, dpfarr
Old 03-24-2016, 04:34 PM   #1065
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Originally Posted by Nitro22 View Post
Also don't forget to allow the EcuTek software to do an update. The ProECURomFiles Folder will populate with OE calibrations typically after the first update. (At least that's how mine behaved)
I downloaded the software and yes...it did update and populated with Mazda and Subaru files...
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 03-24-2016, 05:30 PM   #1066
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Does anyone else get blower surge? Or whatever you care to call it. My idle hunts around a lot.
Luftwaffel is offline   Reply With Quote
Old 03-24-2016, 06:17 PM   #1067
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I was having issues so bad on my delicious flex tune, that the rpm would jump around by 2.5k rpm whenever we rolled to a stop. it would also die like every other time. I was updated with a newer tune. But now we are having a real hard time during cold start up. it takes like 4-5 times to turn over and when it does stay on, it sounds like it ants to die. I don't know if I got something wrong or not. Hopefully the logs can tell.
[ame="https://www.youtube.com/watch?v=Qe_aWf2fZ4o"]March 23, 2016 - YouTube[/ame]
srry my cam is messed up so it shakes a lot
[ame="https://www.youtube.com/watch?v=W90znZz27fU"]March 21, 2016 - YouTube[/ame]
clayrush is offline   Reply With Quote
Old 03-24-2016, 09:11 PM   #1068
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Hmmm maybe I'll just hold off on the E85/Flexfuel and aftermarket tune for now...
The Following User Says Thank You to BigFatFlip For This Useful Post:
clayrush (03-24-2016)
Old 03-24-2016, 09:32 PM   #1069
clayrush
They said I am the only one with the issue that they know of. Before my charger the flex was fine even when it got freezing out. They are working with me and my shop is assisting to see what my issue is. It just sucks on top of my clutch problems.
Old 03-24-2016, 10:39 PM   #1070
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
l]
Mine dose that all the time, even after it's warm. It gets real annoying stalling at intersections. I have sent Zach at Delicious Tune logs and he keeps saying vacuum leak. I have had 3 different technicians check my engine including close to 6 hours on a smoke machine. At 1st we found loose hoses, missing clamps, but now nothing.
Plus I keep getting a P0068 MAP/MAF code. I have replaced both sensors with out any success. If you find the cause please let me know.
Lunatic is offline   Reply With Quote
Old 03-24-2016, 10:41 PM   #1071
Lunatic
Lunatic's Avatar
I don't know who "They" are but I have been fighting the same issues for 6 weeks now and I thought the whole world knew about my problems. I also had the delicious tune flex fuel kit installed.
Old 03-24-2016, 10:56 PM   #1072
clayrush
I'm sorry I was referring to the cold start issue as being only one.
I was originally having the same issue as you even when the car was fully warmed. When Bill was in the Bay Area I met up with him and he worked on the tune a little bit and converted me to a hybrid tune. He fixed the idle issues and it stopped dying when coming to a stop. But it was replaced with the cold start problem.
Old 03-24-2016, 11:00 PM   #1073
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Anyone have any issues on the CARB tune?
shiumai is offline   Reply With Quote
Old 03-24-2016, 11:39 PM   #1074
86fun
Drives: 2013 FRS
Yea, I've worked with Edelbrock on 11 versions of it, it's now drivable, but not smooth. Still has some hesitation and uneven/inconsistent power band. From what I hear my car is a fluke though. Apparently most people don't have any troubles at all.
86fun is offline   Reply With Quote
The Following User Says Thank You to 86fun For This Useful Post:
shiumai (03-25-2016)
Old 03-25-2016, 01:54 PM   #1075
j123ic
Drives: Evo 9
For those of you with idle / drivability issues, check your fuel injectors. They are directional and should only be installed at a fixed clocked position. There's a tab on the fuel rail that aligns with the fuel injector connectors.
If it's not clocked in the correct direction, the fuel spray will be facing the wrong direction and may hit the walls of the runner instead of the center of the valve.
j123ic is offline   Reply With Quote
The Following 3 Users Say Thank You to j123ic For This Useful Post:
clayrush (03-25-2016), Nitro22 (03-25-2016), strat61caster (03-25-2016)
Old 03-25-2016, 04:51 PM   #1076
paiceyfan
paiceyfan's Avatar
I have stock with Edelbrock and some idle hunting for 20 seconds after start-up, but that's all...no stalls and stable thereafter.
In normal driving from cold, I tend to have to give it a little extra gas, due to this dead zone effect people talk about, but once warm, it seems to drive normally. In fact, it does feel very stock until I really start getting the revs above 4.5k rpm or so.
The Following User Says Thank You to paiceyfan For This Useful Post:
CSG Mike (03-25-2016)
Old 03-25-2016, 05:20 PM   #1077
shiumai
shiumai's Avatar
i'm on the CARB tune also and what you said pretty much mirrors my experience. only a slight hesitation for the first couple of minutes from a cold start but no idle hunting, surging or stalling.
The Following User Says Thank You to shiumai For This Useful Post:
Old 03-25-2016, 05:57 PM   #1078
Luftwaffel
Boost Creep
Luftwaffel's Avatar
It's weird, after a bit of driving, the ECU learns out the stalling. It still hunts a little and dips low enough to kill DRLs for a minute though. I don't get it. Finished my gauge install though, so that's a win.
Lighting is WIP, don't judge yet.
The Following 6 Users Say Thank You to Luftwaffel For This Useful Post:
Alltezza (03-26-2016), clayrush (03-26-2016), CSG Mike (03-25-2016), MicheleAbbate (03-25-2016), NahumCC (03-25-2016), paiceyfan (03-25-2016)
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
