Old 03-24-2016, 09:07 PM   #1023
steve99
Drives: FT86
Originally Posted by tato.valverde View Post
So I've been reading your threads and Wayno's threads on MAF scaling... is that java program from RomRaider's forums the best option to go with? Or is it better to tweak the tables manually?
yep vgi's maf scaling utility is rearly good its got help screens as well.
while you can do the open loop manually you might as well let the utility do it for you.
Old 03-24-2016, 09:55 PM   #1024
makinen
makinen's Avatar
Drives: Toyota 86
Originally Posted by Kodename47 View Post
What cam timings did you get in the end?
Could probably make a bit more by targeting a bit richer to allow a little more timing advance. Dyno chart looks quite good though. Why the request at 6600? Due to the way the power drops off? If so, not much you can do.
Yes, because of power drops from 6600 rpm.
I've tried several timings using vgi's tool, but not much diffetence in actual acceleration.
makinen is offline   Reply With Quote
Old 03-27-2016, 10:01 PM   #1025
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I'd try adding half a degree of ignition advance across the power band in the high load areas since your log loos to be relatively knock free, then go from there. Take a log with the increased ignition advance trim back timing in areas where you are registering knock corrections or add more advance if you think it can handle more.
Personally I've seen notable increase in whp by increasing ignition timing only .3* to.7* in the right spots on the powerband. Though I'm not sure whether if your butt dyno is going to feel a 5-10whp increase at the top end, to be honest.
Intent > Content
Old 03-28-2016, 05:17 AM   #1026
churchx
churchx's Avatar
Drives: 2014 GT86
butt dyno feels easier fixing of torque dip then +5whp imho.
Old 03-29-2016, 01:48 AM   #1027
solidONE
solidONE's Avatar
+5-10 whp at the 3500~4500 range really hits the butt dyno
Intent > Content
Old 03-30-2016, 12:26 PM   #1028
Silver86K
Drives: Silver 86
Hi All,
I've been running a modified OFT tune on my car and logging like crazy trying to follow Wayno's Guide to dialing in a base tune.
Here where I live we only get 95 Ron (yes pretty shit)
Can someone have a look at this log and tell me what they think. So basically the AFR and Commanded AFR look good, IAM consistently on 1.
I'm not to sure about the LTFT?
I'm also seeing FLKC hitting -1.95/-2.25 in this log.
Here is my log:
http://www.datazap.me/u/86driver/95-...zoom=2931-3763
Silver86K is offline   Reply With Quote
Old 03-30-2016, 12:35 PM   #1029
steve99
Drives: FT86
Originally Posted by Silver86K View Post
Hi All,
Here is my log:
Yep that flkc over 5500 is knock. don't worry too much about the -0.65 but the stuff over -1 needs sorting out.
on your fuel I would try adjusting the PI/DI fueling ratios so you run full Direct injection until 7200 rpm.
look at the PI/DI ratio tables in the E85 fuel roms and change the axis as is done in those (all three tables cold/warm/hot
running the DI up to 7200 help with knock on your fuels.
we did this for @sav with good results, assume your in south africa
as per the bottom table
The ltft is a bit off at lower rpm might be extremes of temp causing that, if it does not selle down you might want to do a bit of maf scaling
also your running a bit leaner than commanded AFR ie your measured AFR is leaner than Commanded (what ecu is asking for) so again a bit of maf scaling will help you as you will run a bit richer higher rpm which will help with knock
Old 03-30-2016, 01:02 PM   #1030
Silver86K
Drives: Silver 86
Thanks Steve, been reading through alot of things you posted too.
How exactly do I go ahead and change the Axis?
Old 03-30-2016, 01:04 PM   #1031
steve99
Drives: FT86
just same as changing table values, just type in new value ;-)
Old 03-30-2016, 01:08 PM   #1032
Silver86K
Drives: Silver 86
Okay thanks will give it a shot and run the tune in and log again
Old 04-01-2016, 06:42 PM   #1033
seant2h
Drives: 2013 BRZ 6MT LTD
Hello all, I'm new to OFT and I am super excited about this little tablet. I flashed it (so easy) and drove about 15-20 miles of normal driving and then I did a few logs. I have a 2013 BRZ and I am running a JDL UEL, catted midpipe and catback with a k&n filter so I loaded up the Stage 2 UEL tune
http://www.datazap.me/u/seant2h/log-...=1-3-4-9-11-12
http://www.datazap.me/u/seant2h/log-...ata=1-7-8-9-11
seant2h is offline   Reply With Quote
Old 04-01-2016, 06:59 PM   #1034
steve99
Drives: FT86
look fine
tiny bit of knock but only minor iam is solid at 1
once you get more familiar and if your kean you could switch in the JDL UEL specific cam timing into your tune
Intake and Exhaust VVT CAM tables for JDL UEL catless headers.
http://www.ft86club.com/forums/showp...3&postcount=10
you will need to use romraider see links below
Old 04-03-2016, 05:30 PM   #1035
cjd
cjd's Avatar
Drives: 2017 BRZ
Hoping someone may have a little better idea what's going on here than I do.
http://datazap.me/u/cjd/log-14597179...=0&data=1-8-12
Went out for a drive today and things got a little weird - first odd thing I noticed was horrible bogging when trying to get the car moving from a stop - I'd guess the car had just warmed up fully at that point, but I started logging. It also didn't repeat itself. Seemed responsive on the highway, unfortunately the WOT pulls I got didn't save (I guess I dismissed a screen I should not have when it hit the log length limit...) but I got the few miles home from the highway.
LTFT is a clear problem - I was watching it early on (before I started logging and after the first log was started) and it seemed to be -2 to -3 when I was at stoplights. Since things seem normal-ish any time throttle is applied, I'm suspecting perhaps an intake leak? I checked for any signs of exhaust leak when I was doing an oil change the other day (engine oil and transmission oil both) but I also lifted the engine a bit to do motor mounts, so... maybe I damaged something on the exhaust side, though of course something on the intake side could have been messed up too.
Thoughts?
Old 04-03-2016, 05:56 PM   #1036
steve99
Drives: FT86
Thoughts?
High positive fuel trim can be indicator to exhaust leak, or cracked header. 02 sees fresh air at lower rpm between exhaust pulses.Ecu thinks its lean adds fuel via fuel trims.Looks like you have some knock as well at lower rpm causing iam to drop to 0.7 are you on 91 or 93 fuel ?
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
