#2101 | |
Drives: 4 wheels
Some people actually prefer the OEM diff vs. an aftermarket diff. |
| The Following User Says Thank You to justint5387 For This Useful Post: | tigermack (03-21-2016) |
#2102 | ||
#2103 | |
Drives: 4 wheels
If you source your part smartly, it can be done with 5 to 6k. |
| The Following User Says Thank You to justint5387 For This Useful Post: | strat61caster (03-21-2016) |
#2104 |
Drives: 2013 Raven FR-S
Since we're in the subject, can stock end links be used with the Strano bar on KW coilovers? I had some Whiteline adjustable links last year and they clunked. I'd like to try running the Strano bar with the stock links. I'm lowered about 1 1/4" from stock right now.
#2105 | |
Drives: '13 FRS - STX
Yeah you could spend $7k+ on suspension, $3k on header and custom tune, $3k on high end wheels, $1.5k for a diff and probably another few thousand in odds and ends like bushings and lightweight stuff but that's way overkill, there's serious levels of diminishing returns on that stuff, you can flip through earlier pages, the guys that are running 3+ seconds faster than midpack cars are doing it with heavy batteries and OE seats and bushings, it's all talent. The reality is for the average guy about $2k in coilover/suspension and <$1700 grabs you brand new RPF1's with RE71R's mounted right now and you've got a car that's a blast to drive with a ton of adjustment and setup potential that will run pretty well locally. You can skip the header and tune, bushings, fancy diff and high end coilovers and still slide it around like a maniac. At only $165/tire for 245/40/17 RE71R's right now and the plethora of coilovers available under $2k you can have a lot of fun for not much more money than CS imo. See you in a few weeks at Crow's, where I'll probably still be on the stock powertrain unless I get a Christmas miracle in April.
#2106 |
Drives: FRS hot lava
ok yes going to beat the dead horse again so the spc arms are both versions that have this "illegal" bushing. i have the original cheapo ones with the sliders.is that the same bushing im having a hard time finding info on the old original ones
#2107 |
The Stig's German cousin
It's not like an antenna. At all. The rules say nothing explicit about replacing antennas, only some "comfort and convenience" language that requires some judgement to interpret. Bearings with more metal than OEM are specifically spelled out as illegal. There isn't any room for judgement or interpretation.
You wouldn't try to run a 9.5" wide wheel, would you? That's the more accurate analogy. 9.5" wheels are illegal and there's no room for interpretation on that. Maybe you think a 13th place trophy is worthless, but for those who have been around this sport for a long time it means a lot; and in a class like STX it's actually pretty damn hard to get 13th place. People work their ass off all year to earn that. It's not right for anyone to deny that from them with an illegal car and there are procedures to remedy that. I agree it's unfortunate that legal bushings cost more. I'm not against changing rules either (although there's very good reasons for this rule). But until then, rules are rules and if you plan to trophy at nats, you better follow them. |
| The Following User Says Thank You to renfield90 For This Useful Post: | justint5387 (03-23-2016) |
#2108 | |
In the CS car you are stuck with what is fundamentally not the best suspension, so you make a bunch of compromises to make the car do some things really well and try to drive around the things it doesn't do well. My car could slalom really well, and put down power at corner exit really well, but was pushy everywhere else as a result. It needed patient lines that allowed you to attack the sections where the car was good. A good STX car has no bad manners or foibles to deal with. It's just good at everything. It takes a set much faster, so you never feel like you're waiting for the car to be stable before giving it the next input. It makes the CS car feel like a clumsy, blunt instrument even with all the TRD goodies. |
| The Following 2 Users Say Thank You to renfield90 For This Useful Post: | e1_griego (03-21-2016), justint5387 (03-23-2016) |
#2109 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
So far I have spent about $1400 on mid tier coils, a few whiteline bushings, and light wheels just from coping up deals. I would replace brake pads and my catback anyway so I dont count that towards prep cost really. I will prob run my first full season and regional event in 2017 and go from there. |
#2110 | ||||
http://www.spcalignment.com/index.ph...article&id=291 Also worth noting, LCA's can't have multiple holes for adjusting damper/sway bar mounting location: Quote:
![]() Seriously take your OE or legal LCA, bolt it up to just the chassis at full torque and move it around, that bushing does not restrict any movement that would make the SPC joint beneficial. Going to metal to prevent deflection is such a minor change compared to how much rubber is in the rest of the subframe, like was said earlier Lewis Hamilton probably couldn't tell the difference. That bushing isn't going to take a trophy away from anybody. As a side note while reading up, noticed the Whiteline roll center correction kit is illegal, probably repeated info but it was on the 'I need to investigate' list until now. Quote:
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | GeorgeJFrick (03-21-2016), Silverspeed (03-21-2016) |
#2111 |
Drives: 2014 FR-S
#2112 |
Drives: '22 BRZ
"take a trophy away from someone"
#2113 |
STX prep dollar cost
I agree with everything but the cost estimate for wheels and tires.
New RPF-1's are $1,116.00 delivered. Trust me I know, DP [QUOTE=Kostamojen;2590021]ST-X: Headers + OFT = $1000 (Car section + catback another $1000) Mid-range coilovers and camber bolts = $1500 Front swaybar and endlinks = $300 Brake pads and fluid = $200 RE71R's plus light 17x9's = $1500 Thats $4500-5500 right there... Not including weight saving measures or beefier brakes or bushings |
#2114 |
Drives: Many
I've spent a lot more, but the car works so well that I'm not regretting it at all (alright, maybe a slight bit).
Two weekends in a row of wet events, hopefully dry this weekend so I can atually push and see what fixes (if any) I want to make. |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
