View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 02-20-2016, 08:09 PM   #4803
nottabrzbobby
Drives: 2015 white scion Fr-S
Originally Posted by Hanzo View Post
Please only vote after you have driven your car for over 300 miles.
I've posted this on the BRZ section as well. Please only vote once in either section.
I went down to my Toyota dealer an the guy there (after being a **** Thinkin I was clueless n tried to screw me out of my warranty) tried to buddy up w me an told me to come in an complain about a chirping noise because the fuel injector I think he said is bad an Toyota just changed the part an kept the same part number to avoid a recall an now I have no chirping noise at all im also at 26k miles now an the noise was there from the time I got the car till last week
nottabrzbobby is offline   Reply With Quote
Old 02-20-2016, 09:05 PM   #4804
stevesnj
stevesnj's Avatar
The pump is high pressure driven by a cam lobe and is a mechanical pump, the pump seal is probably of a hard material or teflon which causes the cricket like sound. Unless you replace it with an electrical one. But replacement mechanical pumps will eventually make noise again. Dunno if an electric can be put in place of the mechanical and high pressure electric pumps are typically noisy.
My 2016 Build thread
Old 03-15-2016, 05:24 PM   #4805
Hyperblue302
Hyperblue302's Avatar
Drives: 2016 BRZ, 94 Integra GSR
No chirping for me at 1300 miles on a 16 brz. Switched from shell 93 to e85, now the crickets have arrived.
Hyperblue302 is offline   Reply With Quote
Old 03-16-2016, 10:15 AM   #4806
stevesnj
stevesnj's Avatar
The pump is broken in.
Old 03-16-2016, 11:18 AM   #4807
Nah nothing to do with it. He just went from chirp free gas to chirp gas. I go back and forth all the time.
Old 03-16-2016, 07:25 PM   #4808
MikeyBatz
MikeyBatz's Avatar
Drives: Scion FR-S
Does replacing the fuel pump actually fix this issue?
MikeyBatz is offline   Reply With Quote
Old 03-16-2016, 07:36 PM   #4809
No. They have not had a revision yet that eliminates the sound (it isn't really a "problem") and I doubt they ever will.
This condition doesn't seem to exist anyplace else in the world but no place else uses ethanol in their fuel like we do so I don't think fixing it is a high priority for Toyota.
HunterGreene (03-17-2016), MikeyBatz (03-16-2016)
Old 03-16-2016, 08:35 PM   #4810
stevesnj
stevesnj's Avatar
Is there any additive to lube the seal? I think the pump plunger seal is the culprit. Some brand of gas must have an additive than others that is somewhat quieting the pump internals. I'd like to take a pump apart to find that darn cricket!!
Old 03-16-2016, 08:46 PM   #4811
Chanpion
Drives: 13 FRS Satin
Don't take it apart, you'll risk actually breaking it. Or if you want to whatever too. It's not broken as it is, the chirps are more of a characteristic.
But if you really want to get rid of your crickets, get the recommended 93 octane or higher and make sure you get 0 ethanol or alcohol additives (Alcohol family so tactrol, blah blah) and least amount of additives always helps. They'll be gone after a tank of gas. Once you've cycled through the old stuff. I don't know the market for your area but up where I live, it's a bit tougher to just straight up gasoline because pumps add anti freezing agents because of the climate and halfs the pumps are not labeled if they contain less than I think 30% ethanol.
It's agreed on by now it's the alchohol content that makes it chirp.
Chanpion is offline   Reply With Quote
Old 03-16-2016, 08:50 PM   #4812
stevesnj
stevesnj's Avatar
Originally Posted by Chanpion View Post
Don't take it apart, you'll risk actually breaking it. It's not broken as it is, the chirps are more of a characteristic.
But if you really want to get rid of your crickets. Get the recommended 93 octane or higher and make sure you get 0 ethanol or alcohol additives (Alcohol family so tactrol, blah blah) and least amount of additives always helps. They'll be gone after a tank of gas. Once you've cycled through the old stuff.
I thought this subject would have died by now.
Well it's not the fuel, I use only Shell V-Power or Sunoco Ultra, both are 93 octane, I have been using both since I got the car new. I don't want to take my fuel pump apart just "a" fuel pump.
Old 03-16-2016, 08:52 PM   #4813
Chanpion
Uh, I said alcohol family. Shell VPower's pretty good up in the north, chirp free. Blends are different in other places though.
EDIT: If I'm wrong or whatever, forgive me, studying for my 3rd midterm this week, cooked.
The Following 2 Users Say Thank You to Chanpion For This Useful Post:
stevesnj (03-16-2016), Tcoat (03-17-2016)
Old 03-17-2016, 09:43 AM   #4814
HunterGreene
Hail Magnet
HunterGreene's Avatar
The stickers at my gas stations say that it may contain up to 15% ethanol. Higher than that and they have to report it.
It has priests in it?
Old 03-17-2016, 09:49 AM   #4815
Nah Steve it has been shown time and again that ethanol in the fuel can me a major contributor. The problem is that fuels are not consistent everyplace so some guys say "I use X with no issues" while others say "X causes them all the time". Add to that the fact that even ethanol seems ok a when the ambient air temperatures are low and we get yet another variable when people try to compare fuels. All this adds up to the conclusion that personal " I have" and "I don't have" stories don't mean a thing.
HunterGreene (03-17-2016), [YOYO] (03-21-2016)
Old 03-19-2016, 03:24 PM   #4816
Sonne
Drives: 2015 BRZ Limited
I got rid of it after adding no ethanol fuel here in Florida...issue is that it's only 90 octane. Can I get away with that, maybe add octane booster and leave it at that?
Sonne is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
