Old 03-26-2016, 02:48 PM   #1
lizbrayan
Drives: '15 Scion Frs Steel
Help please, cracked bumper
Size:  92.4 KBName:  uploadfromtaptalk1459014175382.jpg
Size:  65.2 KBName:  uploadfromtaptalk1459014186650.jpg
Size:  66.2 KBName:  uploadfromtaptalk1459014195224.jpg
So a few weeks ago I was driving home from work and I was getting on to the highway from a ramp going about 30-40 mph. In the middle of switching lanes, I guess I hit a pothole or something so bad that the car jumped up. Pulled over to check if I got a flat and to my surprise I had this huge crack in my front bumper. The car is a lease but I am 85% sure I am going to keep it after the lease term is up. I want to fix this crack but I also don't want to spend an arm and a leg getting a nee bumper and having to get it painted. Any advice? Is there a front splitter I can get that would cover most if not all of it? Or like an aftermarket bumper? I know I said I dont want to deal with paint and stuff but I think itd be worth it if it was aftermarket and it would make the car look better. Just looking to not break the bank. Thanks in advance guys!
Sent from my SGH-T999N using Tapatalk
lizbrayan is offline   Reply With Quote
Old 03-26-2016, 03:49 PM   #2
Kostamojen
You can get some ABS glue and glue the crack back together.
Old 03-26-2016, 03:57 PM   #3
raven1231
What you meant to say was " some **** hit my bumper "
lizbrayan (03-27-2016)
Old 03-27-2016, 02:17 AM   #4
lizbrayan
What is this glue you speak of and where does one get such a thing
Old 03-27-2016, 02:34 AM   #5
Kostamojen
Bumpers are made of ABS plastic. ABS plastic is the same plastic used for different types of plumbing. Its available at any hardware store.
Old 03-27-2016, 02:56 AM   #6
lizbrayan
Is there a certain type cause I just goolged it and theres like one for pluming, welding and so on. Which should I get? What do I have to do once the glue is on there? Will it be noticable?
Old 03-27-2016, 04:14 AM   #7
Kostamojen
I've never actually done it myself, you'll have to find someone who has.
Old 03-27-2016, 04:18 AM   #8
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Crazy glue bottom part, 3M clear top....or vinyl! Oh you can also wrap it?
I'd wrap like this below, although your car is not white...
Old 03-27-2016, 01:00 PM   #9
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
C-west front lip will cover it, you can see it on my avatar picture
KungFuWaffle is offline   Reply With Quote
Old 03-28-2016, 07:53 PM   #10
15limited
15limited's Avatar
If you hit a pothole that hard you also might want to check your wheel/ suspension components/ oil pan on that side.
I hit a raccoon and at first glanced I thought it had only cracked my bumper, which I zip tied back together to prevent further cracking. It ended up also bending my radiator and AC condenser.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 03-28-2016, 08:17 PM   #11
lizbrayan
The rubber/plastic underpart thay goes under the bumper was hanging off. I fixed that and checked everything else. It was all fine, just cosmetic damage.
The Following User Says Thank You to lizbrayan For This Useful Post:
15limited (03-28-2016)
Old 04-03-2019, 03:51 PM   #12
12foot
Drives: Scion F-RS
Did same thing. Cracked and scuffed quite bad Bought a kit. Was quoted 750$ from 2 shops. Nope.
12foot is offline   Reply With Quote
Old 04-04-2019, 02:23 PM   #13
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I'd throw a TRD Replica kit on there.
Clueless
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
12foot (06-21-2019)
Old 04-04-2019, 02:25 PM   #14
Pretty sure they have taken care of it in the three years since the thread died.
Cracked Screen on an OFT Thrustin Software Tuning 3 08-03-2014 07:29 PM
Cracked Oil Pan?! Jolaessss Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 11-21-2013 03:28 PM
Cracked taillight Drftfan Issues | Warranty | Recalls / TSB 2 07-12-2013 07:58 PM
Am I the First BRZ/FRS w/ a Cracked Windshield?!?!?! NYC BRZ BRZ First-Gen (2012+) — General Topics 65 05-04-2013 01:14 AM
Cracked Rim SmsAlSuwaidi Issues | Warranty | Recalls / TSB 29 04-02-2013 02:30 PM
