Old 06-15-2012, 06:51 PM   #1
DookDookDGM
BR-Zizzle
DookDookDGM's Avatar
Drives: 2013 BR-Z, 1985 AE86, 1986 AE86
Send a message via AIM to DookDookDGM
Subaru of America BR-Z TechTalk Bulletin May 2012
My master technician dropped off the section of May's TechTalk bulletin from SOA for me while I was at work today. There's a couple odds and ends that might prove to be interesting and a few other things that might quell some fears or maybe even raise some concerns. I'm not near my scanner right now, so for now you'll have to deal with me just re-typing everything.
BRZ REPLACEMENT ENGINE INFORMATION
In the event a replacement engine is required for a BRZ, be aware it will not include driver's side crush cover for the fuel injectors as shown in the photo. The left side cover will need to be changed over from the original engine or replaced with a new one if it cannot be reused. The right side cover is included with the replacement engine assembly.
BRZ FUEL INJECTION OPERATIONAL CHARACTERISTICS
You may notice, or customers may question, various sounds that change in volume and character from the engine and direct injection fuel pump at idle. These may be described as "clicking" or "clacking" sounds or a similar description. The sounds described are most commonly noticed at idle during initial engine warm up.
Be aware that BRZ utilizes both port and direct fuel injection systems. These systems are operated in one of three modes: Port Injection Only, Direct Injection Only, and a combination of both together. The transition between these modes of operation will occur automatically based upon inputs to the ECM. As the injection mode changes, there will be associated changes in the volume and character of the sounds coming from the injection system. Upon initial cold start, both direct and port injection systems are functioning. Within a short time (roughly 60 seconds, dependent on many factors), the port injection turns off and only direct injection is active. As a result, there will be a normal increase in injector sound volume. Shortly after that, injection will change from direct only to port only. After additional time, the mode will change back to a combination of both direct and port injection. These mode changes will continue to occur as decided by the various ECM inputs and will vary under changing conditions. Similar actions will also occur during hot start depending upon catalyst temperatures and other factors. These sounds are most likely quite different from what you may have experienced with prior Subaru models and are not a source for concern.
BRZ MANUAL TRANSMISSION SOUNDS
You may notice, or customers may question, a "thump" or "thunk" sound intermittently when placing the new six-speed manual transmission into first or reverse while stopped. This is a characteristic of the transmission operation which occurs when any remaining input shaft rotation is brought to a quick stop by gear selection. If enough time is given for the shaft to stop turning on its own, then no thump will occur. No wear or damage is occurring as a result of this action. This sound may be more noticeable as the gear oil warms and gear selection is able to be accomplished with greater speed.
So this means that most of the noises I have heard so far are considered "normal" - intriguing.
A little addiction goes a long way...
2013 Dark Grey Metallic Subaru BRZ
1986 Toyota Corolla GT-SR5
1985 Toyota Corolla SR5
DookDookDGM is offline   Reply With Quote
Old 06-15-2012, 06:55 PM   #2
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
I figured that all of the above was normal -- What I am more concerned about is the damn squeaking/chirping presumably coming from the drive belt tensioner pulley/device.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 06-15-2012, 06:56 PM   #3
DookDookDGM
BR-Zizzle
I hear that noise occasionally, too, at low RPM, mostly when shifting into 2nd. I dunno if it's actually the tensioner, but it sounds like tensioner chirping.
Old 06-15-2012, 07:00 PM   #4
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
This is what I love about this forum. Collectively, we have all noticed, discussed and came up with conclusions with at least the last 2 issues. Its still nice to get some kinds of "official" statement on them though. Thanks!
Old 06-15-2012, 07:45 PM   #5
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Thankfully we haven't needed to figure out the first one!
Old 06-15-2012, 11:14 PM   #6
Jayde
Jayde's Avatar
It sounds more like the injectors if you ask me.
Jayde is offline   Reply With Quote
Old 06-16-2012, 02:17 AM   #7
Subaruwrxfan
Subaruwrxfan's Avatar
Drives: 2015 Mustang EcoBoost
I'm really curious as to why they're even mentioning replacing engines...it's almost as if they anticipate it, along with the other two complaints of the injectors and transmission.
Check out my BRZ videos on my YouTube page: youtube.com/subaruwrxfan
Subaruwrxfan is offline   Reply With Quote
Old 06-16-2012, 09:25 AM   #8
I don't think there is anything unusual about this. The engines are mechanical devices and when you produce this many even a 99.9% success rate means you are going to have dozens of failures that need to be replaced for some reason.
Old 06-16-2012, 11:27 AM   #9
stateless
Double Dragon
stateless's Avatar
Drives: 2013 6MT BRZ Limited
You'd think in the age of ubiquitous video that car companies would simply release a short video/sound clip demonstrating normal operation sounds and any deviant sounds to be expected. Seems so much simpler than vague descriptions like "thunk" and "click", which could refer to a variety of different sounds.
stateless is offline   Reply With Quote
Old 06-16-2012, 03:56 PM   #10
OrbitalEllipses
Drives: Attitude
Let's not even talk about hard drives; 10% DOA rate is industry STANDARD. MTTF and MTBF...yeah, I doubt the engines in these cars are near 99%, but they won't be in anything except a boutique supercar.
Old 06-16-2012, 08:41 PM   #11
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I would guess it is because the replacement engine will not look like as orders and rather than wait for someone to need a engine and deal with it then they sent out the information right away.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 06-16-2012, 08:52 PM   #12
#87
I usually post drunk
#87's Avatar
No mention of the rear driver side side clunk. Can you relay that some owners are experiencing this?
#87 is offline   Reply With Quote
Old 06-16-2012, 08:53 PM   #13
#87
#87's Avatar
MT -> Sport Car -> Youthful audience -> aggressive driving -> mis shift -> BOOM
Old 06-17-2012, 12:02 AM   #14
Tainen
Drives: First SWP BRZ-L
Holy crap, where do you guys buy hard drives? My DOA rates are less than .1%... Now mean time to failure might not be met by as much as 2 or 3 percent, but... 10? Man, I'd drop that company like a hot potato.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Toyota Service Bulletin: Body Panel Fitting Issues ahausheer Issues | Warranty | Recalls / TSB 99 03-07-2017 12:21 PM
JDM Subaru BRZ brochure (m01CZ012 2012.03) DarrenDriven BRZ Photos, Videos, Wallpapers, Gallery Forum 3 06-13-2012 01:45 AM
CarAdvice (AU) : 2012 Subaru BRZ Review Nambo AUSTRALIA 2 01-11-2012 10:05 PM
2012 Subaru BRZ appears on Subaru web site DIG1992 BRZ First-Gen (2012+) — General Topics 26 12-01-2011 05:20 PM
2012 Subaru Impreza matadormi5 Other Vehicles & General Automotive Discussions 54 10-27-2011 12:11 AM
