#169 |
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
Thanks man! Love your build also! My cars been there for along time, almost 3 months tomorrow. I got unlucky and got one of those faulty DW Fuel pumps, took awhile for the guys over there at that shop to figure out what was wrong with my car. Hopefully I can finally take her home this month.
#170 |
Are you 20/20?
Drives: Hopes and dreams
Jesus those seats.
| The Following User Says Thank You to AznKirby For This Useful Post: | R2RO (10-13-2015) |
#171 |
I highly recommend them, they're so comfortable and keep you in place when taking corners very well
#172 |
Most recent photo of my car in its current state, running the Volk Racing RE30's CSII.
| The Following User Says Thank You to R2RO For This Useful Post: | MCTeeJ (02-18-2020) |
#173 |
Drives: Mazda3
Sick build. +1 on Quality parts.
| The Following User Says Thank You to ottoyu34 For This Useful Post: | R2RO (12-03-2015) |
#174 |
Drives: 2013 Whiteout FR-S
did you ever get the design craft clutch fork?
TEAM NEMESIS | NEM 86 | IG: @NEM_86 PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics The NEM86 Build Thread |
#175 |
Drives: Ablaze
Did you have to roll the fender for the Advan?
#176 |
No I didn't, I was trying to reach him for months but no response back. But I had Evasive motorsports reinforce a spare stock one for me, Since my clutch starting making a really loud sound on deceleration it was only noticeable at low speeds(sub 30mph/4000rpm). The clutch still worked 100% and made no noise on acceleration. The clutch was reinstalled with the custom fork and I haven't had a problem since, also my stock fork was noticeably bent compared to the custom fab'd one. Just a heads up since I know you run a Twin plate also, its worth upgrading if any problems that I stated pop up on you.
Here's some photos of my stock fork and the custom one(Not finished at the time). It was fully reinforced when it was reinstalled, I just don't have photos of it finished. ![]()
#177 |
No fender work, but some adjustment was made with the alignment to make sure everything worked. But the car still rubs on full lock with 255 width tires with what I believe is a 1.9-2.1 inch drop, Im not 100% sure on the height since we have raised and lowered it multiple times.
#178 | |
| The Following User Says Thank You to pleong For This Useful Post: | R2RO (04-04-2016) |
#179 |
Finally dropped off the FR-S at Outfront Motorsports for the full rebuild on the FA20, Its going to be the 6th I believe Closed deck FA20 in the world. Since I have yet to see another company begin to develop a closed deck system for the FA20, I can't wait for this thing to be done and become one really high hp FA build! Stay tuned for the specs and updates as I get them from Outfront over the next month and weeks ahead!!
Specs: -Closed Deck Service -Bore/Power Hone w/ Torque Plates -CP Custom High-Compression Forged Pistons w/ceramic coating -Carrillo Pro-H 3/8 CARR Bolt Connecting Rods -Kings Performance Rod Bearings -Kings Performance Main Bearings -Outfront Motorsports 1/2" Stud kit -Stage 2 Porting for heads -Supertech Stainless Intake Valves -Supertech Inconel Exhaust Valves -Supertech Dual Valve Spring kit W/Titanium Retainers 74 lb -WPC treated (New FA20 Crank, Main bearings, Wrist pins, rockers, Cams, Rod bearings, and piston skirts), fully balanced and blueprinted. -Genuine Subaru Gasket Set -FLUIDAMPR Engine Damper ![]() ![]() Closed deck goodness from outfront motorsports! ![]() ![]()
#180 | |
Drives: Toyota GT86
| The Following User Says Thank You to wnt3d For This Useful Post: | R2RO (06-28-2016) |
#181 | |
Next comes either the option of a direct bolt on Garrett GTX3076R, which we will try to get it too mid 600 HP numbers on E85 or might just switch it up and go with a new twin scroll manifold fro, JDL and put a BorgWarner turbo on it. Or we might try and stick on a Garrett GTX3582R and try and hit 700Hp haha Personally I don't look to run more then 700Hp on the block, because I don't want to put that much strain on the Carrillo rods since they personally might be the weakest point in the whole build. Not because of the company, but because these FA motors run a offset design rod that isn't as strong as a straight one. If you go this route you should try and bore out the motor to 2.1 or 2.2L since the closed deck reinforces the block in the most vital area when the piston is fully compressing the gasses. Either route you go i'm pretty sure you will enjoy this motor, you will be able to beat on it all day at 500-600HP numbers and not have to worry about reliability.
#182 |
Finished installing my AP Racing Endurance kit on my FR-S today, Im going to do a full review and write up on my website Import-addicts.com Its going to have really high quality photos and tasteful review. So far I love these brakes it was a piece of cake to install if you refer to the instructions step by step, thanks Essex for producing these high quality brakes!
Here is the fitment with both of my wheel sets the Street (Advan GT) and Track (Volk RE30), Enjoy! Advan GT 18x9.5 +40 (So much clearance! 1.2+in) ![]() Volk Racing RE30CS2 18x9.5 +40 (About 0.5-0.7in of clearance!) ![]()
| The Following User Says Thank You to R2RO For This Useful Post: | DustinS (07-05-2016) |
| GT86 badge : whiteout fr-s | F3dzo | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 10-22-2012 08:51 AM |
| MT Whiteout available now... | JohnATL | Southeast | 8 | 08-09-2012 01:12 AM |
| My new Whiteout FR-S! | Flawless22 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 07-05-2012 02:46 AM |
| My whiteout fr-s | F3dzo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 7 | 07-04-2012 07:25 AM |
| Whiteout FR-S/86 | just86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 04-01-2012 01:16 AM |
