Old 06-15-2012, 08:39 PM   #1
driver01
Drives: brz 13
People having a hard time with the FR-S blind spot
I was talking to a coworker and the subject of adjusting your outer mirror (aka side view mirrors) came up. he explained to me how to adjust your mirrors in such a way that you have great awareness of the traffic around you. Before this, I would adjust my outer mirrors in such a way that I can see my car in the mirrors. after trying this "new" setup I feel more comfortable driving. A couple months later I found an article about it, so... here it is.
(it might be disorienting at the begining but great once you get used to. also, I would still recommend to do a shoulder check when changing lanes, specially if you are on the right lane and there are two lanes to your left as the car on the far left might be doing a lane change at the same time as you. or vice versa)
For the past few years, various carmakers have been offering blind-spot detection systems for their cars’ side mirrors. Often complex, these systems employ cameras or radar to scan the adjoining lanes for vehicles that may have disappeared from view.
The Society of Automotive Engineers (SAE) published a paper in 1995 suggesting how outside mirrors could be adjusted to eliminate blind spots. The paper advocates adjusting the mirrors so far outward that the viewing angle of the side mirrors just overlaps that of the cabin’s rearview mirror. This can be disorienting for drivers used to seeing the flanks of their own car in the side mirrors. But when correctly positioned, the mirrors negate a car’s blind spots. This obviates the need to glance over your shoulder to safely change lanes as well as the need for an expensive blind-spot warning system.
The only problem is getting used to the SAE-recommended mirror positions. The cabin’s rearview mirror is used to keep an eye on what is coming up from behind, while the outside mirrors reflect the area outside the view of the inside rearview mirror.
Those who have switched to the SAE’s approach swear by it, however, some drivers can’t adjust to not using the outside mirrors to see directly behind the car and miss being able to see their own car in the side mirrors. To them we say, “Have fun filling out those accident reports.”
driver01 is offline   Reply With Quote
Old 06-15-2012, 08:41 PM   #2
driver01
Drives: brz 13
Another tip, that i figure out about this. if you set up your right side mirror lower than usual, you can still see the car in your blindspot as well as the curb beneath you when you are trying to parallel park. No more curb rash.
you just have to move your head slightly to the right when parallel parking to get the right angle to see the curb
Old 06-15-2012, 08:59 PM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
What the article fails to consider is that by seeing the flanks of your own car in the side mirrors you can better judge distance; something that's very difficult in the right hand mirror.
I also take exception with the statement that by adjusting your mirrors like this you no longer have to turn your head to check your blindspots. Always double-check your blind spots.
Now I'm not saying people shouldn't adjust their mirrors like this. It makes good sense. But some people have depth perception issues and may NEED the flanks in the mirror. And what you see in the mirror should never replace common sense and what you can see with your own eyes.
Old 06-15-2012, 09:23 PM   #4
That's exactly how I have my mirrors set up, and I have no blind spot. I can drive the car safely with reference to mirrors only.
Besides, the FR-S is a glass ****pit compared to my wife's Mustang convertible, or flying a Cessna 172!
Old 06-15-2012, 09:52 PM   #5
FRiSson
Drives: FR-S MT
Difficult to get used to
I have adjusted my mirrors to eliminate the blind spot, but it is hard to get used to. I still swing my head back and forth when I merge to get a view from both the old and new position.
FRiSson is offline   Reply With Quote
Old 06-15-2012, 10:00 PM   #6
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I've been setting up my mirrors like this since they showed my how in drivers training when I was 15... WAAAY better!
Old 06-15-2012, 10:04 PM   #7
mpicher
Autocross Nut
mpicher's Avatar
Drives: Argento 2013 Scion FR-S - MT
My wife's 2012 CR-V actually has a split drivers side mirror. It's a little funny to get used to but it's effective.
mpicher is offline   Reply With Quote
Old 06-15-2012, 10:07 PM   #8
BlaineWasHere
Grip>Drift
Drives: FRS
When I worked for a beer distributor all of our full size vans had this on both sides and I LOVED it!
Old 06-15-2012, 10:52 PM   #9
neutral
Drifter-Wannabe
Drives: Firestorm MT FR-S
Send a message via AIM to neutral
For me the issue isn't the lane next to me, but the lane two over. I'm always super paranoid about merging into someone trying to merge into the same lane at the same time. I've had the mirrors set up just like that picture for years now, and haven't had a problem with the lane immediately adjacent since. But I can't do a quick look-back anymore to check my 5 and 7 o'clock positions 2 lanes over. There's just car in the way
neutral is offline   Reply With Quote
Old 06-15-2012, 10:55 PM   #10
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
I've been setting up my cars and everyone I know like this since I first learned about it. I can't drive a car any other way!
Superhatch is offline   Reply With Quote
Old 06-15-2012, 11:36 PM   #11
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Agree with method of setting mirrors. It really does open the view to the rear so that as a vehicle exits one mirror it enters another or your peripheral vision.
As for knowing where the back end or your car is, it is always in the same place relative to the driver. You may need to resort to some other techniques to know where that is relative to the driving position, but once you know where it is, it is always in the same place!
Whereas the cars around you can always be changing position.
Drove a Ford Focus rental car recently with built in mini convex blindspot mirrors to assist the side view. They were in the outside upper corner of the mirror. What I thought interesting however was that when you adjusted the side view mirror as above, the mini mirror then gave you an even wider view. I had not seen that in a production mirror before. I also expect it would take some getting used too, if you have not had them before.
I am sure we have all seen aftermarket stickon's as well.
smbrm is offline   Reply With Quote
Old 06-15-2012, 11:46 PM   #12
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
I've done this for years. My old MX-3 had massive blind spots due to the way the rear curved, and positioning my mirrors this way was incredibly helpful. I adjusted the FR-S's mirrors to a similar position before I even took it off of the lot.
MVJ1975 is offline   Reply With Quote
Old 06-16-2012, 12:17 AM   #13
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
The above mentioned is about how I've set up my mirrors for a long time since learning about it years ago.
For adjusting the drivers side mirror place your head against the drivers side door glass and adjust mirror so you just see your vehicle in the mirror. For adjusting the passenger side mirror put your head in between the drivers and passenger seat (rear view mirror should be directly in front of you) and adjust until you just see your vehicle in the mirror. Then adjust the rearview mirror while in driving postion, centered to slightly more of the drivers side in view. I always physically check to both sides even with this adjustment because the adjustment does nothing for that driver beside you who is changing to the lane next to you while you want to go into the same lane.
Vracer111 is offline   Reply With Quote
Old 06-16-2012, 01:43 AM   #14
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
I've been doing this since I was 16. Can't believe its not common knowledge. There are a few downsides but this method is far better than seeing your own car. Especially in busy city traffic. Not that I wouldn't like to see my own car more...if I had one!
michaelahess is offline   Reply With Quote
How hard to replace BRZ Nav with aftermarket Nav? eikond Electronics | Audio | NAV | Infotainment 9 05-28-2012 08:52 PM
Test drive and spot avail in first shipment Oilers99 CANADA 0 05-17-2012 11:49 PM
Hard compound street rubber? slaxx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-01-2012 08:47 AM
Blind Spots? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 35 10-04-2011 04:17 PM
