Old 03-17-2016, 02:54 PM   #1
sydious
Matthew FR-S
Swap AT Diff with MT Diff
From what I am reading, the final drive is in the differential. If I swapped a differential from a manual transmission into my auto, would that just give me the same final drive as the manuals? There are a bunch of wrecked twins out there now so this is a viable option. thanks
sydious is offline   Reply With Quote
Old 03-17-2016, 02:54 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
The gearing is different in the actually tranny. Both MT and AT come with 4.10 rear end
Old 03-17-2016, 02:59 PM   #3
sydious
Matthew FR-S
ahhh, i thought it couldnt be that easy. thanks
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Redline diff oil with LSD ducky106 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 11-11-2015 06:20 AM
RR Diff swap Triumphrider Engine, Exhaust, Transmission 25 10-21-2014 08:34 PM
Diff swap help wootwoot Engine, Exhaust, Transmission 30 06-10-2013 11:05 AM
