Old 03-20-2016, 12:32 PM   #1037
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by Luftwaffel View Post
I think that's a private log, I can't seem to view. Yeah I suspect this sensor is shot. I wish I could plug it into the factory MAP harness to test but it's a completely different connector.
Woops, my bad, switched to public for ya.
The Following User Says Thank You to BigFatFlip For This Useful Post:
Luftwaffel (03-20-2016)
Old 03-20-2016, 01:53 PM   #1038
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Originally Posted by 86fun View Post
Resistance should be 0.1 between the yellow to green, and blue to orange combo's. I measured mine with a cold engine and off (obviously), and it was per spec. Easy to measure, the pins are readily accessible when unplugged, lots of room for any measuring device imaginable.
I think I might have a frayed multimeter lead, but I can't get any sort of reading from any of the pins to each other. With some finagling it usually works fine but I'm getting nothing unless I test the meter probes to each other.
There is also a voltage curve
I think that chart is wrong. It shouldn't max out at 4.85V @ 102kPa, it should max out at something like 250 kPa.
Thanks, definitely looks like a bad sensor to me. My MAF looks good at least.
Luftwaffel is offline   Reply With Quote
Old 03-20-2016, 01:56 PM   #1039
dj2020
Yep. I also just ended up with a P0451 code. Maybe some of the wiring is defective.
For what it's worth, I also threw a p0451 code on my JRSC set up when my MAP sensor reading did not correspond with my barometric sensor. At my altitude, my baro reading is 0.94 bar but my Omni 2.5 bar sensor was reading 0.85 bar with engine off. In my case, I believe it was a tune issue. My tuner had to change the offset of my new 2.5 MAP sensor. I don't know if he had to change any scaling though. That got rid of my p0451 code!
Your baro and MAP readings are way different so I don't know if this applies.
dj2020 is offline   Reply With Quote
The Following 2 Users Say Thank You to dj2020 For This Useful Post:
CSG Mike (03-20-2016), Luftwaffel (03-20-2016)
Old 03-20-2016, 03:37 PM   #1040
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Just took a peek online to try and find the sensor, and it's impossible to find from a legit looking source. Hopefully Edelbrock has extra stock. Why would they go with a difficult to source euro part? I am confused.
Tried to steal the sensor from my Golf R. Sensor fitting is perfect, connector is wrong.
Old 03-20-2016, 04:58 PM   #1041
CSG Mike
CSG Mike's Avatar
Any component in the Edelbrock kit is VERY easy to source. Let us know what you need and we will make it happen.
Old 03-21-2016, 12:32 AM   #1042
Luftwaffel
Boost Creep
Luftwaffel's Avatar
I figured it out. The MAP offset isn't correct.
This is taken with the stock sensor in open atmosphere.
The Following 2 Users Say Thank You to Luftwaffel For This Useful Post:
clayrush (03-21-2016), menikmati (03-21-2016)
Old 03-21-2016, 01:37 AM   #1043
BigFatFlip
BigFatFlip's Avatar
Ah, so it was a tune problem?
Old 03-21-2016, 01:43 AM   #1044
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Yeah, just to verify this is a 2.5 bar, right?
Old 03-21-2016, 01:49 AM   #1045
86fun
Drives: 2013 FRS
Everything I found online for the part number said 1.2 bar.
86fun is offline   Reply With Quote
Old 03-21-2016, 04:04 AM   #1046
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Back in one piece. Kinda.
Just checked again. This guy says it's a 2.5 bar.
Old 03-21-2016, 11:26 AM   #1047
86fun
Drives: 2013 FRS
Yep, looks like you're right.
Old 03-21-2016, 01:42 PM   #1048
toast
Drives: 14 BSP Edelbrock BRZ
So the Edelbrock tune has a bad value in it? Why do all the other cars with their tune work? Shouldn't everyone see the same issue as you?
toast is offline   Reply With Quote
Old 03-21-2016, 02:09 PM   #1049
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
I believe his tune is from Moto East.
menikmati is offline   Reply With Quote
The Following User Says Thank You to menikmati For This Useful Post:
toast (03-21-2016)
Old 03-21-2016, 02:16 PM   #1050
BigFatFlip
BigFatFlip's Avatar
If I remember correctly, he's not on the CARB tune.
The Following 3 Users Say Thank You to BigFatFlip For This Useful Post:
CSG Mike (03-21-2016), Luftwaffel (03-22-2016), toast (03-21-2016)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
