Old 03-26-2016, 02:27 PM   #4537
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Ok, so I thought I did my research on this but apparently not enough? Is this really true?
- Question posted: "I was talking to a tech at my work and he said engine braking can increase oil blow by in the motor by a lot...true or false"
- One of the replies:
Now, I engine brake all the time (along with using my actual brakes, of course). Mostly because I want to hear the exhaust while coming to a stop.
The Twins make me smile
soulreapersteve is offline
Old 03-26-2016, 02:39 PM   #4538
True but exaggerated a bit. Maybe a bigger issue in race cars but still nothing to worry about. If this was the case then you would have oil blow by every single time you took your foot off the gas. The way that is written it sounds like you create a vacuum that suck the oil out but the engine is designed to for both acceleration and deceleration so the statement is a bit extreme. Because I drove truck for so long I always gear down and engine brake and have never had an oil issue with cars that had 400K on them. Don't sweat it.
Tcoat is offline
MrFisty (03-26-2016), soulreapersteve (03-26-2016)
Old 03-26-2016, 02:45 PM   #4539
soulreapersteve
Sweet! Thanks for the knowledge!
Glad I found the forum before finding that fb group. I honestly don't know why I'm still a part of it.
Old 03-26-2016, 02:47 PM   #4540
Ashikabi
Ashikabi's Avatar
Sounds plausible. I'd like to hear more too
Ashikabi is offline
Old 03-26-2016, 02:52 PM   #4541
Ashikabi
Ashikabi's Avatar
It sounds like it should suck oil into the cylinder, not increase crank case pressure. I don't see a catch can helping but it seems like you could potentially foul your o2 sensor. I dunno, probably not an issue unless your rings are shot
Ashikabi is offline
Old 03-26-2016, 03:06 PM   #4542
p1l0t
p1l0t's Avatar
A BRZ with a Jake Brake... Thanks suckers, I just found my next mod!
p1l0t is offline
The Following 3 Users Say Thank You to p1l0t For This Useful Post:
Dadhawk (03-26-2016), soulreapersteve (03-27-2016), Tcoat (03-26-2016)
Old 03-26-2016, 03:13 PM   #4543
totaled
Ultramaroon is offline
p1l0t (03-26-2016), soulreapersteve (03-27-2016)
Old 03-26-2016, 04:00 PM   #4544
Just think of the cool noise!
Tcoat is offline
p1l0t (03-26-2016)
Old 03-26-2016, 04:05 PM   #4545
Ya if you are getting that much oil past everything meant to keep oil where it is supposed to be then engine braking is probably the least of your problems.
Tcoat is offline
Ultramaroon (03-26-2016)
Old 03-26-2016, 04:22 PM   #4546
p1l0t
p1l0t's Avatar
Just remember brake pads are what? $20 $60? A new engine is like $5k sooo unless it's life or death just use your brakes!
p1l0t is offline
Old 03-26-2016, 04:47 PM   #4547
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
So I recently discovered a fair amount of blow by on my breather tube. I dont engine break but I do downshift sometimes when slowing and do a fair amount of hard driving mostly using partial throttle. Discussing it with guys that know more they said driving partial throttle causes more blow by then full throttle.
Basically if you can see oil residue on your breather tube (small line branching off just before the throttle body) then you could benefit from a catch can. Still figuring out if mounting it to the PCV is better (I think it will help more but need to do more research)
finch1750 is offline
Old 03-26-2016, 04:48 PM   #4548
p1l0t
p1l0t's Avatar
All cars become FI eventually anyway...
It's the CIRCLE OF LIFE...
p1l0t is offline
Old 03-26-2016, 06:52 PM   #4549
Ashikabi
Ashikabi's Avatar
Do both.
Ashikabi is offline
Old 03-26-2016, 07:28 PM   #4550
Teseo
Drives: frs
Red line the engine, the heat will clean the junk
Teseo is offline
The Following User Says Thank You to Teseo For This Useful Post:
finch1750 (03-26-2016)
