Old 03-16-2016, 09:02 PM   #1
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
General Q's about wheels and coils
I'm trying to plan out what I want to do to the wheels and coils of my DGM BRZ and I could really use some advice. Right now I'm on the stock wheels and tires. I daily drive this car and I don't track it, so I'll sacrifice some performance for comfort and looks if it comes down to it.
Here are my must-haves:
- Even wheel gap around the wheels
- Tires that aren't too low-profile for comfort - my last car had 235/65-35-19's and I was always worried about denting the rim or blowing the tire in potholes. For anyone familiar with NorCal I do a lot of driving in Oakland and it's pothole city.
- No rubbing with the steering wheel turned as far as it will go in a parking lot
Questions:
1) Currently I've noticed that I'm able to bottom out the suspension running tires into the wheel wells on a few of the mountain roads I frequent... which throws the TCS light on for a second and makes an unpleasant sound. I'm afraid if I lower the car at all this problem will get worse... is there a way to stop this based on coil configuration?
2) Would 18" wheels with tires thin enough to fit w/o rubbing be too low-profile for my taste? (see potholes above)
I really like the look of the Volk CE28's but even used they're out of my price range and I don't want a cheap imitation... so right now I have my eyes set on the Enkei RPF1's 17x7.5 with some Michelin PSS-225-45-17 tires, and lowering the car 1" or so with coils.
This is about the wheel gap I'm looking for, nothing too extreme:
Any help or advice is greatly appreciated, thanks.
treminaor is offline   Reply With Quote
Old 03-16-2016, 11:35 PM   #2
8R6
8R6's Avatar
Drives: FRS
that setup is pretty much what meets all your requirements and wants. for money savings, i'd just get springs like RCE Yellows or Hotchkis. For a little bit more money though, you could get ST's or the new Tein Flex Z's and have ample dampening for a daily driver, weekend canyon runner, have more clearance on the inside of the wheel well, and adjustability to go lower than 1" if you decide to in the future. and still under $1k easy. install yourself and save even more money.
8R6 is offline   Reply With Quote
Old 03-16-2016, 11:40 PM   #3
treminaor
"DGM BRZ"
treminaor's Avatar
Are there significant performance advantages going with new coilovers vs lowering springs? For example the RCE Yellows vs the Tein Flex Z's. Is it just for the adjustability or is there more I should consider?
Thanks.
Old 03-17-2016, 01:08 AM   #4
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
If you're bottoming out on stock suspension right now switching to springs will make it worse.
tyler_win_photo is offline   Reply With Quote
Old 03-17-2016, 01:17 AM   #5
treminaor
"DGM BRZ"
treminaor's Avatar
What are my options to improve that, if any? Aside from raising the car obviously.
Old 03-17-2016, 01:22 AM   #6
swarb
Stiffer springs or stiffer shocks. Or coilovers that don't have limited travel like stock when lowered.
Old 03-17-2016, 01:24 AM   #7
treminaor
"DGM BRZ"
treminaor's Avatar
Makes sense. Do you have any recommendations on what to use?
Old 03-17-2016, 01:44 AM   #8
swarb
Rce yellows are 5k/5k spring rates.
Flex Z are 6k/6k.
I'd go flex z for the adjustable dampening to suit your comfort needs.
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
What coils/spring rates for midsize E/UHP wheels (weekend/hobby drive)? Tor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 01-04-2016 06:15 PM
General Shifting Q's Lust Scion FR-S / Toyota 86 GT86 General Forum 29 06-26-2015 09:34 PM
FS: General Altimax Snow Tires and WHEELS (MASS) Pooverdam Wheels and Tires 6 05-04-2015 12:05 PM
Asphalt frs on coils looking for wheels ironhorse2118 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 04-30-2015 02:49 AM
