| Software Tuning Discuss all software tuning topics. |
#15 | |
Drives: 2015 HL FR-S
#16 | |
The Stig's German cousin
I don't have a datazap account setup yet but I should figure that out sometime... |
#17 |
Drives: 2013 "Hot Lava"
I think I got a bad batch of gas last night when I filled up from half a tank. Previous couple weeks I'd been .97-1 IAM at first running 91 Oct. Stage 1 as I had remaining bits of 90 and 91 from a trip out of town that were at the bottom of a 93 fill-up once back in Austin. A day or so before installing my JDL UEL I bumped to 93 Stage 1 and then 93 Stage 2 immediately after the install.
A week or so it's doing great, .97-1 IAM and I run that first tank on the UEL down to half last night and fill up on the way home. This morning it feels off, coinciding with this being the first truly warm day since I've been running OFT. I hooked it up at lunch running errands and noticed very high intake temp 5-10F above what my dash showed as ambient temp and my IAM was dropped to .7 and I saw it rise to .82 by the time I got back to work. On the way home it was back down to .7 and only went back up to .71 and I could really feel it. I did a short log and sure enough I caught some knock in the 3-3.5K range, damnit. Gonna drop back to 91 Stage 2 and see if that clears it up. It also looks like, based on my ECU number, that I will want flash back to stock, un-marry and get the dealer to flash in a later version and try this again
2013 Hot Lava FRS :: OFT Stage 2+ :: JDL UEL Catless :: JDL Over-Frontpipe :: GReddy Evolution RS Catback :: Enkei "Tarmac Black" RPF1 :: Tein Flex-Z Coilovers :: 245/35r18 Conti DW :: RS*R R-LCA :: Racer-X Fab R-Toe Arms :: Mishimoto Intake Tube :: Mishimoto Oil Catch Can :: JDL FSTB :: Raceseng "Slammer" + RLO :: Diode Dynamics HID + Tail-as-Turn + DRL :: 5:AD Spoiler ::
#18 | |
Drives: FT86
you will need to mod tune as per the tune tweaks link below , see the links to moding tune for 91 fuel the oft tunes are based on latest compatable stock rom for your car so getiing delaer reflash will not help with your knock. Also all stock tunes are the same its jist utility bug fixes no power or performance mods right up to latest F40C roms |
#19 |
The knock just started based on some suspicious timing. You mod for transient issues that might change again with the next tank of gas from a different source?
The dealer reflash would be because the stock flash and the mod flashes I'm using are based on versions from 2013 that have the injector seal failure issue. I'm looking to correct for that and not have the motor pop and then have to explain why the OFT isn't responsible, or do all the flashes fix these issues as well?
#20 | |
#21 |
Yeah, I want to say that I've read as much but I've also read it suggested getting the the updated OEM flash that fixes it and any other issue. I'd want to know for sure.
#22 |
Drives: 2013 Fr-S UltraMarine
didn't want to make a new post wondering if anyone here could just help me out.
oft is coming today in the mail. before i even hook up the oft, should / do i need to drive the car around for a lil. haven't started my car today it's been sitting in the garage all morning. |
#23 | |
Drives: 2013 Ultramarine Scion FRS MT
You don't have to drive it before you write your stock ROM to the OFT. You battery should be fine assuming you haven't let it sit for an extended period of time without running it. I suggest you take a look at this thread, the "First Use" section in particular:
http://www.ft86club.com/forums/showthread.php?t=71157 Quote:
#27 |
so before I hooked it up to my car.i made sure to update the oft from my laptop.after that.i did the normal install..plug in oft.turn ignition to on. Pick gt86. Then read..it'll keep getting this errorSent from my SM-G920V using Tapatalk |
#28 | |
Drives: FT86
if your cars original ecu calibration was 400C, 700C, A00C, A01C,B00C the oft rom you flash will actually be a B01C version (or the equitant D version if your auto). even thoug it may be labelled with your original calid, ie with the oft rom your already on the latest flash. note you may see your old rom calid like A00C or something but the actual rom in car is based on B01C. |
| Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps | DeliciousTuning | Software Tuning | 1213 | 06-17-2025 04:02 PM |
| R/T Tuning & R/T Tuning Speed Shop Review Thread | R/T Tuning | User/Vendor/Sponsor Reviews, Feedback, Comments | 37 | 10-03-2014 02:23 PM |
| Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) | DesertFrs | Northern California | 14 | 04-24-2014 03:15 AM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
| Visconti Tuning - Latest Forced Induction Tuning Info | Visconti | Forced Induction | 340 | 04-30-2013 06:33 PM |
