#57 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | go_a_way1 (03-23-2016) |
#58 |
Drives:
Hence why I said it was an apples to oranges comparison. I'm by no means an expert, but with the information I have, the car only drove oddly and had bad alignment numbers with the Teins on. Without the Teins and with any other combination the car was fine. It could be great if I can find something else that can prove it isn't the coilovers' problem, as that means there are more damage found that needed to be repaired, but as of right now there is nothing else found lately.
#59 | |
#61 |
Drives:
Wouldn't it be possible that Tein never manufactured this particular set properly and as a result the coilovers had mismatch build specs?
#62 |
#63 |
Does OP have a friend, they could trade coils for a bit and see what happens
#64 |
Drives: 2014 Monogram FR-S Whiteout
My unit constantly sends me to AZ so if this is still ongoing next time I am there, I can definitely offer up my car to see if I have the same issue with the Flex Z's. But that may be a ways away...
#65 | |
Drives:
I wish I can and have the time and money to do so, but I don't. |
#66 |
Drives: GR Corolla
Could be just an isolated problem? I just installed my Flex Z about a week ago, along with Whiteline rear LCA. Car drove straight after the installation, but I knew my alignment was off since my steering wheel wasn't centered.
![]() Car feels smoother than stock (7 clicks back of full stiff), and I pretty much maxed out the drop in the front. Had to reduce the rear via pre-load to even out the drop since the shock length was still about 3/4" too high at max adjustment. Oddly enough, the click/clank/creak that I had with stock went away after I installed the Flex Z. |
| The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post: | CSG Mike (03-23-2016), shattered_memory (04-03-2016) |
#67 |
Drives: Subaru BRZ Limited
I had a similar problem to the OP when I added camber bolts to stock suspension on a RHD GT86 which had never been in an accident. The factory fixed castor is setup to slowly drift away from oncoming traffic (in my case the left) and this seemed to be exaggerated when 1 degree of negative camber was dialed in.
Toe was neutral. When I took the camber bolts out to sell the car the problem went away. On my BRZ over here in the states I plan on running a racer x LCA for full camber/caster adjustment along with a camber bolt and will use OEM strut tops rather than camber plates. Sent from my iPhone using Tapatalk |
#68 | ||
Drives:
On a side note, there were a lot of more noises coming from the front end after installation of the Teins, but they were mostly related to the sway bar endlinks. The ride was bouncy I believe 12 clicks from stiff, and after driving extended periods on 9(?) clicks from stiff the dampers felt less effective. Car also felt to have a lot more body roll after the Teins were placed on, but that could be an alignment issue. There was also a consistent clicking near the right rear area going over bumps after the install of Teins. I am by no means dismissing Tein in this issue and just ask for a refund at their expense, but it seems like they just sold me a defective product and refuse to deal with it under any circumstances. If they are willing to ship me another pair while taking back the current set I'd be happy to put another set on and retest everything. Quote:
#69 |
Drives: GR Corolla
When you had the alignment done with the Flex Z on, were they able to get the alignment back to factory specs (sorry if you answered this already). Fortunately for me, I think the tech that did my alignment has OCD since he tried his best to get every spec the same for both sides.
#70 | |
Drives:
| Sway Bar Creaking | smg1138 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 11-16-2015 01:28 PM |
| Creaking during turning after coilovers? | Rifle | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 11-10-2015 12:51 PM |
| Bc racing v1 coilovers (track spec edition) knocking sounds | Tsumari | Brakes, Suspension, Chassis | 3 | 08-06-2014 07:44 PM |
| Seats creaking | Wes | Issues | Warranty | Recalls / TSB | 28 | 06-15-2014 06:19 PM |
| BEST of Start Up sounds!! More than 70 Exhaust Sounds! | JPxM0Dz | Other Vehicles & General Automotive Discussions | 5 | 01-08-2014 02:24 PM |
