Old 03-15-2016, 02:42 PM   #2059
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by renfield90 View Post
Offset is unrestricted. However you are not allowed to roll the fenders or have holes in your wheel well liner due to tire rub.
I'm not sure that's correct.
Originally Posted by 14.2 (Bodywork) E.
Fenders may not be cut or flared but the inside lip may be rolled to gain additional tire clearance. (The outer fender contour may not be changed.) Plastic and rubber wheel well splash shields may be modified for tire clearance and to accommodate a rolled inside fender lip. The modifications may serve no other purpose (e.g., air intake, brake ducts, etc). No other changes to the standard fenders or wheel wells are permitted.
The Following 2 Users Say Thank You to cjd For This Useful Post:
Silver Ignition (03-17-2016), strat61caster (03-15-2016)
Old 03-15-2016, 05:18 PM   #2060
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Everyone I've talked to who has committed to a real number is running more than three degrees, myself included. If the tire temps work for you then keep on trucking.
How far beyond -3 are you guys going? That seems like a hell of a lot of negative camber for Autocross. Right now I'm at -3 front and -2 rear.
smg1138 is offline   Reply With Quote
Old 03-15-2016, 05:45 PM   #2061
renfield90
The Stig's German cousin
Yeah you're right, it sounded fishy when I wrote that last bit. Now I remember.
A long time ago it used to be illegal. But then, how much liner has to be rubbed away before it's illegal? How do you tell if a fender has only been slightly rolled? All in all it was very difficult to police and the offset/tire size rules were creating that situation.
In stock class it is most definitely illegal. Any amount of material missing = unauthorized mod and protest.
Old 03-15-2016, 06:22 PM   #2062
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Anywhere from -3.2 to -3.5 is what I've heard from others, probably has a lot to do with style, course surface and layout, and how stiff your front springs/swaybar combo are. Running RCE and the Whiteline bar your front end will have a lot more roll resistance than my current setup, would make sense that you'd need less camber than me.
Only way to find out is to try changing it or take some data.
Thought I'd seen some people running >-4 on track, but found this post:
http://www.ft86club.com/forums/showp...1&postcount=36
ineedyourdiddly
smg1138 (03-15-2016)
Old 03-15-2016, 10:40 PM   #2063
smg1138
smg1138's Avatar
Hmm, it would be nice to be able to adjust camber on the fly. I guess that's an aspect of camber plates I hadn't considered. Running -3 on the street definitely isn't ideal. What camber plates are popular with the STX crowd? I've only really looked at the Vorshlag plates.
Old 03-16-2016, 12:37 AM   #2064
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I daily right at -3 front and it's fine for tire ware.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
Silverspeed (03-17-2016)
Old 03-16-2016, 12:56 AM   #2065
strat61caster
Whatever fits the coilover and the budget.
I've got Raceseng.
ineedyourdiddly
Old 03-16-2016, 10:42 AM   #2066
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
We determined the SPCs are not legal unless you swap bushings. Counter Space Garage's website says their SPC LCAs are STX legal. I don't know how to mention people? @CSG Mike ?
GeorgeJFrick is offline   Reply With Quote
Old 03-16-2016, 04:59 PM   #2067
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
The unit they have listed on their website is STX legal.
http://counterspacegarage.com/spc-rl...-frs-gt86.html
2superblus is offline   Reply With Quote
Old 03-17-2016, 04:34 PM   #2068
Silverspeed
Drives: 2014 FR-S
Running -3 on the street definitely isn't ideal. .
Camber doesn't kill tires.... toe does. Although toe + camber is worse. I run 3+ as well with no ill effects. Unless it rains. Hard.
Silverspeed is offline   Reply With Quote
Old 03-17-2016, 05:12 PM   #2069
nisti
nisti's Avatar
Drives: BRZ & XV
It was recently discovered that the sealed bushing SPC uses in their arms contain more metal than oem.
So, technically, not legal.
nisti is offline   Reply With Quote
Old 03-17-2016, 08:04 PM   #2070
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Ok. No that we are beating this horse to death. Whitelines new rlca is an spc rlca with STX legal bushings. If you need to make the spc ones legal and spc can't help you get there whitelines can.
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 03-18-2016, 05:13 PM   #2071
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
When/where did this discovery come to light?
Old 03-18-2016, 05:41 PM   #2072
Silverspeed
Drives: 2014 FR-S
Probably when DIF started marketing their ST legal ones.... I guess I'd have to cut open my SPC bushings to see if there is any difference. It may in fact be a spherical type joint versus a bushing.
I do believe that 90% of the twins in the STX field are running the arms as is. The DIF replacement bushings are RIDICULOUSLY priced at $90 a pair ($110 retail). They're no larger than my steering rack bushings but 3+ times the price. Dumb to the consumer, smart for them as it appears they are the only game in town for the SPC arms. Maybe a group buy is in order? Maybe SPC should step up and make their own set?
The Following User Says Thank You to Silverspeed For This Useful Post:
GeorgeJFrick (03-19-2016)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
