Old 03-23-2016, 01:20 AM   #1
Ehokana
Drives: 2016 FRS
Trunk Won't Open with Either Key Fob or Dash Trunk Release
Hey Guys- I was cleaning the car this evening and, after finishing up, went to put a couple of things in the trunk. I can't seem to get the trunk to open using either the key fob or the button on the dash. All other electrical seems to be functioning perfectly fine, with the single exception.
Has anyone else had this problem, or a fix? Figured I would ask here before trying to deal with the dealer. Thanks in advance
Ehokana is offline   Reply With Quote
Old 03-23-2016, 01:24 AM   #2
disable button is on the left side inside the trunk. stuff hits it.
go_a_way1 (03-23-2016), PNW-BRZ (02-09-2017), whataboutbob (03-23-2016)
Old 03-23-2016, 01:35 AM   #3
Ehokana
Drives: 2016 FRS
Wow... I did not even think of that, and that is a tad embarrassing. Guess the blatantly obvious sometimes gets overlooked
Thanks a ton
Old 03-23-2016, 01:46 AM   #4
Kaotic Lazagna
Drives: GR Corolla
If that button also gets disconnected somehow, you won't be able to electronically open the trunk either.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
mixtape (03-23-2016)
Old 03-23-2016, 08:13 AM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
@MisterSheep your not alone
Old 03-23-2016, 08:55 AM   #6
Ashikabi
Ashikabi's Avatar
You can pull the trim off the top pc the seat where the round posts are and pull those parts up, this will unlock back seat, then you can hit the button
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 03-23-2016, 09:22 AM   #7
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
I actually did that when I pulled back the trunk liner to put in my taillights. I forgot to plug it back in and thought I had a dead battery when I came back to my car with groceries later that day lol
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
The Following 2 Users Say Thank You to mixtape For This Useful Post:
go_a_way1 (03-23-2016), Kaotic Lazagna (03-23-2016)
Old 03-23-2016, 09:26 AM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
or you know.... just use the key in the key slot on the trunk thats up by the license plate bulbs
Old 03-23-2016, 09:28 AM   #9
Ashikabi
Ashikabi's Avatar
Mine doesn't work. So maybe his doesn't either
Old 03-23-2016, 09:29 AM   #10
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
haha what did you do to yours?
Old 03-23-2016, 09:53 AM   #11
Ashikabi
Ashikabi's Avatar
No master key. Valet key doesn't open the trunk
Old 03-23-2016, 10:05 AM   #12
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
I didnt even know we had a valet key I wonder what one I have always been using
Old 03-23-2016, 10:10 AM   #13
Ashikabi
Ashikabi's Avatar
If it has the keyless entry it's the master key. If it's just gray with no buttons it's valet
Old 03-23-2016, 10:22 AM   #14
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
ahhhhhh I think I had one but they used it with the remote start install. I only got 2 normal keys now
Scjacob827 (12-12-2019)
Trunk release failure - BRZ Smilez CANADA 35 07-15-2019 10:15 PM
Trunk Release Not Working FRSNewb Issues | Warranty | Recalls / TSB 22 09-05-2014 03:47 PM
Trunk won't release! ThaBigUnit Scion FR-S / Toyota 86 GT86 General Forum 16 12-28-2013 07:23 PM
trunk release quit working regal Issues | Warranty | Recalls / TSB 4 04-20-2013 10:41 AM
Broken Trunk Release? Craig Issues | Warranty | Recalls / TSB 18 03-14-2013 07:21 AM
