Old 03-15-2016, 06:54 PM   #267
Celica00
Celica00's Avatar
Drives: 86
Originally Posted by rice_classic View Post
So the moral of the story and 16 pages is:
You can it wrong, or you can do it right and there's more than one way to do either.
edit: who cares.. our Throw out bearings will fail every 50k anyway. Just replace your clutch then.
Is there any feasible or logistical way to make a more durable throw out bearing? Why or why not?
I've learned based on the age/profession thread that a hell of a lot of the members here are engineers, so it's a good resource to learn for someone like myself.
Celica00 is offline   Reply With Quote
Old 03-15-2016, 06:57 PM   #268
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
A: it's only after someone quotes me do I realize I can't type worth sh**.
B: Perhaps. I avoided the factory option and bought a more robust SKF bearing with a self centering function.
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
Celica00 (03-15-2016)
Old 03-15-2016, 07:00 PM   #269
62K Original tranny oil. No throw out bearing issues, no grinds, no 2nd/5th gear lockouts, no problems of any sort.
You are 100% correct though. There are many ways to do things and none are "right" or "wrong" really. This same debate rages across the internet with even the experts taking sides.
Old 03-15-2016, 07:03 PM   #270
OEM parts are a compromise between cost, durability and functionality. It is great for us to sit and say "why can't they make XXXX better?" but they have to meet all the requirements not just one or two. Like Rice says there are "better" aftermarket options available.
Old 03-15-2016, 07:05 PM   #271
I have had that same realization about 22,000 times!
Ultramaroon (03-15-2016)
Old 03-15-2016, 07:08 PM   #272
The Golden Rule of product design: Light, strong, or cheap, pick two.
There is something hinky about this TOB. They may have sacrificed some of the strong for the cheap.
Celica00 (03-15-2016), strat61caster (03-15-2016)
Old 03-15-2016, 07:14 PM   #273
I think the difference isn't in the function, but in the application and in the application of the average driver.
Most folks aren't rev matching or double clutching, therefore on a downshift the clutch is speeding up an engine, whereas on an upshift it's slowing it down. The friction disk is being applied to retard or accelerate what is essentially a compressor. The requirement in force to slow down an off-throttle engine is much less than to accelerate one.
To compound this, on a down shift, the clutch re-engagement is generally slower for your typical driver so the delta between where the revs are when the clutch is disengaged to where the revs are when the clutch is re-engaged is greater, aka: even more work.
TRUTH!
I will amend my comment:
"There is no more strain put on a clutch by downshifting properly for the conditions then there is up shifting properly for the conditions.
And my usual disclaimer of:
"My statements are for regular driving only. Track and 'cuz racecar methods will vary"
Old 03-15-2016, 07:33 PM   #274
Do you have a source on this? I skip gears on the highway all the time when I hammer on it then shift to 6th when I hit 60
At 60 from 5th to 6th there's maybe 500 RPM split? I'm totally spitballing.
But from 3rd at, what, 4500 to 6th at 2500? That's a lot time to squeeze all the lube from between the cones and get 'em cookin' real good.
Originally Posted by Capt Spaulding View Post
Edit: It seems to me that the strain on the synchros is/should be directly proportional to the difference in speeds of the input and output shafts. If you're slowing down and reach a road speed that's compatible with gear ratio/engine speed for the gear you're downshifting into I don't see what excessive stress that puts on the box.
It's not bad at low speeds because the relative speeds all converge to zero RPM.
It's that 6th-to-3rd shift at highway speed that'll cook the 3rd gear synchro in no time. Those I ALWAYS double-clutch.
Old 03-15-2016, 08:35 PM   #275
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Auto owners ideas of a "clutch".
[ame="https://www.youtube.com/watch?v=8OTDK9ZVQaA"]1v6 Clutch 29 Secs AMAZING Killcam! WOW! - YouTube[/ame]
The Twins make me smile
Old 03-15-2016, 09:16 PM   #276
Ashikabi
Ashikabi's Avatar
MLG no scopes
The Following User Says Thank You to Ashikabi For This Useful Post:
soulreapersteve (03-15-2016)
Old 03-15-2016, 11:19 PM   #277
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Yep. Yep. And, I don't really do that. I'm generally a sequential shift guy. Seldom to never skip gears on the way up and, generally run down the gears coming to a stop. Occasionally, coming to a stop at a light or stop sign, I'll let the car coast in gear down to about 1500 then clutch in and slip into what ever gear would give me 2500 if I needed it. Once stopped, it's into first again. With the way I drive, going from 6th to 3rd at speed, isn't something I've considered doing. I can easily see double clutching that one. On the same page now.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Old 03-15-2016, 11:36 PM   #278
Try it sometime. It's one of my favorite completely unnecessary things to do. #becauseracecar
Oh, and given a choice between buying your car, or mine at 100 Kmi, I'd buy yours in a heartbeat.
Old 03-16-2016, 06:06 AM   #279
ALL THIS^
This is exactly what I do and just could not put into words.
kr-s is colorblind
Show us your Custom Roll Cage or Roll Bar and Harness Setup Black Tire Tracking / Autocross / HPDE / Drifting 27 02-13-2015 09:59 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 08:33 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 06:54 PM
Car rattle at neutral. IloveBaldEagles Issues | Warranty | Recalls / TSB 3 12-23-2012 06:55 PM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 05:44 PM
