Old 03-15-2016, 12:44 AM   #43
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Originally Posted by V_86 View Post
There's no 93 really in any of CA, I've never seen it in Socal. It sucks because I would like the mpg gain and fewer lost ponies to 91.
Quote from other forum:
Monterey
Mazda Raceway - Laguna Seca
Hwy 68, Monterey http://www.laguna-seca.com/
Drive in and look for Fuel Sponsor Signs
Fuel supplied by Bryant Fuel, credit card only.
100 octane unleaded at the pump 2/10/11
Fuel pumps are open to the public in the paddock area during normal business hours.
Laguna Seca is a Monterey County Park. Admission/Day Pass is $6.00 when there is not an event in progress.
I use raceway when it's open to public.... well when it was...
Old 03-15-2016, 03:30 AM   #44
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Premium vs regular fuels
D
Originally Posted by PureShield View Post
My local clubs tuner at Drift Office has tuned and modified over 180 FR-S/BRZ's and has done extensive testing using Canadian 91/94 vs American 92 vs E85 and has shown that are gas is far inferior especially when dealing with a force-fed motor.
How about don't believe everything your tuner say unless you understand it too?
Canada and us fuel rating is the same....
Not to mention fuel varies a bit from stations to station too. If he is just saying fuel @ this station is better then this other station that's ok. But the entire country? What you smoking?
Old 03-15-2016, 02:44 PM   #45
PureShield
PureShield's Avatar
Originally Posted by mav1178 View Post
That's not my point... ECU tune doesn't tell me what octane the gas has, or whether the station had just a bad batch of gas or whether it was systematic in the entire area.
To use ECU tune as a gauge of how good or bad gas is in an area is akin to me gauging the weather of Alaska by seeing what flies over from Siberia...
-alex
No but if both the tunes are the optimal tune for the current setup and the only difference is the fuel that could say something.
PureShield is offline   Reply With Quote
Old 03-15-2016, 02:49 PM   #46
Ya but the same fuel from the same station can change from one day to the next much less comparing from stations in different places. It is possible that they can create more power due to some of the additives that are still used in the US but banned in Canada but even those are at such small levels that I doubt it.
Octane does not produce HP anyway so saying it is higher HP because of octane level is misleading.
Old 03-15-2016, 02:52 PM   #47
PureShield
PureShield's Avatar
Originally Posted by chaoskaze View Post
D
I have lots of reasons to believe him and I also question what anyone says as well. Canada and US fuel may be the same but his testing (Drift Office, the guys who work with EcuTek personally to solve and improve software problems) has found it to be different. Moral of the story is Chevron 92 american is better for FI/Tuning/Dynoing than Chevron 94 Canadian.
The Following User Says Thank You to PureShield For This Useful Post:
DriftinFRS (05-04-2016)
Old 03-15-2016, 04:19 PM   #48
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
So what does that say?
That the tune is optimal, or the fuel is?
I really think you are missing what I am saying: ECU tunes are not a reliable method of gauging gasoline (octane) quality.
Just because a tune works well in one area and not for another does not mean one area has inferior gas. Hell, most people equate cheap/inferior gas w/ Costco, and they have some of the most consistent gas you can buy on the market.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
LOLS2K (03-15-2016), Tcoat (03-16-2016)
Old 03-15-2016, 11:22 PM   #49
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
How is this even a question? read the manual. It will tell you what you should and must use.
The octane levels are for reducing knock ONLY! Higher octane fuel does not give you more power really. What it does is allows the engines with learning ECUs to adjust the timing higher. This is where the "more power" is created.
As a society that identifies higher numbers as being stronger or better I think many people totally misunderstand octane rating. High octane fuel is intended to reduce preignition in high compression engines it is not stronger or better than low octane fuel in any other way. To grossly over simplify what is happening the higher the octane fuel the harder it is to ignite not the other way around. Sure you can run high octane in a regular engine but it is not doing a single thing for you. You should not run lower octane in a high compression engine though since you run the risk of damage. New engines with self adjusting timing this risk is not huge but run too low in an older engine and you better be good at fixing it.
billwot is offline   Reply With Quote
Old 03-15-2016, 11:38 PM   #50
MrDinkleman
Drives: 2016 Oceanic, "base" model
Yes, there is... sort of.
http://www.davebarton.com/Unleaded_Racing_Fuel_in_SoCal
There are 76 stations that sell "racing fuel" (100 octane?). There is one in Pasadena at Glenarm and Arroyo Parkway. But, as someone mentioned above, it's about $9/gal.
OTOH, you don't have to fill your tank with 100 Octane. Just a few gallons per tank should get you to 93 Octane.
MrDinkleman is offline   Reply With Quote
Old 03-16-2016, 03:16 AM   #51
Hotrodheart
Hotrodheart's Avatar
@Tcoat does sugar free maple syrup have less octane than the regular kind?
Hotrodheart is offline   Reply With Quote
Old 03-16-2016, 06:54 AM   #52
It is the E85 of the maple world. It will give you a boost but you need to use way more of it.
Ultramaroon (05-11-2016)
Old 03-16-2016, 07:50 PM   #53
CatScan
Someone in Canada must be using ethanol fuel made from maple syrup.
CatScan is offline   Reply With Quote
Old 03-16-2016, 09:05 PM   #54
steve99
Drives: FT86
AFAIK Octane rating are measured in a weird anchient carburetted test engine in a lab under lab controlled conditions, it gives an octane number that you can relate to other fuels tested in same test engine , but fuels may perform differently under differnt conditions in real world engines and engines using dofferent compression ratios and fuel injection methods.
kind of like the fuel economy figures produced for cars what they achieve under controlled conditions is usefull to compare two different car , but real world economy may differ considerably
see here http://www.fuelexpert.co.za/octanetesting.php
new2subaru (03-17-2016)
Old 03-17-2016, 03:24 AM   #55
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by emishor86 View Post
Hey all,
Wondering if the ZN6 or ZC6 engine performs better with a more expensive fuel like "BP Ultimate" or "Shell V-Power". From research I've done, only sport cars seem to gain a few HP however normal family vehicles gain no benefits.
So is it worth it in a FRS or BRZ?
Originally Posted by VTEC View Post
It all depends on the OEM tune. The FR-S and BRZ were tuned by factory to use 93 octane under North American rating. I think for you in Australia your system rates that as 98 or 100?
Anytime you use something below factory settings, the computer will detect that because the fuel will start to detonate when it's not supposed to. The computer will detect the explosions and compensate by lowering the compression and horsepower to prevent more premature detonations. So it's not so much that you gain power by using the factory recommended fuel, you lose power by using the cheaper fuel.
If you put something with higher octane and more expensive than the recommended fuel, the computer has no way of knowing that. You will still get the same 200 horsepower on 100 octane that you get with 93 octane. You would just be wasting your money on more expensive fuel with no added performance.
The reason why family cars get no benefit from premium fuel is because they are usually tuned to 87 octane. And if you decide to put 91 octane in your Corolla, there is no way for the Corolla's ECU to detect that. And you would be wasting your money again.
You gotta check the factory specs for each car though. Some sports cars like ours and I think the STI are tuned for 93 octane. Most are probably tuned for 91. An accord coupe V6 6MT is only tuned for 87 octane.
Manual says: Recommended 93 Required minimum 91. All is good in the world.
Originally Posted by Packofcrows View Post
93 you'll notice bit more response and better mpg. Thats it. 91 it feels the same as 93 but with about 3-5mpg less. IMO
I only use Shell 91 or Chevron 91. No 93 in central CA
Tcoat has the best interpretation of this and the manual itself:
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Muaddib (03-27-2016)
Old 03-17-2016, 02:04 PM   #56
TRD4life
Drives: 10 Series FRS #1525
I use the highest octane ethanol free gas available in my area, which is 91. I've used Shell, which has 93 at some places near me, but I get the crickets. Maybe its in my head? The price difference isn't significant, so I don't mind.
TRD4life is offline   Reply With Quote
The Following User Says Thank You to TRD4life For This Useful Post:
Tcoat (03-17-2016)
Gas Premium or regular? Dragon86 Scion FR-S / Toyota 86 GT86 General Forum 315 06-20-2017 11:14 PM
Subaru Premium BRZ 86 & Premium Proud of Boxer Catalog & Broshure keioffice Miscellaneous 0 03-14-2014 09:10 AM
Shell URT Advanced / / Sonoco 260GTX // Race Fuels BC-Boy Engine, Exhaust, Transmission 2 03-11-2014 11:12 AM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
use regular gas? Sirnice Scion FR-S / Toyota 86 GT86 General Forum 85 09-29-2012 09:25 AM
