation today...I tried to finish yesterday but I was destroyed by mosquitos... lol
I will finally begin the provisions for my HKS supercharger pro kit v3 installation!
I received my Beatrush air intake duct on Monday...I will know soon if I will be able to use it in conjunction with my supercharger. If I am able to, it will more than likely be because I modified it.
This thing is beautiful!
I did not reinstall the factory overpipe heatshield after polishing it... I just layed down some more heat barrier...
The Following 3 Users Say Thank You to zeal86 For This Useful Post:
8R6 (04-13-2016), Bramick (04-13-2016), Koj (09-06-2016)
Old 04-15-2016, 10:19 PM   #361
zeal86
zeal86's Avatar
Drives:
Finished polishing the supercharger bracket... I was back and forth about whether to polish, powder coat, or paint the bracket... glad I polished it...
I'm not done polishing though... I still have some hardware and perhaps even the idler pulley and alternator to do...
8R6 (04-16-2016), Koj (09-06-2016), new2subaru (04-16-2016)
Old 04-16-2016, 09:16 PM   #362
zeal86
zeal86's Avatar
Drives:
I would've gotten more done today but I couldn't stop binging on The Flash... lol I also had a birthday party to go to.... anyway
Here is some polished hardware from my HKS v3 supercharger
Before on the right, after on the left
I started some of the provisions necessary for the HKS v3 supercharger install today...
nicked it a bit... but thats okay because I'm going to polish it anyway. Rounded off all corners.
Sanded down the nick then polished the area to see how it is going to look.
8R6 (04-20-2016), DustinS (04-21-2016), Koj (09-06-2016)
Old 04-16-2016, 09:31 PM   #363
Irace86
Looking good man
The Following User Says Thank You to Irace86 For This Useful Post:
zeal86 (04-18-2016)
Old 04-18-2016, 01:35 AM   #364
zeal86
zeal86's Avatar
Drives:
I completed a few more provisions today... I spent most of the day mocking up, testing, then fabricating brackets. This is necessary in my install because of my Beatrush front beam brace.
I'm pretty far along on two more brackets... I hope to have them completed tomorrow.
I was able to complete this bracket for the traction fluid cooler today. I just have to paint the brackets gloss black and clear coat them.
painted and cleared...
Temp installed...
Drilled an M6 hole...
Ready to be mounted...
Installed...
The Following User Says Thank You to zeal86 For This Useful Post:
Koj (09-06-2016)
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 09:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
