Old 03-23-2016, 07:41 AM   #15
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I originally bought xxr's for my car as an impulse buy. The stocks are SO UGLY! Had them for less than 6 months. Then I bought RPF1s.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 03-23-2016, 09:33 AM   #16
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
I'm seeing lots of guys in the same boat and I'm one of them. I went with 17x8.25 XXR with 225/45 tires not long after purchase. the wheels are 20+lbs. Now this spring I am switching to 17x7.5 PF01 at 16lbs and going back to 215/45 tires. I honestly dont know if it was the weight or the tire specs but something didn't feel quite right.
I should be saving close to 6-8lbs a wheel since im getting lighter tires as well. Ill report back on the results.
headlikeahole is offline   Reply With Quote
Old 03-23-2016, 09:39 AM   #17
speeddemon
Drives: Scion frs
Yeah, thanks for the input. I see I have two choices: I get much better tires for my current XXR's like MPSS's or I go with Enkei PF01's still in 18" but much lighter....Either way its costing me money but I didn't buy this car to be unhappy with handling..
speeddemon is offline   Reply With Quote
Old 03-23-2016, 09:45 AM   #18
chc36
Drives: 2013 FR-S Ultramarine
Originally Posted by speeddemon View Post
Is it worth trying the brand new set of 225/40r18 Pirellis I have? I don't think they could be any worse? Or should I shell out the money for MPSS or go with an entirely new setup all together.
I actually just put a set of 225/40/18 Pirelli P-Zero Nero's on yesterday, I'm running fairly heavy wheels (23.5 lbs) but I love the feel currently.
chc36 is offline   Reply With Quote
Old 03-23-2016, 09:50 AM   #19
speeddemon
Drives: Scion frs
Better than stock?
Old 03-23-2016, 09:52 AM   #20
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I don't actually think it is the HTRZ III tires here. I think its a combination of the change in offset and move to heavier wheels with wider tires.
The HTRZ III is actually a pretty good tire, I've used it several times and have never thought the sidewall was soft.
The Following 3 Users Say Thank You to Summerwolf For This Useful Post:
brandonblt2 (03-23-2016), Pat (03-23-2016), speeddemon (03-23-2016)
Old 03-23-2016, 09:56 AM   #21
speeddemon
Drives: Scion frs
Heavy wheel regret
I'm thinking about Enkei PF01 18x7.5 +38 with Pirellis. What do you think about that in improving my situation? the stock offset I believe is 48 so the farther you move from this the worse the feel will be? is 38 too far?
Old 03-23-2016, 09:57 AM   #22
Dougboy
Dougboy's Avatar
Drives: acura tsx
I dont think wheel weight is the issue here. I had an XXR527 18x8.75 on a scale and it was around 21.5 lbs. A similarly sized RPF1 (18x9.5) is listed as 18.5 lbs on tirerack. Majority of FT86 drivers wont be able to feel a 3lb difference driving around on the streets.
What sumitomos are you running? Ive also ran HTRZ3's in 18's. While relatively soft compared to better max performance tires like a Z2 or RS3, its still significantly more rigid than stock primacy's in 17's
Edit**
It just wobbles all over the place its driving me nuts
After looking back at your concern, could it possibly be a wider tire which will track steer annoyingly with the grooves and curves in the road, giving you the impression that its wobbling around? Even the most garbage triangle tire would not have its sidewalls "wobble"
Dougboy is offline   Reply With Quote
The Following 2 Users Say Thank You to Dougboy For This Useful Post:
speeddemon (03-23-2016), Summerwolf (03-23-2016)
Old 03-23-2016, 09:57 AM   #23
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Reviews may be your best bet to figure out sidewall stiffness.
I run Bridgestone S-04's on my BRZ. The first time I had a set mounted, it took about 4 shops to find one that could actually mount them.
JazzleSAURUS is offline   Reply With Quote
Old 03-23-2016, 10:04 AM   #24
Summerwolf
Panda Trueno
Summerwolf's Avatar
http://www.ft86club.com/forums/showthread.php?t=45554
OP, I'd start going through this thread.
The Following User Says Thank You to Summerwolf For This Useful Post:
Old 03-23-2016, 10:07 AM   #25
speeddemon
Drives: Scion frs
235/40R-18 SUMITOMO HTR A/S P02. I either get lighter wheels or better tires.....
Old 03-23-2016, 10:11 AM   #26
Summerwolf
Panda Trueno
Summerwolf's Avatar
HTR A/S P02..... definitely not the same tire as the HTRZ III I think most of us were under the assumption you were running.
http://www.ls1gto.com/forums/archive.../t-326858.html
I actually found a review I did on the Z III. May be worth looking in to different tires, lol. The A/S is just a normal all season. I would put that on my beater car in a heartbeat, but not the BRZ.
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
brandonblt2 (03-23-2016), speeddemon (03-23-2016)
Old 03-23-2016, 10:17 AM   #27
chc36
Better than stock?
It's been a while since I had stock tires on (had winter's on since November - actually they did the same thing that you are describing; a bit squirrelly at higher speeds, feel like your floating and don't have much control) so I can't really say for certain if its better than stock but I do feel like it is a lot tighter and I have more control - especially after running winters.
Old 03-23-2016, 10:21 AM   #28
8R6
8R6's Avatar
Drives: FRS
xxr are shitty wheels, but those all-season sumitomos are the real shitty problem you're experiencing. you can keep the xxr's and just upgrade to better tires, and that alone will make the driving experience way better (back to stock lol) again
8R6 is offline   Reply With Quote
JDM Wheel Sale - Volk Racing, Advan, Gram Lights, Forged and heavy discounts Gruppe-s Wheels and Tires 10 05-05-2016 07:10 PM
Anyone regret getting MT? Almighty Bob Cars for Sale/Trade 39 03-24-2013 02:58 AM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 04:52 AM
Regret it or not? Bangduk Scion FR-S / Toyota 86 GT86 General Forum 83 08-03-2012 07:16 PM
What is a heavy or light wheel? DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 07-26-2012 03:01 AM
