Old 03-19-2016, 12:39 AM   #1009
Rezi
Drives: GT86
Originally Posted by Wayno View Post
You have to wait for LTFT above 5k to go +ve, which will make it richer and alleviate the timing pulled.
Ah okay. This means more "learning time"?
But overall i think it is looking good.
Rezi is offline   Reply With Quote
Old 03-20-2016, 11:27 PM   #1010
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
I finally decided to start logging to "fine tune" my tune... and this happened.
Is this a bad connection to the OFT or what?
I'm using the OBDII Y splitter cable from amazon recommended by many people here, and the other end is connected to a P3Cars vent gauge.
http://www.datazap.me/u/tatovalverde...&mark=117&hg=5
Help please
tato.valverde is offline   Reply With Quote
Old 03-21-2016, 12:09 AM   #1011
steve99
Drives: FT86
Help please
logging is very intensive on ecu so the oft will need exclusive access to ecu the ecu prioritises and if it runns out of time it drops logging so it can run engine
also the to devices may use same addressin on can buss and interfere with each other
tato.valverde (03-21-2016)
Old 03-21-2016, 02:31 PM   #1012
nunonuna
nunonuna's Avatar
Help please
I would suspect as steve99 said. Y splitter is not ideal to use with OFT at least in my case. I had similar issue when I tried y splitter with oft and obdii bluetooth for torque app. It sure seems like interferes each other when both are hooked up together.
nunonuna is offline   Reply With Quote
The Following User Says Thank You to nunonuna For This Useful Post:
Old 03-21-2016, 03:36 PM   #1013
tato.valverde
I'll try again next weekend, hopefully i can get some clean pulls. Thanks!!
And on another note, I'm bringing my car to the shop tomorrow, and last time it was there, they took it out for a test drive, going pretty hard... Since I don't want anyone going on joyrides with my car, i thought i would make a map with the rev limiter at 3000rpm (3000rpm limiter, 2950 resume).
Is this dangerous? Any downsides? Or is there anything else I should change?
Thanks!
Old 03-21-2016, 04:37 PM   #1014
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thanks!
You could always just limit the throttle
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-22-2016, 01:48 AM   #1015
tato.valverde
I disconnected the Y cable, and the log looks good now =)
Can you take a look at it? It's a 3rd gear pull in a slight uphill.
http://www.datazap.me/u/tatovalverde...-5-6-7-9-11-12
Also, about the map for the shop.. If anyone is trying to do it, remember to disable LC, because i didnt and it kicked in at 1000rpm lesson learned
Old 03-22-2016, 08:51 AM   #1016
steve99
Drives: FT86
all look pretty good no knock, iam 1, ltft low numbers.
It running a bit on the rich side past 5000 rpm, maybe adjist the ol maf scaling to correct, will pick up a bit of power
tato.valverde (03-22-2016)
Old 03-23-2016, 05:25 PM   #1017
Jonathanlim
Drives: 15' Frs
Data Logs! Post them here.
Hey guys i did 3 data logs. I got JDL UEL headers installed about a week ago and deiced to do a data log. Did you think it is safe running this? I think its running rich but want your opinion. http://datazap.me/u/jlim7/2nd-and-3r...log=0&data=1-8
Thanks
Jonathanlim is offline   Reply With Quote
Old 03-24-2016, 12:24 PM   #1018
tato.valverde
So I've been reading your threads and Wayno's threads on MAF scaling... is that java program from RomRaider's forums the best option to go with? Or is it better to tweak the tables manually?
Old 03-24-2016, 02:20 PM   #1019
jpsimon
Drives: 2015 STi
Hey guys, my hosting provider is having DNS issues. They've identified the problem apparently so hopefully Datazap will be back up shortly! Sorry for the inconvenience
https://status.digitalocean.com/
2016 340i xDrive / 6MT / M Sport
www.datazap.me - free shareable interactive datalog viewer
jpsimon is offline   Reply With Quote
Old 03-24-2016, 02:23 PM   #1020
jpsimon
Drives: 2015 STi
looks like datazap is back online, hopefully it stays up!
(that's what she said)
The Following User Says Thank You to jpsimon For This Useful Post:
DocWalt (03-25-2016)
Old 03-24-2016, 09:01 PM   #1021
makinen
makinen's Avatar
Drives: Toyota 86
Hi,
I've done dyno runs while finding cam timings.
Considering how to enhance 6600~ rpm.
Any suggestion?
Thanks.
http://datazap.me/u/makinenkr/201512...&data=1-6-7-13
Mods:
HKS catted EL header
OP
stock from FP
K&N panel filter
makinen is offline   Reply With Quote
Old 03-24-2016, 09:40 PM   #1022
Kodename47
Kodename47's Avatar
Drives: UK GT86
What cam timings did you get in the end?
Could probably make a bit more by targeting a bit richer to allow a little more timing advance. Dyno chart looks quite good though. Why the request at 6600? Due to the way the power drops off? If so, not much you can do.
.: Stealth 86 :.
Kodename 47 DJ:
makinen (03-24-2016)
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
