Old 06-15-2012, 01:12 AM   #1
wrxneffect
wrxneffect's Avatar
Drives: 13 BRZ Ltd 6MT(sold), 03 WRX (RIP)
Torque spec for lug nuts
Is the torque spec for the lug nuts really 89 ft-lbs?
wrxneffect is offline   Reply With Quote
Old 06-15-2012, 01:43 AM   #2
Fly Guy
Fly Guy's Avatar
Drives: '91 MR2
That's what's in the manual:
Tada-san: Oh so cooler than the concept.
Fly Guy is offline   Reply With Quote
The Following 7 Users Say Thank You to Fly Guy For This Useful Post:
autobrz (01-14-2014), flippy (10-10-2012), hmong337 (11-05-2014), lordtakuban (06-15-2012), MarkRacerX (06-15-2012), tigermack (11-05-2014), Tristor (04-16-2018)
Old 06-15-2012, 01:56 AM   #3
Fish
Fish's Avatar
Drives: 2015 Yuzu RS1.0 Scion FR-S #893
It sounds right to me being that they use the metric system. It's the same for me at work. Wheels get torqued to around 120Nm depending on the vehicle.
Fish is offline   Reply With Quote
Old 06-15-2012, 02:31 AM   #4
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
general rule is about 90ftlbs. Most people overtighten the crap out of their wheel nuts. You shouldnt have to labour like mad to get them off.
spiller is offline   Reply With Quote
Old 06-15-2012, 04:35 AM   #5
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Pretty much every other Toyota model (save for M14 models like Tundra, Sequoia and Land Cruiser), use 76ft-lbs, but the FR-S uses Subaru studs with a finer thread pitch. 89ft-lbs is correct, as was mentioned.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following 3 Users Say Thank You to Jeff Lange For This Useful Post:
impossible (10-26-2016), Tristor (04-16-2018), USMC -FRS (02-11-2013)
Old 06-15-2012, 04:39 PM   #6
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
As a general rule I torque the lug nuts on all of my cars to 90 ft-lbs, been doing so for around 20 years, no problems.
Miniata is offline   Reply With Quote
The Following User Says Thank You to Miniata For This Useful Post:
Old 06-15-2012, 04:55 PM   #7
#87
I usually post drunk
#87's Avatar
Don't worry if you service at the dealer you will get at least 200 ft/lb. More is better right?
#87 is offline   Reply With Quote
The Following 14 Users Say Thank You to #87 For This Useful Post:
8R6 (11-04-2014), Black Tire (11-04-2014), CatDaddysBBQ (09-07-2016), churchx (01-10-2020), Impureclient (06-27-2016), limitedblkwrx (07-26-2014), lupindub (05-18-2016), ndsleep612 (01-10-2015), re-animator (09-11-2018), Silky (03-17-2018), SkAsphalt (03-30-2015), tigermack (11-05-2014), Tristor (04-16-2018), wparsons (03-04-2014)
Old 06-15-2012, 05:01 PM   #8
FakeWhiteMan
Back From The Dead
Drives: Hot Lava FR-S
Send a message via AIM to FakeWhiteMan
They would think
FakeWhiteMan is offline   Reply With Quote
Old 06-15-2012, 05:35 PM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I usually do 85.. I guess I'll switch that to 90 :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-15-2012, 06:18 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I have been an 85 ft/lb guy for awhile. I know when working at a local tire and lube place that most cars were either 100 or 85 ft/lb with a few less than that such as Hondas I believe. Most trucks were also in that 100 ft/lb area except for the heavier duty trucks with thicker studs that went up to 140 ft/lb I believe.
Old 10-03-2012, 03:17 PM   #11
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Would the torque spec for aftermarket lug nuts and aftermarket wheels also be 89 ft-lbs. I ask because I have some mcgard lug nuts and volks, and when removing the lug nuts after they have been torqued to 89 ft-lbs they squeal and make a lot of noise.
These nuts use a key/spline driver, so maybe that is increasing torque beyond 89 ft-lbs...I'm not sure.
But in short...would 89 ft-lbs apply to any wheels/lug nuts? And is that squealing noise normal? (It doesn't happen for me with the stock wheels/lug nuts.)
Phaedrus29 is offline   Reply With Quote
Old 10-03-2012, 04:04 PM   #12
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Aftermarket lug nuts have different specs, so just make sure you go by that if you are not using stock lugs.
No Limit Motorsport is offline   Reply With Quote
Old 10-03-2012, 08:19 PM   #13
Phaedrus29
Phaedrus29's Avatar
These are the lugs/locks I'm using, McGard SplineDrive 65554BK:
[ame="http://www.amazon.com/McGard-65554BK-Chrome-SplineDrive-Installation/dp/B0006HOVNE/ref=sr_1_1?ie=UTF8&qid=1349306169&sr=8-1&keywords=mcgard+65554BK"]McGard 65554BK Chrome/Black SplineDrive Wheel Installation Kit (M12 x 1.25 Thread Size) - For 5 Lug Wheels : Amazon.com : Automotive[/ame]
On the McGard website for just general installation instructions, it says: "Tighten lug nuts in a progressive crisscross pattern to the recommended installation torque found in your vehicle owner's manual." And "Using the McGard key and a wrench, tighten each lock to the torque specified in your vehicle owner's manual."
So this seems to be saying just to go with the 89 ft-lbs.
The Following User Says Thank You to Phaedrus29 For This Useful Post:
Old 10-03-2012, 08:32 PM   #14
No Limit Motorsport
Ok on those you are good. I know the Rays, Project Kics, Muteki etc have different specs, so just double check depending on the brand.
The Following User Says Thank You to No Limit Motorsport For This Useful Post:
The FRS torque curve smbrm Scion FR-S / Toyota 86 GT86 General Forum 29 06-30-2016 05:10 PM
Need Lug Nuts? Wheels? Hit us up! -FullyBolted.com Josh@FullyBolted.com Wheels and Tires 1 06-25-2012 03:04 PM
What's the reason for Torque dip in BRZ Dyno ? yuli8466 Engine, Exhaust, Transmission 82 06-23-2012 08:06 PM
Calling all wheel nuts. Staticfrost AUSTRALIA 90 06-13-2012 10:33 AM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 01:22 AM
