Old 03-27-2016, 09:56 PM   #4593
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Originally Posted by cjd View Post
Is the ST softer than stock? Typically a stiffer rear swaybar brings oversteer, and a stiffer front is more under steer... All things being equal and glossing over details... I'd not be surprised if you simply felt more confident and overdrove (front sway can definitely improve confidence.) Weird.
Typically. But these cars are MacPherson in the front, and will also roll a fair amount. There's an increased tendency to understeer, but you're also increasing the maximum grip up front by taming that roll and keeping your tires where they're supposed to be. The front camber curve leaves something to be desired. Depending on your driving style, ie: if you don't come into turns too hot, you may not notice a major change in the tendency to understeer, but you may notice an increased amount of maximum grip.
jawn is offline
Old 03-27-2016, 10:37 PM   #4594
cjd
cjd's Avatar
Drives: 2017 BRZ
Hah. I guess I assume a proper camber setting for the car... I was wondering whether to remove my swaybars today.
cjd is offline
The Following User Says Thank You to cjd For This Useful Post:
jawn (03-27-2016)
Old 03-27-2016, 10:46 PM   #4595
@Captain Snooze did it along with installing some top shelf dampers fitted with significantly higher rate springs. He loved it.
Ultramaroon is offline
jawn (03-27-2016)
Old 03-27-2016, 11:02 PM   #4596
jawn
jawn's Avatar
There's more than one way to skin a cat.
jawn is offline
Old 03-27-2016, 11:11 PM   #4597
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
There are pros & cons in removing a sway bar. Some swears that, it drive better without sway bar. Some say it drives better w sway bar.
Tbh, it's your preference. There's not exact answer for this. Test both & sweet how it goes.
ichitaka05 is offline
Old 03-27-2016, 11:19 PM   #4598
It sticks in my head because I would love to try it someday. It's waaaay down the road for me but when I do start messing with the suspension, It'll be along those lines.
Old 03-28-2016, 01:47 AM   #4599
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
He also went back to his previous dampers with 6k/6k springs and kept the sway bars off. He noticed more roll but much preferred the independent suspension operation. Having said that he had the Eibach sways on f&r which are quite stiff.
Because compromise.
Captain Snooze is offline
Old 03-28-2016, 01:48 AM   #4600
Captain Snooze
Drives: Red Herring
There's more than one way to shave a pu$$y.
Old 03-28-2016, 01:49 AM   #4601
Captain Snooze
Drives: Red Herring
At first read I thinking you wanted to skin a cat.
Ultramaroon (03-28-2016)
Old 03-28-2016, 01:54 AM   #4602
Because compromise.
He had them on previously, or is he running them now?
Old 03-28-2016, 02:23 AM   #4603
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
I know I shouldn't complain and whine because at least I have a job that pays decently but...
Think I'm slowly becoming saddened by the fact that due to how schedule is set up, I'm missing out on a lot of auto-x and regular drives that gets set up. Just a lot of the social outings, I have to say no due to work. ughhhh..
Work/life balance sucks.
The Twins make me smile
soulreapersteve is offline
Old 03-28-2016, 03:54 AM   #4604
Captain Snooze
Drives: Red Herring
Old 03-28-2016, 03:56 AM   #4605
Captain Snooze
Drives: Red Herring
Have a job and have the money but not the time or don't have a job and have the time but not the money.
Because compromise.
soulreapersteve (03-28-2016)
Old 03-28-2016, 06:40 AM   #4606
p1l0t
p1l0t's Avatar
Because compromise.
The time and the money..
The money and the power..
Minute after minute..
Hour after hour..
I'm 23 now but will I live to see 24?
The way things are going IDK...
Tell me why are we..
So blind to see..
The ones we hurt..
Are youuuu and me?
p1l0t is offline
Sarlacc (03-28-2016)
