Old 03-28-2016, 04:29 PM   #323
8R6
8R6's Avatar
Drives: FRS
Originally Posted by frslee View Post
I recently installed my front sport performance kit. I'll try to take some pics after work and post this evening.
awesome! thanks man! cant wait to see
8R6 is offline
Old 03-29-2016, 09:23 AM   #324
frslee
Just drive it
Drives: 13' FR-S
@8R6 Not the best pics, but here they are. Stopping power is great and consistent. I really like this kit for my usage. It's larger than stock rotor, so it fills up the wheel area really well. One slight issue I had during/after the install was once the shims were attached to the pads and installed, it was ridiculously tight and the pad would drag to the rotors. I tried to wear out the pad, but it was keep dragging and didn't want to glaze the rotor. Ended up removing the shims and applied brake grease for now. It's so far quiet on braking. It's no big deal to buy shim set and apply once pads are worn down, or purchase thinner pad (0.65" I think. This one is 0.80" thick).
frslee is offline
The Following User Says Thank You to frslee For This Useful Post:
8R6 (03-29-2016)
Old 03-29-2016, 11:29 AM   #325
8R6
8R6's Avatar
Drives: FRS
thanks for the pics man! appreciate the tip about the brake pads too. yeah these are supposed to be 0.80" i wonder if that's just an issue with the pads or if the calipers. the calipers are supposed to take 0.80"
@Rafi@RR-racing - have you guys heard from other users of the Sport Performance kit having this issue with the pads being too thick? just wondering if this is a isolated case or a common issue but easy fix? thanks!
8R6 is offline
Old 03-29-2016, 11:57 AM   #326
frslee
Just drive it
Drives: 13' FR-S
I believe I saw Rafi's post saying that thinner pads can be installed. As long as back plate is same, but it's just less material.
frslee is offline
Old 03-29-2016, 12:31 PM   #327
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
Originally Posted by tato.valverde View Post
How much would replacement disks for the stage 4 be? and where would we buy them from?
bump
tato.valverde is offline
Old 03-29-2016, 12:52 PM   #328
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
bump
it's on the RR website
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline
Old 03-29-2016, 02:06 PM   #329
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
@frslee On the rotor is that rust from the coating going away?
Cockatoo is offline
Old 03-29-2016, 03:18 PM   #330
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Looks like rust on the rotor from where the rotor wasn't coated. They only coat where they expect pads to never touch, but the Wilwood pads clearly don't slide onto the rotor as deeply as whatever pads were intended for that rotor originally.
DocWalt is offline
Old 03-29-2016, 04:01 PM   #331
frslee
Just drive it
Drives: 13' FR-S
As person above mentioned, pad doesn't cover the entire rotor surface. Rotor is stock 2004 Impreza STI size. Since it's bare metal and exposed, rust line is formed. It doesn't bother me much though. I'm not sure on stage 3&4 kit, but up to stage 2 will have those rust line. Who cares, it brakes great!
frslee is offline
DocWalt (03-29-2016)
Old 03-29-2016, 04:07 PM   #332
Cockatoo
TALLY FT86
Cockatoo's Avatar
Dang, I just ordered the Front Sport kit and this issue would annoy the crap outta me...
@Rafi@RR-racing comments?
EDIT:
Im not seeing this issue here:
Originally Posted by Kostamojen View Post
Finally got my kit installed!
Cockatoo is offline
Old 03-29-2016, 04:10 PM   #333
MaximeT
MaximeT's Avatar
The is a zinc coating line that remain on stage 4. Looks great.
MaximeT is offline
Old 03-29-2016, 04:17 PM   #334
frslee
Just drive it
Drives: 13' FR-S
You're not seeing it yet. If you look closely between rotor surface and caliper, you'll see that the pad is not touching the rotor entirely. As he uses the brake and get rained on, inner circle will show rust.
If you've already ordered, why not measure the inner circle with pad on top and spray with caliper spray? That will help. Any little spray on rest of surface will disappear as you bed the pads in.
frslee is offline
Old 03-29-2016, 05:29 PM   #335
Kostamojen
Ya, there is like 1/2" of unused rotor.
Kostamojen is offline
Old 03-29-2016, 06:29 PM   #336
tato.valverde
Can you point out where? All i can find is that they are Coleman Racing rotors, but nothing else
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 04:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 11:31 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
