Old 03-31-2016, 03:03 PM   #1737
b rawr z
b rawr z's Avatar
Drives: 2014 BRZ, 2008 Impreza
I can't do all the work for you. Turn to page one and give this thread a few minutes. I have read the whole thing. Everything is explained in detail. Many questions asked, just like yours, with answers. Also, I already told you it will fit with coilovers.
I didnt ask you to do all the work. Lol. Maybe you should read what my first post stated.
"hey guys. i SEARCHED in the forum if 255/35/18 on 18x9.5 +38 lowered on coilovers will fit. IVE ONLY SEEN CONFIRMATION THAT IT FITS ON EIBACH SPRINGS. currently lower than 1.5. any idea? i know 245/35/18 will clear. just mainly concerned up front."
b rawr z is offline   Reply With Quote
Old 03-31-2016, 03:17 PM   #1738
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I read what you wrote. It is not correct. They will not fit with springs.
For what you are doing, you need coilovers. Springs are larger diameter than coilovers. The smaller diameter adds clearance, which allows more negative camber. Also, the OP is very knowledgeable, if you read his posts, you will understand what you need. No where does he say 9.5 will fit with springs.
b rawr z (03-31-2016)
Old 03-31-2016, 03:18 PM   #1739
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
hey guys. i searched in the forum if 255/35/18 on 18x9.5 +38 lowered on coilovers will fit. ive only seen confirmation that it fits on eibach springs. currently lower than 1.5. any idea? i know 245/35/18 will clear. just mainly concerned up front.
Sent from my HTC One M9 using Tapatalk
I am running those specs car is pretty low. we are friends on facebook. you can see pics.
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following User Says Thank You to nickmerronesucks For This Useful Post:
Old 03-31-2016, 03:27 PM   #1740
b rawr z
b rawr z's Avatar
Ill check em out. Thanks
Old 03-31-2016, 03:54 PM   #1741
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Originally Posted by texasbound972 View Post
I love my 275s but will definitely go wider in the rear soon!
Sent from my SAMSUNG-SM-N920A using Tapatalk
Why so wide? No traction?
The Following User Says Thank You to NyC Zn6 For This Useful Post:
texasbound972 (03-31-2016)
Old 04-01-2016, 11:33 AM   #1742
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
running a 9.5 in the front with a meaty tire on stock struts is just more hassle than its worth and as you saw from king tuts post on the first page, the clearance is incredibly tight and to make it work you really gotta pull that strut in and have a really low yet stiff spring. This is why those going to springs should really stick with the 17x9 +35-ish formula with a 245 tires. That is a spot on fit for htese cars and is more than plenty of tire for the car given you run something decent and not nakangs or other garbage.
if you're asking about 2mm difference, you've got some reading to do man. read and comprehend what people are telling you and what others wrote in here. if you're already on coilovers you will be fine. you may rub on hard dips and like i said in my first post YOU WILL RUB ON THE REAR BUMPER COVER TABS so dremel that shit off or let the tire do it for you.
what kind of 255 tire are you going to run? not all tires are created equal.
if you don't want to roll rear to run minimal camber go to -2.2 front and -2 rear if you can even adjust the rear. make sure who ever does the alignment toes in the rear. Total toe in .18 roughly. Keep in mind that your rear is not adjustable camber factory so you will need an LCA if you want to fix that because as you lower the rear it will camber in-i highly suggest SPC, but if you want to spend money then go SPL. Those are my only two recommendations just because i've seen so many and know how pain in the fucking ass it is to adjust arms like the cusco for example.
i dont think alignment stuff was posted in detail in this thread before so here is a quick explanation of how things basically work on this car and generally on all cars in terms of geometry. Keep in mind we have McPherson strut front and double wishbones rear. i'll explain why i talk about more camber up front, less camber in rear and toe in rear, toe out front. i should probably copy this into the OP.
so camber...basically in order to maximize cornering force from your tires, the tire must be square on the road during a corner to achieve max grip. If your car had zero camber (all tires square to the road when driving straight), as soon as you turn, the body will roll to the outside, and the outer tires will roll only on the outsides of the tires. Thats why if you ever drove a car with stock alignment hard in turns, you'll see the outsides of the tires worn.
Because of the twin's suspension geometry. Simply put, as the car rolls in a turn, the outside wheels' suspension compresses (makes sense right?). The rear suspension was designed to gain negative camber as it compresses. So as the body rolls, the tire does not roll over as much as the car's body roll, maximizing the tire's contact patch. The front suspension is different, it does not gain significant negative camber as it compresses (during body roll in a corner), and therefore allows the tire to roll over to the outside edge, minimizing traction. This is why you must give the front end more negative camber to begin with. (Another very popular BRZ trick is to run a stiff front sway bar, to limit the front body roll and maximize tire contact).
now toe..Toe-in will stabilize the car, making it track straight and not want to change direction. Toe out does the opposite, makes it twitchy, and want to change direction quickly. A car is more responsive with toe out, but significantly less stable. Just a basic definition.
FRONT Of CAR - Toe-out in the front lets the car turn in nicely, but may "tramline" down the road (finding grooves and irregularities and following them). Toe-in front makes the car hard to turn and want to "push" or understeer. I suggest going with total toe out front of -0.1 (so about -.05 per side)
REAR OF CAR - Toe-out in the rear is pretty dangerous for RWD cars, makes the car want to spin, especially under hard braking. Toe-in rear will keep the rear stable, and (here is the key) allow for you to put power down as early and as hard as possible without wheel spin. More is not always better, racers will always adjust these settings till they get it just right. For the street, the suggested settings will let you set-it-and-forget-it. Negative camber does not kill tires. Negative camber plus excessive toe (in or out) causes inner tire wear. Toe (in or out) in effect forces the car to "drag" the tire down the road, where 0 toe lets the tire roll down the road. Make sense? Negative camber will cause the tire to roll on the inside of the tire, but negative camber plus excessive toe will drag the inside of the tire down the road causing bad inner tire wear.
TLDR: yes 255/35/18 on 18x9.5 +38 will fit just fine with coilovers. i now have no wheel gap all around and i'm perfectly fine. no rub no drama. But i'm rolled in rear and did alot of triming to rear bumper. If anyone is in NJ drop by @AZP Installs and i'd be happy to show you around the car.
-Ivan
Jive Turkey is offline   Reply With Quote
The Following 7 Users Say Thank You to Jive Turkey For This Useful Post:
ajaxthebetter (04-01-2016), b rawr z (04-03-2016), BirdTRD (04-13-2016), Bramick (04-17-2016), Leonardo (04-01-2016), nima314 (06-24-2016), smg1138 (03-31-2017)
Old 04-11-2016, 11:39 AM   #1743
PeterFRS
PeterFRS's Avatar
Drives: FRS
Can I play with 255's?
I have never complained of FRS power level but now it does feel slow
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to PeterFRS For This Useful Post:
DuMa (04-13-2016), slow15frs (04-11-2016)
Old 04-11-2016, 01:06 PM   #1744
Leonardo
Country Boy 4 Life
Leonardo's Avatar
It looks like you went from the stock size tire to a 255/40/17 Bridgestone Potenza (RE760?), is that right?
If so, you easily added 6lbs per tire. You are going to feel that. I know your wheels are light weight, but the fat kid on the out side of the merry-go-round will effect it more than if he sits in the middle.
PeterFRS (04-11-2016)
Old 04-11-2016, 02:47 PM   #1745
PeterFRS
PeterFRS's Avatar
Drives: FRS
Geez you hit the nail on the head!
Yup, the comparison pic is of my winter (stock size) and to the tires you mentioned.
Before my summers were the stock tires from factory..
Although the added feeling of slightly heavier steering is pleasant,
The fat one adding to the rotating mass isn't.
'14 Scion FRS
Tein Flex
TE37
Old 04-11-2016, 03:06 PM   #1746
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yeah, I had some RE760 in the past. They felt heavy to me.
The sidewall bulges slightly in the photo. Are your wheels 17x8 or 17x8.5?
Old 04-11-2016, 07:12 PM   #1747
PeterFRS
PeterFRS's Avatar
Drives: FRS
you have a keen eye sir
they are indeed 17x8.. I hope i won't get flamed for throwing on such wide tire on narrow wheels..
'14 Scion FRS
Tein Flex
TE37
The Following User Says Thank You to PeterFRS For This Useful Post:
Leonardo (04-11-2016)
Old 04-11-2016, 07:56 PM   #1748
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Not great for handling.
Originally Posted by humfrz
I'm old and lazy
Old 04-13-2016, 01:09 AM   #1749
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
255/40/17 Maxxis VR-1 on 17x9 +42 Mach V Awesome's
The Following 6 Users Say Thank You to ATL BRZ For This Useful Post:
ajaxthebetter (04-15-2016), BigFatFlip (04-13-2016), Calais (04-14-2016), Hicklinc (02-27-2018), Leonardo (04-13-2016), ShadowReaper (07-24-2016)
Old 04-15-2016, 11:27 PM   #1750
CBR600RR
Drives: Raven Black
New summers. Yokohama S Drives 225/45r17 on Motegi MR125 17x7.5 +42
Love the tires so far!
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
