Old 02-26-2016, 12:49 PM   #141
zeal86
zeal86's Avatar
Drives:
I will be installing my v3 w/ flash editor soon... What's the biggest thing about this install that I should look out for or be prepared for?
How many of you swapped out your plugs at the same time? Did y'all work from the top or the bottom?
I read I'll need some air tools...I believe they are a die grinder and cutter... anything else?
thanks in advance
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
Old 02-29-2016, 05:34 PM   #142
86Tony
Drives: 2015 AOZORA EDITION
so can this blower make 350whp?
86Tony is offline   Reply With Quote
Old 03-01-2016, 02:21 PM   #143
CxG
Drives: Pearl White '13 ZN6
Yes.
Sent from my D5803 using Tapatalk
CxG is offline   Reply With Quote
Old 03-11-2016, 09:59 AM   #144
Shinra Inc
Shinra Inc's Avatar
Drives: Tiny Bronco
Any updates about the flash editor and 2015+ vehicles?
Shinra Inc is offline   Reply With Quote
Old 03-16-2016, 02:27 PM   #145
jasonojordan
Drives: 2013 satin white brz limited
Has anyone got this kit without the tune and had your own tune done? Im curious as I already have a tune on mine for the delicious ethanol module. Wondering if I could just have a tune done to work with that since its already on the car,
jasonojordan is offline   Reply With Quote
Old 03-16-2016, 03:22 PM   #146
CxG
You can get the base version without tuner and get it tuned elsewhere
The Following User Says Thank You to CxG For This Useful Post:
jasonojordan (03-16-2016)
Old 03-26-2016, 04:41 PM   #147
v12twinturbo
Drives: '15 BRZ - '08 tC - '01 tour bus
Still waiting on 2015+ tuning compatibility, any news?
2015 WRB Limited 6MT - OFT - Tomei UEL - Perrin OP - Invidia catless FP - Perrin 3" exhaust - H&R Coils - 18" Grids - Sway Bars - Endlinks - Valentis - Filter
v12twinturbo is offline   Reply With Quote
Old 03-27-2016, 04:02 AM   #148
asraam
Drives: Subaru BRZ
Hello, I´m sending the greeting from the middle of Europe . Here is my dyno: 270 hp at 6500 rpm. I can´t tell if I have v2 or v3 kit because mine is from japan and they use slightly different naming... I have injectors upgrade kit with bigger restrictor plate, Miltek primary catback resonated exhaust and stock headers.
I have few questions on you guys since you have way more experiences than we have here...
1) I want to buy HKS EL headers - do you think it is ok with this kit? How much hp can I expect (with ECU remap)? Will the car be any louder with this headers?
2) What sparkplugs do you use?
3) Is that restrictor plate any good or can it be safely removed?
4) I´m having difficulties starting the car when it is really hot (I mean when I drive it hard) - any tips on that?
5) I dont like stock throttle map with is too agresive when you push the pedal only slightly - have somebody tried to change the map with ECUtek?
Thank you and happy Easter!
asraam is offline   Reply With Quote
Old 03-28-2016, 08:24 AM   #149
James@HKSUSA
James@HKSUSA's Avatar
Currently on our shop FRS we have seen 319 on E85. This is with the stock motor. If you were to do a capacity upgrade kit, you should be able to see around the 350 mark.
James@HKSUSA is offline   Reply With Quote
Old 03-28-2016, 08:25 AM   #150
James@HKSUSA
Unfortunately we do not have any updates at this time. I may have more information later this week after our meeting today, but I cannot promise anything.
Old 03-28-2016, 08:26 AM   #151
James@HKSUSA
You certainly can use a different tuning software than what is provided on the flash editor!
Old 03-28-2016, 08:26 AM   #152
James@HKSUSA
Old 03-29-2016, 11:16 PM   #153
sebastiansim
Drives: 2015 Crystal Black Silica Brz MT
Please let us know asap! I'm sure they're are a lot of 2015+ owners that are dying to get their hands on this kit that just want a install, flash and go system (myself included haha)
sebastiansim is offline   Reply With Quote
Old 03-30-2016, 12:07 AM   #154
mpross
mpross's Avatar
Drives: 2015 Scion FRS
+1 I'm curious about expected power gains with the header and v2/3 after a tune
Sent from my SAMSUNG-SM-G928A using Tapatalk
mpross is offline   Reply With Quote
supercharger help... sosick Forced Induction 25 08-15-2013 11:02 PM
HKS GT Supercharger Evasive Motorsports Forced Induction 48 02-08-2013 06:21 PM
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 10:09 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 10:10 PM
HKS GT Supercharger Kit BPAuto Forced Induction 18 10-27-2012 03:11 PM
