#995 |
Drives: 2014 WRB BRZ
Are there any ways to get more angle from a stock car?
#996 | |
Drives: 2014 Scion Frs Whiteout
Boost
| The Following User Says Thank You to DriftinFRS For This Useful Post: | SoCal80six (03-31-2016) |
#997 |
Drives: '24 GR86
Megan tie rods are the cheapest and easiest solution. Otherwise, you're looking at modifying the knuckles.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | CarzCarzCarz (04-01-2016) |
#998 |
Drives: '13 10 Series FRS #1203
So I have to say, I'm impressed with the megan rack ends.
The do increase angle by what I'd say quite a bit. The 1" gap or so that i had between my wheel and swaybar now rubs. While its April here in NY, we got some snow today and i was playing around and was giddy; it just felt so much better. Also, I took a picture of them (stock and megan) side by side. unfortunately like an idiot while in the zone, we did not take angle measurements on the car before and after.. I thought it was extending the rod; though after seeing it, it makes more sense; it simply changes the pivot point to allow more angle; much like rack spacers on an S13 as i understand it. ![]() I also corner corner balanced my car. I would highly suggest everyone do the same. A friend of mine has a legit set of scales/camber/toe/bumpsteer tools so we decided to do a full alignment and corner balance with all my parts. Firstly; depending on your car, your dampers, you the driver and your level of OCD or need for that stance life, if the potential of uneven ride height bothers you then its not for you.. However if you want a car that feels extremely stable and exactly the same in both directions, well then you should deff do a corner balance. While I don't condone messing around on the street, I was able to go into an old commerical building lot and whip the car around on dry pavement (day before the snow) I honestly have never felt so "confident", like the car did not get twitch, it transitioned in a manji better than it ever has. |
| The Following 4 Users Say Thank You to Shady195 For This Useful Post: | 2015firestormFRS (02-03-2017), CarzCarzCarz (04-05-2016), gatorbushmen (04-04-2016), tato.valverde (04-05-2016) |
#999 |
Thank you Shady195 for the informative post above, from this I've ordered a set of the megan rod ends. I'll try to take pics of my wheel spacing and whatnot when I install them.
#1000 | |
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
#1001 |
It might be a little while before I get a chance to do the install, as I'll be out of town soon. But I will do my best when I do get around to it.
#1002 |
I'd recommend holding off. You can spend that money on a lot of other worthwhile parts to make your experience better. While the PBM/Driftknuckle/Wisefab kits will give you more angle; Without boost these cars don't really lack the power to push that kind of angle. They will certainly help make a save if you over extend yourself; but your not going to have the power to hold it IMO. The car struggles enough if you watch some of the videos in hear, requires a lot of clutch.
| The Following User Says Thank You to Shady195 For This Useful Post: | tato.valverde (04-11-2016) |
#1003 | ||
Drives: '24 GR86
The PBM kit is great, but all the steering angle in the world is useless if you have a car that's unable to keep the wheel speed up. You can run stock power with the PBM kit and throw massive hangle, but you won't be able to hold the wider lines. You'll find yourself with too much forward bite and you won't be able to maintain the line you want. In my opinion, just cutting the OEM knuckles or doing the tie rods is the way to go if you plan on staying N/A. If you intend to go with forced induction and really want the maximum angle possible, then PBM would be my first choice. Though I would add Todoroki 30mm front fenders or something, because seeing that Teurck'd bullshit front fender fitment pisses me off.
| The Following 2 Users Say Thank You to TylerLieberman For This Useful Post: | Shinchu (04-17-2016), tato.valverde (04-11-2016) |
#1004 | |
Amateur Drifter
Drives: '13 FRS
It does depend on the tracks you drift at though..... The only way I wouldn't recommend PBM is if you drift at tracks that you have a hard time revving the car out, or not being able to get enough entry speed. Entry speed becomes such an important factor when dealing with a low powered car with alot of angle. Regardless, I respectfully disagree with those that justify not getting PBM because the car doesn't have enough power. I went from having just megan inners, to a custom knuckle/outer tie rod setup, to PBM and it is by far the best mod you can do once you feel confident enough in your drifting. Here is some video of my first event with the kit installed. Fast forward to 8:50 for my best run. [ame="https://www.youtube.com/watch?v=a8jPoY0U_F0"]https://www.youtube.com/watch?v=a8jPoY0U_F0[/ame]
| The Following 2 Users Say Thank You to gatorbushmen For This Useful Post: | CarzCarzCarz (04-12-2016), Manji (04-23-2016) |
#1005 | |
Amateur Drifter
Drives: '13 FRS
#1006 | |
Drives: '24 GR86
On another note, I've seen a couple of your videos on YT. Cool to see somebody progress with their build and drive it. Nice change of pace from the other channels I see of people doing nothing but vlogs driving on city streets in traffic.
#1007 |
Drives: 2016 FR-S Asphault MT
Im following gatorbushmen on yt also. Good vids dude! I have been out of the drift game for a while and i even checked your first drift event suggestions just to see if i remember what to bring. I would also add to that list... fluids! For the car and yourself. Good vids though man you are catching on and really doing well!
Oh yeah and i think my helmet is a snell 2000 lol im old... As for the angle, yeah i would really say the pbm angle kit is not for beginners. Learn t h e car with stock angle first, then get the tie rods after a while. I really just want the rods and try relocating the swaybar mount since that binding would piss me off. Man i need to get to an event. Easiest thing is thursday nights in riverside but thats a mofo when i work in san diego at 6am lol otherwise i need to look for moto's events.
#1008 |
No rice, no life
Drives: 2013 Asphalt FR-S
I've got the PBM kit and it looks like I will need wider fenders to fit any tire bigger than 215 under there. I test fitted my 18x9.5 wheels and I didn't dare try driving on them because I knew they would rip off the fenders.
I'm looking at the Todoroki fenders, but it's hard to justify the $1200 price tag and I worry 30mm might not be enough clearance. I'm tempted to just order the Rocket Bunny front fenders since they're only $500, but that would probably look really goofy. The worst part is that until I figure out this fender problem, I can't track or drift my car
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
| The Following User Says Thank You to campy For This Useful Post: | chaoskaze (04-25-2016) |
| Is there a thread for 'people doing stupid things in their brand new car' thread? | Symbiont | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 02-18-2013 12:24 PM |
| BRZ Drifting. | Hunter | BRZ Photos, Videos, Wallpapers, Gallery Forum | 7 | 09-20-2012 08:57 AM |
| So Cal drifting | Thefear13 | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 08-10-2012 04:53 PM |
| REAL drifting thread | TylerLieberman | Off-Topic Lounge [WARNING: NO POLITICS] | 17 | 02-28-2012 04:20 PM |
| FT-86 II (RC) Drifting | ft86cbx | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 8 | 11-11-2011 02:02 AM |
