Old 03-16-2016, 09:04 PM   #729
Iwannajag
Drives: 13 FR-S whiteout / blue w2w
2013 FRS 26k miles Manual
Bilstein B8 shocks ( only height adjustable)
Eibach Sportline Springs
SPC Rear Control Arms
Raceseng camber plate (front)
Hawk DTC-60 Break Pads
APR Brake cooling kit
APR extend lugs
Wedsport Leonis Navia 02 17x7 wheels
Hoosier R7 tires 225/45/17
ACE header type B-150
ACE Front pipe
Greddy SP elite axle back muffler
Jackson Racing Oil Cooler
AC delete bracket & condenser removal
K&N drop in filter
Heater core removal
Radio removed
Cruise control removal
Radium Dual Catch Can (Crank & PCV)
Grimm Speed Strut tower brace
Accusump ( off during the dyno test)
AIM Solo DL laptimer and data logger (not installed during the dyno test)
Coolshirt driver cooling system ( Off during Dyno Test)
Recaro Pro Racer HANS Racing Seat
Beastronix TC and ABS controller (Unplugged during Dyno test)
2 nozzle 5 lbs fire system
Schrott 6 point harness
Bell Works short hub + Quick release steering wheel
CAE Ultra Shifter
Complete interior removal
Stainless steel brake lines
AMB Transponder ( Off during Dyno Test)
Iwannajag is offline   Reply With Quote
Old 03-16-2016, 11:08 PM   #730
R2
Originally Posted by Iwannajag View Post
Dynocom
OEM header cat removed Berk front pipe (2015 T4)
Stock Tune 165.6hp
Spec86 Tune 171.0hp
Delicous Stage1 Tune 172.2hp
Ace Header + Ace front pipe (T4 + Spec86)
Spec86 Tune 177.9hp
Delicous Ace Stg2 tune 178.3hp
If I understand this right, you were running the stock header but with the cat removed?
R2 is offline   Reply With Quote
Old 03-17-2016, 12:55 AM   #731
twag4
Drives: frs
Originally Posted by churchx View Post
twag4: But IIRC Delicious had developed specific OTS tune for Ace and as they are mentioned as tuning shop, they should have known if right or not one was used?
That is basically what I was wondering with my comment. We already have the answer now.
twag4 is offline   Reply With Quote
Old 03-17-2016, 03:55 AM   #732
churchx
churchx's Avatar
Drives: 2014 GT86
I'm sure at the end it will be something trivial. But debugging to find cause will drive several people nuts in process
Old 03-17-2016, 06:07 AM   #733
Iwannajag
That is the configuration that SCCA Touring 4 allows and now in 2016 they allow a header so the dynos were done to compare the configurations under the same circumstances and demonstrate the improvement.
Old 03-17-2016, 06:42 AM   #734
churchx
churchx's Avatar
Drives: 2014 GT86
Hmmm, hmm, so +6whp improvement is not over catted stock header, but over decatted one? I'd still expect more from Ace, but maybe this is it? As in - also catless frontpipe, catback, aftermarket filter .. and those big gains for Ace were reported over everything rest being stock, except header & tune. One thing is gains for single component improvement on otherwise restrictive stock intake/exhaust tract, another - when almost everything is replaced and one hits diminishing returns on upgrading last bit. Or stock baseline you were comparing to was really 'stock' one .. stock tune, stock catback, stock headers, stock filter, stock both cats?
raven1231 (03-17-2016)
Old 03-17-2016, 07:49 AM   #735
Iwannajag
Many have seen way more (190+) so it must be something specific to my situation/configuration
Old 03-17-2016, 08:07 AM   #736
churchx
churchx's Avatar
Drives: 2014 GT86
Those many may have it on higher reading dynos and may compare to completely stock baseline unlike you with almost everything in exhaust/intake path upgraded.
Old 03-17-2016, 12:15 PM   #737
CSG Mike
CSG Mike's Avatar
Do you happen to know what a 100% stock car on that dyno typically reads?
Old 03-17-2016, 01:55 PM   #738
Iwannajag
Unfortunately not.
I do have another "spec86" car as comparison that has a Tomei EL with the exact same spec86 tune on the exact same dyno.
Has an invidia OP and FP, stock muffler and Air intake and it reads the same 169 ( 166 with SAE correction). My is 165 with SAE correction.
Blue is mine with ACE. Red is the other with Tomei. Both with the spec86 tune (which we believe can be way way more aggressive on the timing)
Not sure if it helps, but .....
I have 2 more spec86 cars reference point that rate 175/176 with the spec86 tune, also on a Dynojet, and also with Tomei EL so this dyno might read a little low.
This other spec86 car has his own tune, that "feels" way stronger when driving the car compared to the spec86 tune, but this tune has not been on the dyno. So one of the things we are considering is running his tune on my ACE and do more dyno work. I may just simply try it out of the track as well compare the three tune. Spec86, DT STG2 and this custom tune.
Old 03-17-2016, 02:12 PM   #739
Iwannajag
Here is the spec86 tune vs the DT Stage 2 ACE tune on the ACE header.
Old 03-17-2016, 02:20 PM   #740
CSG Mike
CSG Mike's Avatar
There shouldn't be a torque dip at all, but if the torque/horsepower profiles are different with the two tunes, then because it is the same header, you should be able to get the best of both tunes....
Old 03-21-2016, 08:32 AM   #741
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Just a simple question for the guys that track the ACE header.
I just got my ACE type B 350.
There's no way I'll trust anyone to do a ceramic coating on it in France.
Would you wrap it or not ?
Buying parts out there to wrap it right is not especially easy too.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 03-21-2016, 09:25 AM   #742
sqd
sqd's Avatar
Drives: '13 SWP GT86
I'll be picking up my Type A with 350 OP next weekend Hoping for some nice gains with E85!
Question to the more knowledgeable people around here - I am planning on running the header and OP in combination with the Invidia N1 catback, and a catted aftermarket FP (maybe the Berk high-flow one) - how incredibly, extremely loud am I looking at? :p
I know it'll be loud, I can live with that, but I wish I could hear that combo beforehand. Luckily I don't need to daily my car though.
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
