Old 04-04-2016, 08:40 PM   #1
Starkiller
Drives: 2013 Scion FR-S 10 series
Tomei titanium front pipe users??
Hello all.
Last year I purchased a Tomei titanium front pipe, which I installed on my car along with the rest of a mainly custom titanium exhaust.
Since then, I have had nothing but problems with this thing. It started to crack at the welds, and I contacted the seller. He replaced it without hesitation, so that was awesome. After some more time on the car, it started to crack on the welds again. This time, I didn't want to mess with shipping and everything, so I said, screw it.
I went to a local shop that has a great reputation for fab work and had it repaired. Along with fixing the weld, he fabbed a spacer out of resin, for the mounting bracket, to soften some of the vibration.
A month later, it starts to crack on the other weld!! What gives? LOL.
Has anyone else had problems like this? I'd like to know if it is the Tomei pipe, or just my setup is too rigid or something and thats what is causing the problem?
Thanks in advance for the help.
Starkiller is offline   Reply With Quote
Old 04-04-2016, 08:44 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I suspect your custom exhaust is the cause of your problems.
-alex
CSG Mike (04-05-2016)
Old 04-05-2016, 12:18 AM   #3
Starkiller
How so? It uses all stock mounting locations and it is much lighter than stock.
Old 04-05-2016, 02:43 PM   #4
CSG Mike
CSG Mike's Avatar
Sounds like your custom exhaust is putting undue stress on the welds, or just has bad welds.
Old 04-05-2016, 03:09 PM   #5
Starkiller
Which has bad welds? The exhaust or the Tomei pipe? My guess is the Tomei pipe. Which is a little disheartening, because I have used their stuff before with great results. Their reputation for quality has always been great, so it makes me think that they moved their manufacturing to a different location. Outsourcing will ruin the world!! lol
Old 04-05-2016, 03:21 PM   #6
mav1178
mav1178's Avatar
I don't care about using stock locations. I care about the fact that unless you used the exact same jig as a factory exhaust, any deviation from the OEM setup may be putting too much stress on the front pipe.
How is it bolted together? Is it using the stock donut gasket or a regular bolt/nut? How are your exhaust hangers? How much movement do you have? Did you have to have the custom exhaust at a certain angle to mount it?
A lot of people don't realize why welds on exhausts break in the first place. It's usually because the entire system will break at the weakest point, especially when non-OEM parts are used. The jig used to fab the exhaust is key... and it's also why cheap exhausts fail, because they just buy an existing exhaust and copy the flange/hanger locations instead of actual R&D on a physical car.
-alex
Edit: as for your front pipe problem, it may work fine. I'm just saying that your custom exhaust may be exposing the current weakest link in the system.
Old 04-25-2016, 08:18 PM   #7
OzzyGT86
OzzyGT86's Avatar
Drives: Ultramarine GT86
no problems here and been running the front pipe for over 10,000 miles.. track days too might just be what above posters have stated.
OzzyGT86 is offline   Reply With Quote
Old 12-14-2016, 06:16 AM   #8
troek
troek's Avatar
Drives: 2012 Toyota 86
Reviving the post, my apologies.
My tomei pipe is cracking on the welds too. stock overpipe and midpipe, hks EL header.
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
Starkiller (12-16-2016)
Old 12-15-2016, 11:44 PM   #9
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
i am all tomei, from headers to full exhaust and i have no problems.
Dr. BRZ is offline   Reply With Quote
Old 12-16-2016, 08:44 PM   #10
troek
troek's Avatar
mine gets tracked from time to time, maybe its the heat? im gona get it welded once and if it happens again, ill just get a different one.
Old 12-18-2016, 01:52 PM   #11
AlphaMotorsports.ca
Drives: Rocket Bunny BRZ, Track FRS
We haven't experienced any issues with the Tomei FPs, but we have encountered a few units with the some cracking at the weld on the Tomei catbacks which Tomei has been warrantying.
AlphaMotorsports.ca is offline   Reply With Quote
Old 01-05-2019, 05:01 PM   #12
adam389
Drives: '19 Toyota 86 TRD
Necroing this thread. Complete Tomei exhaust (uel header, op, 80mm front, type 80 rear) in for about a month. Just found a big crack on the rear muffler weld
Sent from my SM-N960U using Tapatalk
adam389 is offline   Reply With Quote
Old 05-04-2020, 03:22 PM   #13
Kynans
Ultra Junior Member
Kynans's Avatar
Drives: 2013 Scion Frs First Edition
Unhappy TOMEI 80MM EXPREME TEST PIPE
I have been having similar issues with the 80MM Ti catless front pipe. I have the Tomei UEL catless header, Tomei overpipe, and Greddy evo4 3" catback. I started seeing cracks in the weld connecting the pipe to the bell housing frame about 9 months ago. I just checked the connection this weekend and saw that one of the weld points to the pipe has completely fractured through!!! I attached a photo from 9 months ago when I first noticed the cracks, and another that I took this weekend. I have had no previous reply from Tomei and I have just emailed them again today about the issue.. anyone else see something like this?
Lucky me there is still half a weld left for now, I made a resin shim to go in between the exhaust hangar and mount to try and absorb some of the vibrations from the Catless UEL.
Kynans is offline   Reply With Quote
SPECIAL PRICE TOMEI TITANIUM MUFFLER TYPE -80,60S,60R/FRONT STRAIGHT PIPE TYPE-80,60 myjdmparts Groupbuys 15 10-08-2015 10:41 PM
fs: Tomei Titanium catless front pipe used one week rippin.rex Canada Classifieds 3 03-13-2015 08:42 PM
fs: Tomei Titanium catless front pipe used one week rippin.rex Engine, Exhaust, Bolt-Ons 5 03-02-2015 12:19 PM
Tomei titanium front pipe toby714 Engine, Exhaust, Transmission 5 11-29-2013 03:41 PM
