Old 03-25-2016, 09:48 PM   #1
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Transmission won't engage any gears.. Diff/Axle is done.
Having issues, hopefully someone with more knowledge than me can comment. Was in 2nd gear, drug it out to like 5500rpm. Shifted to 3rd and as I engaged 3rd I lost all my gears. I can let the clutch pedal out in any gear and it won't grab, doesn't sound like slipping at all. Had myself towed back to my house by someone and in neutral, as I was being drug, I heard a metal grinding noise.
I don't know if it's the clutch or pressure plate or the trans all together or what is it, where would I start to try and diagnose this?
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 03-25-2016, 09:48 PM   #2
Rifle
Rifle's Avatar
@Tcoat @jawn ?
295WHP/220TQ
Old 03-25-2016, 09:54 PM   #3
Originally Posted by Rifle View Post
Blew your clutch and/or TOB. Little to no doubt. Just pick up new ones and slap them in there.
jawn (03-25-2016), MisterSheep (03-29-2016)
Old 03-25-2016, 09:56 PM   #4
None of the gears? Not even fifth? Fifth gear couples the input shaft directly to the output. If that doesn't hook up it's either the clutch, or your diff.
jawn (03-25-2016), Sarlacc (03-25-2016)
Old 03-25-2016, 10:01 PM   #5
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Generally speaking, if the pressure plate is bad, your clutch won't fully disengage. If you can shift into gear with the car off, but not with the car on - the pressure plate is likely toast.
This doesn't sound like that. Have you checked for leaks with the slave cylinder?
If I understand your problem correctly - the clutch is not engaging, so the car never goes into gear? Does the clutch pedal have a normal amount of resistance? Can you press the pedal and have a buddy see if anything's leaking under the hood?
There's also a possibility of the center of the clutch failing, which could result in this sort of behavior. The linkages and throwout bearing could also do this, but it would have to be something kind of bizarre on a car this new.
jawn is offline   Reply With Quote
Old 03-25-2016, 10:08 PM   #6
Rifle
Rifle's Avatar
No leaks, I can tell you that. Normal pedal resistance. I'm about to head home now to see if I can get it to engage with it off.
295WHP/220TQ
The Following User Says Thank You to Rifle For This Useful Post:
Old 03-25-2016, 10:10 PM   #7
jawn
jawn's Avatar
I'm leaning towards clutch/throw-out bearing, if I had to guess.
The Following User Says Thank You to jawn For This Useful Post:
Old 03-25-2016, 10:15 PM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Clutch is toast. My sister's 2009 Si had the same exact problem. Throw out bearing and one of the springs on the clutch broke out.
The Following User Says Thank You to Mr.ac For This Useful Post:
Old 03-25-2016, 10:49 PM   #9
Rifle
Rifle's Avatar
So I put the rear wheels in the air, to see if the axle would spin. And it does.
So it could be the diff or axle.
295WHP/220TQ
Old 03-25-2016, 11:07 PM   #10
Ugh.
Old 03-25-2016, 11:12 PM   #11
jawn
jawn's Avatar
In gear?
Old 03-25-2016, 11:15 PM   #12
DAEMANO
Time Traveller
Wiggle the axle, if it clunks around, then the CV joint in th axle is toast. A replacement OEM axle $400. Used ones can be found all day on eBay for $100-$175.
The Following User Says Thank You to DAEMANO For This Useful Post:
Rifle (03-25-2016)
Old 03-25-2016, 11:37 PM   #13
Rifle
Rifle's Avatar
In gear?
Yes. so it engages the clutch but won't spin the wheels. So it's either the diff or axles. Gotta check them in the morning. Too dark now.
295WHP/220TQ
Dream20b (03-27-2016)
Old 03-25-2016, 11:37 PM   #14
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
See if it will buff out lst. (Stock answer)
If not, on a 2016, surely a warranty claim...Talk with your service writer very nicely. If they say no, gradually get more insistent. Even if it was your fault, still a warranty claim...unless of course you've done major mods to the power train already.
Oh, I see now, looking at your posts....seems you've added something under the hood of the car....well, still worth a try for warranty.
Edit: Sorry this happened, but see here: http://www.ft86club.com/forums/showt...09#post2596609
And by morning you'll figure out what's the weakest link.
ToySub1946 is offline   Reply With Quote
Stiff to engage 1st/reverse from a stop after clutch install mhiscott Engine, Exhaust, Transmission 94 07-19-2020 08:11 PM
Automatic transmission hard parking engage and disengage nos145 Issues | Warranty | Recalls / TSB 21 09-18-2015 08:30 PM
Automatic Transmission Kick/Choke when shifting gears Tech Gremlin Engine, Exhaust, Transmission 13 06-16-2015 02:54 AM
clutch won't fully engage/8000 miles small dent stockscionfrs Scion FR-S / Toyota 86 GT86 General Forum 2 10-14-2014 12:06 PM
Anybody change rear gears or trans gears yet? ramosryan Scion FR-S / Toyota 86 GT86 General Forum 2 06-13-2014 01:48 AM
