Old 03-16-2016, 09:12 PM   #15
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Agreed. If you have zero plans for track or autox then upgrading lines and fluid is not worth it.
If you just want a better performance get better pads. And just follow with the schedule maintenance.
Old 03-16-2016, 09:12 PM   #16
Tor
Tor's Avatar
Drives: Toyota GT86
Originally Posted by CSG David View Post
Are CL RC5+ comparable in price to Ferodo DS2500 in Europe? In North America, CL is approximately 2x the price of comparable hybrid pad (DS2500, AX6, R6, HC+800, W3, etc.)
DS2500: 159 Euro (178$)
CL RC5+: 189 Euro (211$)
How are the US prices of curiosity? Are the RC5+ worth an extra 33$ in your opinion?
Also, can I leave the rear brakes stock (apart from the braided lines)? Or will I run into bias problems?
Tor is offline   Reply With Quote
Old 03-16-2016, 09:17 PM   #17
CSG David
CSG David's Avatar
For reference on similarly categorized pads and easier to obtain (prices are in USD): HC+800 = $134, W3 = $150, R6 = $150, AX6 = $158, R8 = $168, XP8 = $177.
We prefer to run a square pad in the rear on OEM brake setups. Sometimes we add a stronger or weaker compound in the rear depending on specific application.
Old 03-16-2016, 09:27 PM   #18
Tor
Tor's Avatar
Drives: Toyota GT86
Thanks, sounds like the general difference in consumer prices (expensive Europe). I think I will go with the RC5+.
Ok, I was a bit in doubt about that. Since CL doesn't make rear pads, I will probably change them for DS2500. They should be about the same µ or slightly less than the CL.
Old 03-16-2016, 10:25 PM   #19
Iceman
Iceman's Avatar
Drives: GT86
Originally Posted by cjd View Post
Essex offers the CL pads... I'd guess they fit. It's possible the 5+ isn't available but the pad spec they use is very common so you should be able to verify.
Yes, but the last time i checked it wasn't clear that the RC5+ was made for the AP/Essex. RC6 and above are available.
While we can definitely make stock pads work for the track, they are definitely a setback when you're trying to do more than one lap at a time. We don't recommend that setup for various reasons, however, one thing we do like to point out is, we do enjoying hitting the same braking points consistently from lap to lap...so take that suggestion into consideration on how we setup cars.
RC5+ is a good hybrid pad, but they're so expensive in North America, it's almost better to just go for more boutique track pad. BBK pad selection do need to be setup accordingly. Some of our more skilled clientele do have to have the right pad setup to maximize their braking potential and consistency. We have had several Essex kits shipped overseas so if you have any questions, please let us know on how we can help. Also, I do believe we have several sets of RC6 on the shelf for the Sprint and Endurance kits. :thumbups:
I think we sold 3x RC5+ pads for the Essex kit and all have moved up to a full track pad. These include 999 (our favorite), DS1.11, XP12, RC8, etc.
Of course, what i meant is that the OP doesn't seem to need more than that.
The only reason for me to move into a BBK are long term costs and being able to make longer runs on track but i like the convenience of CL pads(no bedding in, designed to work well from low temps), specially the RC5+ which is pretty good all around and my 86 is both a DD and a tracktoy. RC6's are terrible for your wheels/bodypaint, and the noise is not for everyone.
That's why i was asking.
I'll be in touch with you guys when the time to replace my rotors comes, perfect excuse for one of those Sprint kits...
I've seen RC5+ for around 150€ in a French online shop.
I haven't found any issues regarding brake bias, btw.
Youtube channel: https://www.youtube.com/c/ÓscarFaraday
IG: @oscarfaraday
Iceman is offline   Reply With Quote
The Following User Says Thank You to Iceman For This Useful Post:
Tor (03-17-2016)
Old 03-17-2016, 03:00 AM   #20
Tor
Tor's Avatar
Drives: Toyota GT86
Thanks. So you are running stock pads in the rear?
Do you remember which shop?
Old 03-17-2016, 12:11 PM   #21
CSG Mike
CSG Mike's Avatar
Brake bias will only rear its head:
- over time as wear, when one axle is overworked compared to the other over a long period of time
- when the pedal dance is used to deactivate EBD.
Iceman (03-18-2016)
Old 03-17-2016, 01:32 PM   #22
CSG David
CSG David's Avatar
To be fair, CL pads are good pads, however, they are some of the noisiest pads we have toyed with...alongside Pagid and Ferodo. For our usage and for our clientele, RC5+ only works for the beginners and many, who thought these hybrid pads were sufficient, found that a tweak in their driving line increased their pace significantly, but also found their pads suddenly become a limiting factor for their pace. As always, use the right pad for the right application and having too much pad is better than not having enough.
As with any imported pads, the cost is higher and the inventory levels are more spotty.
The pads we generally recommend are relatively environmental friendly, good on paint finishes, have excellent brake modulation, nice breakaway qualities, excellent heat capacity, and excellent engineering support.
If you have questions moving forward to your brake pad setup, please let us know as we definitely spend a significant amount of time doing race consultation work and data collection/analysis.
Like @CSG Mike stated, while you don't notice brake bias issues now, it will be more apparent as you develop pace and practice different driving lines. You'll start to realize the limitations of certain pad setups. Any discussions going further than this is why people enjoy working with us.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
Iceman (03-18-2016), Tor (03-17-2016)
Old 03-17-2016, 04:59 PM   #23
Tor
Tor's Avatar
Drives: Toyota GT86
Thanks for the input. I should mention that I will be a trackday beginner. So maybe the RC5+ in the front would be a good starting point for me? Later on I might opt for the Tarox BBK (reasonably priced over here and with road legal approval/TÜV), so I don't want to invest too much in the stock setup. Pads, braided steel lines, fluid change and cooling was my idea.
P.s.
I don't mind some noise.
Old 03-17-2016, 05:29 PM   #24
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
shove a pair of bbk wilwoods in front? just saying... I'll show myself out now
fumanchu1 is offline   Reply With Quote
Old 03-17-2016, 06:48 PM   #25
CSG David
CSG David's Avatar
P.s.
Try full track pads first before moving to BBK. GT86 OEM brake system is larger than the S2000 and many have had success running factory brake system with full track pads. The GT86 is also lighter as well so before upgrading brake systems, start with pads. Remember, not all BBKs are developed with the same level of scope.
The Following 3 Users Say Thank You to CSG David For This Useful Post:
strat61caster (03-17-2016), Teseo (03-17-2016), Tor (03-17-2016)
Old 03-18-2016, 12:02 PM   #26
Iceman
Iceman's Avatar
Drives: GT86
There you go:
http://auriolracing.fr/toyota/5139-gt86-avant.html
IG: @oscarfaraday
Old 03-18-2016, 01:03 PM   #27
Tor
Tor's Avatar
Drives: Toyota GT86
Thanks. I found them already with google and sent them an email. They don't have them in stock and it's 3 weeks delivery. Shipping to Germany is 25 euro, I imagine the same to Spain. Probably better to source them locally even at a higher price, unless you need other stuff you can order there at the same time and don't mind the wait.
Old 03-18-2016, 02:05 PM   #28
CSG David
CSG David's Avatar
May as well try some grade-A American brake pads. :P
How to screw up your cars handling and ride - step by step! Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 401 02-12-2023 11:36 AM
BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) runny_yolk Electronics | Audio | NAV | Infotainment 120 01-29-2021 06:18 PM
[StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:38 AM
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:27 AM
