Old 04-06-2016, 06:25 PM   #337
zeal86
zeal86's Avatar
Drives:
Originally Posted by JMoneyFRS View Post
Looking good Zeal! We met yesterday, Justin from the zone....I'll have to check it out in person one day.
It was awesome meeting another enthusiast here in West Texas... Especially another zn6 enthusiast... I was beginning to think I was the only one. lol
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
Old 04-06-2016, 07:04 PM   #338
zeal86
zeal86's Avatar
Drives:
Received notification today that my Beatrush air intake duct has shipped... I'll know soon if I can modify it to work with my HKS v3 supercharger. If not, I'll go with the HKS air intake duct.
I really want this part to work out!
Old 04-06-2016, 10:36 PM   #339
zeal86
zeal86's Avatar
Drives:
Ran into a hiccup yesterday separating my front pipe at the over pipe union... so today I brought the tools I needed from work. Gave it a go today and I was able to break loose one nut on either side of the over pipe. The two that did not cooperate started to come off then got hung up so I sprayed PB Blaster on them... I'll try them again tomorrow.
If it weren't for the hiccups both front pipe and exaust manifold would have been easy swaps.
Old 04-06-2016, 11:22 PM   #340
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
When I did my overpipe and headers, talk about a serious pain in the butt. But with plenty of PB blaster, I was able to get it off. haha
MS, CSCS, TSAC-F, CPT
Old 04-07-2016, 12:55 AM   #341
zeal86
zeal86's Avatar
Drives:
I take it they came off undamaged? Mine should not even be seized... hopefully the studs don't get stripped in the process. Crossing my fingers...
Old 04-07-2016, 10:16 AM   #342
weederr33
weederr33's Avatar
Nothing broke or stripped, it was just a serious PITA. But since I had new hardware with the exhaust, I didn't really care if I would have stripped the nuts.
Old 04-07-2016, 12:33 PM   #343
zeal86
zeal86's Avatar
Drives:
I'm more worried about the stud at the front pipe to over pipe union... it is inserted through the over pipe...I am not replacing that so I do not want to strip the threads.
Old 04-07-2016, 06:38 PM   #344
weederr33
weederr33's Avatar
Oh! I didn't know you weren't doing the over pipe. I guess just be careful. I didn't the studs on mine but it sure felt like I would.
Old 04-07-2016, 09:26 PM   #345
zeal86
zeal86's Avatar
Drives:
Got my front pipe and exaust manifold out today...the PB Blaster did it's job. One stud on the front pipe/over pipe union is a bit damaged but I think I can fix the threads.
The other pain in the a$$ nut stayed stuck and rotated the stud out of the exhaust manifold flange. Next up are the HKS spark plugs... then the installation of the front pipe and exaust manifold followed by prep work for the SC install.
There will probably be some cleaning and polishing during the rest of my installs... lol
Big weekend ahead!
Old 04-08-2016, 11:50 PM   #346
zeal86
zeal86's Avatar
Drives:
So I cleaned up the threads on the damaged stud. I am able to thread the nut all the way down by hand but it gets slightly hung up where the damaged threads were/are. I will try to find a new stainless steel stud this weekend because I would rather replace it.
I have read that others removed the heat shield to shimmy the over pipe out the back... I had success pulling it out the front...granted I have my exhaust manifold out.
So while the over pipe is out, I decided to practice polishing on steel. I am pretty good with aluminum but I haven't worked a whole lot with steel... especially steel in the condition of my over pipe. So far it is coming out pretty good...Depending on how successful I am polishing the over pipe, I might polish the steel supercharger bracket and hardware I was looking to powder coat. I'll post pics tomorrow sometime.
I hope to get my spark plugs in tomorrow... I'm going to follow the service manual instead of getting at them from the top.
Old 04-09-2016, 07:20 PM   #347
zeal86
zeal86's Avatar
Drives:
Spent more time on this then I had planned but oh well... f@#k it, it looks good... I will install it without the heat shield since the exhaust manifold will not have one either.
Before
By the time I took this pic I had begun to smooth out the outer edges of the flanges with a 40 grit Roloc. The edges were alot worse than what is seen in the pic.
Nicked up thread pictured here...I just replaced both studs even though only one was bad.
Half and half pics...
After
Stock over pipe matches all my other exhaust components now!
The Following User Says Thank You to zeal86 For This Useful Post:
Koj (09-06-2016)
Old 04-09-2016, 07:50 PM   #348
NahumCC
Drives: 2013 FR-S 10 Series
Looking good. I'll admit I cried a little when I looked at my engine bay today when my brother asked to see the car. It needs some serious time and attention to get rid of the dusty water spot look.
NahumCC is offline   Reply With Quote
Old 04-09-2016, 08:29 PM   #349
zeal86
zeal86's Avatar
Drives:
Just take a weekend to do the heavy cleaning then focus on the details the following weekend... Once you have that accomplished, wipe it down every 3 weeks to a month to maintain. If you do car shows, you won't be too far off from being show ready... or if you are just showing a friend or relative, you won't get sad... lol
Old 04-09-2016, 08:32 PM   #350
zeal86
zeal86's Avatar
Drives:
I'm definitely going to get to my spark plugs tomorrow... once I get those in, I'll install my exhaust manifold and front pipe. Then it is on to the supercharger install...
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
Irace86 (04-11-2016), new2subaru (04-10-2016)
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 08:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 07:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
