#2843 | |
- Andrew |
#2844 | |
We will have a custom valved and sprung Bilstein coilover available later this year which uses linear springs. Non-adjustable damping, but they're valved very nicely. KW V3 are a good street and light track coilover that would work well too. Our RCE T2s are customized KW clubsports, so a little more track performance if you're into that. Worth looking into. - Andrew |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#2845 | |
Drives: '13 FRS - STX
http://www.ft86club.com/forums/showp...4&postcount=87 Sounds like your only concern is wheel clearance and the KW's win by default. If you're considering other factors you'll have to weight the pros and cons yourself. Putting a 60mm ID spring on the fronts will result in similar clearance to the V3's I believe, but you'll be running a custom setup with only generosity to support you if any problems arise. |
#2846 |
Drives: 2013 Brz C38 (bought not built :P)
/looks at alignement stuff
CAmber ok... Toe...hmmm ,etc. /cries and ask @Racecomp Engineering for help Seriously, I'm currently running a DD 2013 Brz (with KW c38 sc, all solid mounts/bushings, kw v3 suspension, 18x9.5 wheels with pss) and plan to have some occasional light track duty and some sideways action (some grip but a bit tail happy should I wish to throw it sideway would be my ideal handling!? if that makes any sense). I have to get an alignement done at a local shop, but have no idea what type of specs I should give the guy as far as what I want (suspension is not my forte... neither is kia.. bad joke ok). After some reading (semi understanding wth I'm reading) I'm seeing that people with my setup tend to be around -1 to -2 camber (that's as far as my thought process can take me on this subject). So my question is any recommendations as to what alignment specs I should be looking at (and their corresponding number-ranges) for my application? |
#2847 |
Stock mounts? Rear LCAs?
Max out front camber with the lower mount on the KWs and you should be around -2.5 or so. Zero toe front and a tiny bit of rear toe in (or 0 toe in the rear if you don't really want the stability). - Andrew (currently in Scotland so I'll be slow to reply) |
#2848 |
Drives: 2015 Series.Blue BRZ
Going to get my Tein SRCs rebuild soon, is it possible to get them revalved to be the same as the CSG spec ones? What spring rates would I need for that? Currently on 10k front, 12k rear.
#2849 |
Drives: '23 BRZ Limited
I doubt Tein will be willing to burn one of their vendors by releasing their proprietary valving. Unless you go through CSG for it.
#2850 |
That's basically what I'm trying to find out. Going through CSG would probably make it easier on my too xD
#2851 | |
Drives: Subaru BRZ
Wow. This has everything. And yet in some ways nothing. |
#2852 |
Just the tip
@Racecomp Engineering or @CSG Mike
Hoping to get some recommended camber settings. I just got RCE Tarmac 2s. I have all the whiteline stuff with the exception of the bump steer correction kit and LCAs. I opted for the rear inner camber bolt/bushing instead for camber adjustment in the rear and in the front all I have is the whiteline bolts. I'm getting an alignment next week. I previously had 1.1 in front and 1.5 in the rear on Koni Yellow and RCE Yellows. I run RE11A tires currently 245/40R17. May switch to RE71R after these burn up in about a year. I do a 3-5 track days and 3-5 autox a year and the rest is daily driving. If you recommend more than 1-1.5 camber in the front I'm guessing I'll need to get a camber plate for the tarmac 2 oem top hat with spacer I'm currently using. One guy I talked to says -3 in front and -2 in rear is what's good. What do you guys say?
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#2853 |
Drives: 2015 Subaru BRZ
Looking for recommendations for Autocross/daily driving Caster settings. I've got a buddy with some modest national success recommending the absolute max possible for maintaining camber during turn-in. I'm just looking to see if you guys are echoing that sentiment. I've got the Whiteline caster kit sitting in my garage, should I kick in that extra .5* of caster or is 7.0 enough, or too much already lol.
Current alignment is: Front... Camber -3.3 Caster 7.0 Toe 0.00 Rear: Camber -1.9 Toe 0.10 Current setup is RCE T2's with Raceseng Cas/Cam plates. Wheels are Kosei 17x8+45 w/ 245/40/r17 RS3's, Whiteline 20mm front and 16mm rear adjustable swaybars. Toe arms, trailing arms, all of the other whiteline bushings as well. |
#2854 |
Drives: 2015 AOZORA EDITION
i have this rear clunk on my passenger rear every time i hit a big bump or at low speed on a bumpy road, i checked everything, its seems tight im trying to figure out if the actual damper can cause a clunking noise? what else.can i try to get rid of that clunk
#2855 | |
- Andrew |
#2856 | |
If you run courses with a lot of steering angle, then yes run as much as you can. One excellent motorsports engineer told me that caster is both track dependent and driver dependent. When you get to ~7 or 8 degrees it starts feeling a little "odd" to some and better for others. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Hostile_Kittens (04-13-2016) |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
