Old 03-24-2016, 04:39 PM   #1
Prmspen
Student Driver
Prmspen's Avatar
Drives: 2016 Subaru BRZ Limited
Problems With 2016 Head Unit
Hey Guys,
I took delivery of my 2016 Limited last week, and I'm loving it except for the head unit. I'm having problems connecting it to my iPhone 6. Bluetooth phone connection appears to be fine - I can make and receive calls. But I'm having real problems with Pandora and other apps. When I connect my iPhone via USB (as the manual tells you to) and select the Pandora app on the head unit, I get the white "Connecting" screen for several minutes, then I get an error message. When I use bluetooth audio as the input, I can play Pandora but the song and artist displayed stays the same as the first song - it doesn't update when I change songs or stations.
I notice that the manual doesn't list the iPhone 6 as a compatible device - it only goes up to iPhone 5, which seems strange since the iPhone 6 came out in 2014, and this head unit is new for the 2016 BRZ. I've talked to the dealer, and they're looking into it, but I don't have a lot of confidence in them finding a solution. Have any of you experienced something similar?
Prmspen is offline   Reply With Quote
Old 03-25-2016, 02:00 AM   #2
Welcome to ye ol forum...........
You may get a faster response by posting your question over here:
http://www.ft86club.com/forums/forumdisplay.php?f=27
Tcoat (03-25-2016)
Old 03-25-2016, 07:11 AM   #3
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
It works better with a Android.
I recommend just getting a 32GB slim flash drive and adding all the music you want.
Get dealer to check for update/flash.
Old 03-25-2016, 09:31 AM   #4
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
Drives: Series.Hyperblue BRZ
The 2016 does NOT connect iPHONE and PANDORA with bluetooth or USB. The only way to have them work together is with an AUX cable. This was told to be by the salesman when I purchased my car, and he admitted it's not a "issue", it's just how Subaru designed it.
hypebrz is offline   Reply With Quote
The Following User Says Thank You to hypebrz For This Useful Post:
humfrz (03-25-2016)
Old 03-26-2016, 07:13 AM   #5
ed_423
ed_423's Avatar
Drives: 2016 BRZ Limited
^ not true. my iphone connects to pandora via usb. it also shows spotify as well if you click on "usb" in the selection menu.
ed_423 is offline   Reply With Quote
Old 03-26-2016, 11:26 AM   #6
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Let me get this straight...Subaru specifically designed its infotainment system to be non-compatible with probably the most popular phone in the world?
Yeah, I'm sure that must be true.
billwot is offline   Reply With Quote
Old 03-26-2016, 03:33 PM   #7
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
It's not even close to the most popular phone in the world, probably only in America. Android has far higher sales and operating systems
Old 03-26-2016, 03:48 PM   #8
shagoth
Drives: ICE Silver 2016 BRZ
As bad as the head unit in the 2016 limited is, you'd think there was a dealer installed replacement that they wanted to sell. The unit is slow, the UI is terrible and the compatibility with iThings is dicey at best. It also uses a weird shaped faceplate so aftermarket replacement is more complicated.
Where is the $1500 replacement from the dealer that justifies shipping this big a piece from the factory?
shagoth is offline   Reply With Quote
Old 03-27-2016, 03:29 PM   #9
Prmspen
Student Driver
Prmspen's Avatar
Can you use the Pandora app on the head unit, or do you have to select USB as the audio source and play it through that?
Old 03-27-2016, 04:11 PM   #10
ed_423
ed_423's Avatar
the pandora app works on the headunit, as long as i connect the iphone via usb
Old 03-28-2016, 10:18 PM   #11
Prmspen
Student Driver
Prmspen's Avatar
Problem solved!
Turns out the input jack on my iPhone was full of lint and crud. Cleaned that out with a pin and now it works fine. I like easy fixes.
2016 BRZ Head Unit Wiring Harness TommyC Electronics | Audio | NAV | Infotainment 84 08-18-2017 01:05 AM
2016 BRZ Head unit replacement shagoth Electronics | Audio | NAV | Infotainment 28 03-24-2016 05:40 PM
Can I buy rear camera and head unit 2016 Mikeez Electronics | Audio | NAV | Infotainment 25 03-02-2016 11:23 AM
2016 FR-S Head Unit stock connections tk1138 Electronics | Audio | NAV | Infotainment 2 03-01-2016 07:47 PM
2015 BRZ Limited Head unit Problems Brzzee Electronics | Audio | NAV | Infotainment 8 11-13-2015 07:55 AM
