Old 03-18-2016, 04:24 PM   #197
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I think 32gb. Video playback should work out of the box
B-R-Z is offline   Reply With Quote
Old 03-18-2016, 04:30 PM   #198
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Anybody figure out what that extra harness is for?
Rican_D is offline   Reply With Quote
Old 03-18-2016, 08:26 PM   #199
joop1987
Drives: 2013 FRS, Raven, Auto
Steering wheel controls. Used on other toyotas.
joop1987 is offline   Reply With Quote
Old 03-18-2016, 09:53 PM   #200
Rican_D
Rican_D's Avatar
Anyone have a picture of what needs to be shaved down to keep the unit from sticking out to much? I've only seen picture of the dimples shaved off. Should be installing tomorrow if damn antenna wire and USB adapter come in. I did do a test connection after repining to test out the HU and I'm amazed how quick it boots up.
Old 03-18-2016, 10:03 PM   #201
Baymax86
Baymax86's Avatar
Drives: Whiteout Monogram
What's the size limit on SD cards? Is there anything I have to do to get video playback to work?
I have a 128gb and a 64gb in mine. Reads both fine. If video playback is restricted there in android settings-driving settings there a spot for video while driving. At least it was that easy for me
Sent from my Nexus 5X using Tapatalk
Shameless Instagram plug : @BaymaxGT86
Baymax86 is offline   Reply With Quote
The Following User Says Thank You to Baymax86 For This Useful Post:
Rican_D (03-18-2016)
Old 03-18-2016, 10:33 PM   #202
Rican_D
Rican_D's Avatar
Cool, I thought I had read that it supported up to 128 GB. I figured there must be a setting in there for the video. I only briefly plugged it in since I'm still waiting for the other plugs. Didn't really go thru all the settings.
Old 03-18-2016, 11:59 PM   #203
joop1987
I drilled out the mounting holes on the metal brackets on mine because the radio bezel didn't sit flush on the right side. This let it sit back like 1/8" and everything clipped in.
Old 03-19-2016, 05:21 PM   #204
Rican_D
Rican_D's Avatar
I'm having weird issue driver side door speaker doesn't seem to be putting out audio.
**Well upon plugging in the factory HU seems that problem is still there. Could this be issue with the factory amp? Need opinions.**
Old 03-19-2016, 06:50 PM   #205
joop1987
Did you move the wire from pin 8 to 9?
Old 03-19-2016, 06:57 PM   #206
Rican_D
Rican_D's Avatar
Yeah that's done, passenger side door speaker is working. Like I said problem is there with factory HU.
*unless the dealer unplugged that speaker when they fixed the small window on the door*
Old 03-19-2016, 11:52 PM   #207
joop1987
The door skin is pretty easy to remove and check. Remove some screws and yank the it from the bottom carefully.
Old 03-20-2016, 11:45 AM   #208
Rican_D
Rican_D's Avatar
**update** speaker was unplugged. What a difference that was making. Damn dealer techs....
Old 03-22-2016, 11:48 AM   #209
Rican_D
Rican_D's Avatar
Tried installing 64 GB SD card. Didn't work, is the limit 32 GB?
Old 03-22-2016, 12:21 PM   #210
B-R-Z
B-R-Z's Avatar
That's what I thought it was and its what I use. Someone else said they were able to use a larger one, though. :shrug:
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 12:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 11:55 AM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
