Old 03-11-2016, 05:44 AM   #267
wasupman2
wasupman2's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by khantran04 View Post
but isn't that why thwy cat their headers? I mean if there isn't a way to carb exempt them what's the point of having a cat that lowers performance and not passing smog check lol its quite absurd
Sent from my SM-N910T using Tapatalk
The catalytic converters that are included with aftermarket headers are usually high-flow cat converters. So you're not losing a substantial performance compared to a straight pipe and (at the same time) not polluting so much. Just having any catalytic converter instead of a test pipe really makes a big difference in reducing emissions, just unfortunate that those non-carb certified high flow cats doesn't meet the emission reduction requirements in California.
If not for the California Air Resource Board, it would be a total polluted burning hot place to live in SoCal.
wasupman2 is offline   Reply With Quote
The Following 2 Users Say Thank You to wasupman2 For This Useful Post:
DAEMANO (10-23-2017), WORKS (03-15-2016)
Old 03-11-2016, 12:51 PM   #268
kch
Senior Misanthrope
kch's Avatar
Not everyone lives in California. Many states do sniffer tests but don't care about CARB compliance. A catted header with a higher-flow cat would provide modest performance gains and still probably pass a sniffer test.
The Following User Says Thank You to kch For This Useful Post:
Kaotic Lazagna (03-11-2016)
Old 03-12-2016, 01:32 AM   #269
Bach415
Bach415's Avatar
Drives: Whiteout FRS
The kit runs on stock headers. It's the overpipe that is changed. Front pipe that contains the stock cat are still there. That's why it's CARB legal. Does not modify any cats. And it being CARB legal, when you run the carb legal map on stock exhaust parts (aside from the overpipe that was modified), you should still be able to pass smog. And a cat is there to make it pass smog. People remove cats to increase performance, but increasing performances means increasing emissions as well. CA does not want to go back to the smoggy state it used to be.
Bach415 is offline   Reply With Quote
The Following 3 Users Say Thank You to Bach415 For This Useful Post:
DAEMANO (10-23-2017), khantran04 (03-12-2016), WORKS (03-15-2016)
Old 03-21-2016, 06:57 PM   #270
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Our WORKS Stage 2 Turbo Kit equipped BRZ tuned for E85 competing in the Speed/Stop Challenge at the OPTIMA Ultimate Street Car - Thunderhill event. Enjoy.
[ame]http://youtu.be/NP9SGgJb5Sw[/ame]
WORKS is offline   Reply With Quote
The Following User Says Thank You to WORKS For This Useful Post:
GhostOp86 (03-21-2016)
Old 03-23-2016, 09:24 PM   #271
WORKS
WORKS's Avatar
Pre-tech inspection for our CARB Compliant Stage 2 customer's first track day with NASA.
GhostOp86 (03-23-2016)
Old 03-23-2016, 10:20 PM   #272
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Do you guys have something for the auto cars yet?
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
WORKS (03-31-2016)
Old 03-31-2016, 08:40 PM   #273
WORKS
WORKS's Avatar
The initial round of testing the oil drain was encouraging.
The Following 2 Users Say Thank You to WORKS For This Useful Post:
FRSBRZGT86FAN (03-31-2016), GhostOp86 (04-01-2016)
Old 03-31-2016, 08:42 PM   #274
WORKS
WORKS's Avatar
The white BRZ Stage 2 customer's first track day.
Old 04-05-2016, 05:49 PM   #275
WORKS
WORKS's Avatar
Nice views of our air-to-liquid intercooler radiator tucked behind the bumper from davidbushphoto.com.
BigFatFlip (04-05-2016)
Old 04-12-2016, 05:05 PM   #276
WORKS
WORKS's Avatar
218 whp on 91 at @Elite Performance.
https://www.instagram.com/p/BD4ZKCOASlg/
Old 04-16-2016, 10:31 AM   #277
ihmcguinness
Drives: 2016 Series.HyperBlue BRZ
Any update after further tuning?
ihmcguinness is offline   Reply With Quote
Old 04-16-2016, 01:21 PM   #278
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
218? Did the turbo fall off? I would expect atleast 240.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-19-2016, 05:06 PM   #279
Fred E
Drives: WRB BRZ
Just realized that I forgot to post my results after time on the dyno:
Again this is with a GTX2971R instead of the GT28 that the kit comes with, and at ~14 psi on ~E65. The whp vs vehicle speed plot of this same run actually shows the peak power at 361 whp and there were actually 3 different vaccum/boost leaks during this run that weren't found until later. I haven't been back on the dyno since then to see how the plot has changed, but it certainly feels even better with the leaks fixed. This is with the P&L catless header and a catted front pipe. I'm considering replacing the header with one that has shorter runners/piping to improve spool.
The 254whp run is final stage 1 results (with the GT28) on E65.
Fred E is offline   Reply With Quote
The Following 2 Users Say Thank You to Fred E For This Useful Post:
DocWalt (04-19-2016), WORKS (04-20-2016)
Old 04-19-2016, 06:33 PM   #280
ATaraxias
Drives: 1994 Geo Metro Hatchback
This WORKS stg2 kit hit the dyno at a blazing 202 WHP...
http://www.ft86club.com/forums/attac...1&d=1457659699
ATaraxias is offline   Reply With Quote
P&L Motorsports Stage 1 Turbo Kit Build Thread P&L Motorsports Forced Induction 31 10-25-2017 04:26 AM
WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 230 08-11-2016 06:01 PM
Stage 2 Cosworth Kit Preview!!!! Titanmotorsports Forced Induction 377 04-01-2015 07:29 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer - Over $800 Discount! WORKS Forced Induction 107 11-22-2014 12:15 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer WORKS Northern California 31 11-11-2014 07:24 PM
