Old 03-24-2016, 04:19 PM   #4355
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by Tectoniic View Post
Sticking with the stock wheels and just gonna run the primacys into the ground. I thought you were supposed to avoid slip on spacers like the devil or did i get that backwards?
Avoid them unless you are using proper longer studs that are also stronger then OEM. There are low end bolt on spacers that you should avoid for safety reasons. They also add weight
go_a_way1 is offline
Old 03-24-2016, 04:21 PM   #4356
Ashikabi
Ashikabi's Avatar
I heard they were making new ones that actually reduce the weight of the wheel assembly
Ashikabi is offline
Old 03-24-2016, 04:22 PM   #4357
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Adding lightness eh?
Old 03-24-2016, 04:22 PM   #4358
HunterGreene
Hail Magnet
HunterGreene's Avatar
Have you tried a battery pack? They are pretty cheap now. Then you can charge in your pocket
I like the specials they run on Woot.
http://electronics.woot.com/plus/wea...f=el_cnt_wp_13
It has priests in it?
HunterGreene is offline
Old 03-24-2016, 04:23 PM   #4359
Ashikabi
Ashikabi's Avatar
Yup if you stack up about 10 of these you'll look like a tractor but gain about 15hp and insane throttle response
Ashikabi is offline
The Following User Says Thank You to Ashikabi For This Useful Post:
go_a_way1 (03-24-2016)
Old 03-24-2016, 04:25 PM   #4360
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Oh man I bet you back your sparkplugs out a touch with the lightness added you will hit 221WHP
Old 03-24-2016, 04:26 PM   #4361
Ashikabi
Ashikabi's Avatar
No man, that doesn't actually work. Totally bogus. These are the real deal though
Ashikabi is offline
Old 03-24-2016, 04:28 PM   #4362
Ashikabi
Ashikabi's Avatar
Say... where's your boyfriend at? Haven't seen him on today
Ashikabi is offline
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
go_a_way1 (03-24-2016), MisterSheep (03-24-2016)
Old 03-24-2016, 04:28 PM   #4363
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
In for updates
Old 03-24-2016, 04:28 PM   #4364
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Sheeps gona be gone for a bit.
Old 03-24-2016, 04:32 PM   #4365
Ashikabi
Ashikabi's Avatar
What'd he do this time
Ashikabi is offline
Old 03-24-2016, 04:32 PM   #4366
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
hahaha he didnt do anything, he is just taking a break
Old 03-24-2016, 04:33 PM   #4367
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
sheep better be getting his turbo going. i was gonna challenge him to a formal race to turbo our slow cars
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline
The Following 2 Users Say Thank You to Tectoniic For This Useful Post:
Old 03-24-2016, 04:33 PM   #4368
Ashikabi
Ashikabi's Avatar
I hate to break it to you... but he's posting memes with other people behind your back... this "break" is permanent...
Ashikabi is offline
