Old 03-15-2016, 08:36 PM   #2745
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
This is commonly called "spring" where I come from. It will be followed by a fairly constant state called "summer" and then we will have the chaos known as "fall" to deal with.
I'm surprised by how widespread this actually is. I figured it only happened here.
Nevermore is offline
Old 03-15-2016, 08:38 PM   #2746
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
WTF?!?!?!?!?! I decided to check in for the first time in a long while because for some crazy reason I felt a supernatural force compelling me to return... And imagine my fucking surprise when it turns out you can summon me like some kind of ghost of forum-past.
I'll miss you.
jawn is offline
Old 03-15-2016, 08:40 PM   #2747
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Also, I haven't checked my thanks in a month or so and it's only at 164 (as of this post). I've been checking mentions and quotes.
Old 03-15-2016, 08:41 PM   #2748
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Dude, I got 142 thanks while I went away for a week.
No I want to thank more posts, I know I am not funny enough to get thanked as much as you.
go_a_way1 is offline
Old 03-15-2016, 08:44 PM   #2749
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Gotta admit, this doesnt taste that bad.
The Twins make me smile
soulreapersteve is offline
Old 03-15-2016, 09:12 PM   #2750
jawn
jawn's Avatar
My OCD won't let me not check.
jawn is offline
Old 03-15-2016, 09:14 PM   #2751
p1l0t
p1l0t's Avatar
Hahahhahahaha!!!!! Once a member of off topic, you are a member until death do us part
You can check out but you can't never leave...
p1l0t is offline
Old 03-15-2016, 09:14 PM   #2752
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
Can confirm - I've tried to leave
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline
Old 03-15-2016, 09:24 PM   #2753
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Haha I've had that problem in the past. But every once in a while I defeat it. I offered it the quotes and mentions to keep it happy, so at least I know when and where to communicate. Whether or not someone is happy about my communication is more or less irrelevant (unless they hate me, in which case I just cry.)
Old 03-15-2016, 09:29 PM   #2754
That really is weird. You're like Neo. It's great to have you back.
I mean you are back, right?
Spooky isn't it!
It was Ultra's cries of anguish that called me back.
I still haven't quite recovered, you know. Don't you ever pull that shit again.
Ultramaroon is offline
Old 03-15-2016, 09:48 PM   #2755
soulreapersteve
@jawn
I was looking through your build thread and didnt want to spam there so I'll ask here.
Regarding the SPC camber bolts, that was only for front, yes? The rear didn't need adjusting at all? Trying to read up on all of this since I'm leaning toward the RCE yellows for that mild drop you have but got confused and quit.
http://www.ft86speedfactory.com/spc-...l#.Vui68kautyk
Also read a while back that with such a mild drop, no adjustable LCA is needed so stock is fine.
Old 03-15-2016, 09:52 PM   #2756
jawn
jawn's Avatar
@jawn
Correct. The shop was able to do a tiny amount of adjustments on my rear camber, but I don't have any camber bushings or lower control arms in the rear. -2 is an acceptable amount of rear camber to me. Some folks prefer -1.5, but I think a lot of that is driving style/tire compound dependent.
jawn is offline
Old 03-15-2016, 09:53 PM   #2757
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
@jawn
You shouldnt need it unless your off really bad from factory or are OCD and need it even. Mine was off almost a full degree when I installed my Yellows so I got adjustable bushings but I really dont recommend them and would say just get LCAs if you need it. Install and get the alignment then see where you are at
finch1750 is offline
Old 03-15-2016, 10:20 PM   #2758
soulreapersteve
Thanks guys!
So just to clarify, get springs installed, get alignment, and if need be, get bolts/lca?
