Old 01-15-2016, 10:42 AM   #1
86gt?
86gt?'s Avatar
Drives: asphalt 86
Vortech rebuild
Has anyone rebuilt a V3 for their twin yet? I have taken mine fully apart and then found out vortech will not sell parts for them. Can anyone recommend somewhere to get new bearings and seals that are suitable for this application? Im sure someone has already dealt with this issue, thanks in advance!
86gt? is offline   Reply With Quote
Old 01-15-2016, 10:51 AM   #2
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
http://www.m3forum.net/m3forum/archi.../t-450481.html
There's some pics at the bottom of this thread
The Following User Says Thank You to ZOMFGAARON For This Useful Post:
86gt? (01-15-2016)
Old 01-15-2016, 11:07 AM   #3
-Phil
Drives: Rb25 neo brz
Shoot first and ask questions later, I like it!
-Phil is offline   Reply With Quote
Old 01-15-2016, 02:35 PM   #4
DJCarbine
Thupercharged
DJCarbine's Avatar
I researched rebuilding/aftermarket impellers before I ordered my kit, came across a couple of sources that should be able to help with parts
http://www.928motorsports.com/parts/...ebuild_kit.php
http://www.superchargerrebuild.com/vortech/
Some even sell upgraded bearings for higher RPM usage. Not sure if the stock vortech impeller is good for faster speeds or if it was limited by the bearings vortech uses.. but its worth a shot if you want to try a very small pulley that would normally put the blower past the recommended max RPM.
They also include a better set of seals (or so they claim)
I know mine seeps oil VERY slowly, not enough to even register as a loss on the dipstick but just enough to make a damp stain on the supercharger. Maybe a few drops every oil change.
Check here for upgraded bearing rebuild kits
Also, what is the reason for rebuild? Bearings start getting noisy?
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
86gt? (01-18-2016)
Old 01-15-2016, 02:49 PM   #5
whataboutbob
AutoX-10/10ths every run
http://jonbondperformance.com/index....products_id=10
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
86gt? (01-18-2016)
Old 01-15-2016, 03:11 PM   #6
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
i used bearings and seals from 928motorsports for my v9 back when i had my GTI. no problems with installation or fitment. i ditched the blower not long after i rebuilt it in favor of a turbo setup. too many issues with vortech units leaking
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
86gt? (01-18-2016)
Old 01-18-2016, 03:42 PM   #7
86gt?
86gt?'s Avatar
Drives: asphalt 86
I lost a few psi of boost all of a sudden. I checked the supercharger oil and it was discoloured, I drained it and found a few chunks of bearing. If it weren't for my boost gauge I may not have caught it in time before more serious damage occurred since it was on the high speed side and there was a bit of play on the impeller shaft. I had just raised my rev limiter slightly and I am using the smaller 12psi pulley so I assume it was just too may revolutions for the stock bearings to handle.
I have researched many options and overall "superchargerrebuild" seems to have the best reviews they also sell on ebay incase anyone else runs into this same issue and wants to save themselves the the headache. http://www.ebay.ca/itm/VORTECH-Super..._qi=RTM2247626
I have read about many people sourcing the same or comparable bearings and seals for dirt cheap at local shops but I don't care to risk having to rebuild it again because a seal wasn't quite to spec.
Thanks for for the links, much appreciated! I will post an update as to whether my rebuild is successful or a catastrophic failure
The Following User Says Thank You to 86gt? For This Useful Post:
whataboutbob (01-18-2016)
Old 03-28-2016, 03:33 PM   #8
SDP
Drives: 2015 BRZ Limited
Can I get the SKF bearings part numbers please so I only need to tear my down once. These bearings can be purchased very cheap from MSC, Grainger or Kamand if you have the bearing number.
SDP is offline   Reply With Quote
'13 Subaru BRZ rebuild P3tras Member's Car Journals 96 01-03-2016 06:05 PM
2jz or fa20 rebuild? 2015FRShalo Northern California 24 12-17-2015 01:07 AM
BRZ Rebuild (Mulekr1) mulekr1 Member's Car Journals 3 11-15-2015 10:53 AM
Looking to rebuild a Scion FRS miller.4311 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 06-24-2015 06:47 PM
Supra rebuild or new frs/brz/86 Kylefujiicaelian FR-S / BRZ vs.... 29 12-31-2014 06:12 PM
