Old 03-15-2016, 04:44 PM   #981
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by Luftwaffel View Post
Ohi. Any lessons learned from install? Extra things not listed, what not to do, etc. Other than destroying my manifold gasket.
Planning on doing teardown on Wednesday night while I wait for the box to arrive, then buildup all day Thursday!
The first thing you should do is to read the first few pages of the instructions and email edelbrock for the tune.
Make sure you have a strong friend(s) around for the part where you position the supercharger. If you can get some tools specifically for hose clamps it wouldn't hurt. Don't put the factory snorkel back on, don't forget to put the radiator shroud back on. Some of the steps don't have pictures, read the instructions very carefully so you don't miss anything.
djdnz is offline   Reply With Quote
The Following 2 Users Say Thank You to djdnz For This Useful Post:
BigFatFlip (03-15-2016), Luftwaffel (03-15-2016)
Old 03-15-2016, 04:58 PM   #982
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Not sure if its been fixed on the newer kits, but I found the screws for the MAF sensor to be too long (or hole for the MAF housing too shallow, so have some washers handy (not sure what size) to be able to screw down the MAF correctly.
The Following User Says Thank You to BigFatFlip For This Useful Post:
Old 03-15-2016, 05:12 PM   #983
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I asked my shop and they said they had no issue with them.
clayrush is offline   Reply With Quote
The Following User Says Thank You to clayrush For This Useful Post:
Old 03-15-2016, 05:29 PM   #984
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Originally Posted by Sargy View Post
2 zip ties cut down to the hard bits have worked wonders. no damage done to the clips
-Using the 2 zip ties, find the two tabs (180degrees apart) on the inside of yellow/green quick connector, and push the flat part of the zip ties in to raise the tabs.
-Pull the hose + quick connector out (yellow/green slides out with it)
I want to say we used the zip tie trick when we worked on my STi actually. Either way this is a non issue I think.
Seems like it's all pretty basic stuff. I decided against the Edelbrock tune due to seeing the issues a couple of guys were having, and wanted something more tailored anyway. Should be a few of us doing the install so no issues lifting the top end. I actually even checked with Subaru to see if there were manifold gaskets local in case I accidentally shave one down.
Luftwaffel is offline   Reply With Quote
Old 03-17-2016, 06:46 AM   #985
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Well, productive day. We pulled the manifold, taped everything off, and called it a night. Not bad for three hours of work in low light.
Still don't know what the hell I'm going to do about the rivet nuts.
Old 03-17-2016, 10:08 AM   #986
MicheleAbbate
MicheleAbbate's Avatar
Drives: Grr Racing FRS & BRZ
Send a message via AIM to MicheleAbbate
I got extra gaskets too. Smart. They are easy to pinch
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
MicheleAbbate is offline   Reply With Quote
The Following User Says Thank You to MicheleAbbate For This Useful Post:
Luftwaffel (03-17-2016)
Old 03-17-2016, 11:05 AM   #987
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
You can make your own rivet nut tool using a bolt, nut, and washer/spacer. I was looking at rivet nut tools but it didn't seem cost-effective to purchase a specialty tool for a single use.
[ame="https://www.youtube.com/watch?v=SzWj5y00sVg"]DIY Rivnut tool - YouTube[/ame]
menikmati is offline   Reply With Quote
The Following 2 Users Say Thank You to menikmati For This Useful Post:
BigFatFlip (03-17-2016), Luftwaffel (03-17-2016)
Old 03-17-2016, 11:40 AM   #988
jwvand02
Drives: 2013 SWP BRZ Limited
Has anyone started pushing these with E85 and smaller pulleys? I'm curious to know how much power you can safely make with one before you need to build the engine.
jwvand02 is offline   Reply With Quote
Old 03-17-2016, 11:44 AM   #989
Luftwaffel
Boost Creep
Luftwaffel's Avatar
I didn't actually buy them, I just checked on stock to make sure they were in the warehouse on island. When you live in Hawaii, every complication goes just that little bit more south on you.
Yeah I was thinking the same. For some reason I can't load Youtube this morning, but is that the video where he drills out a pipe? I was like wtf is he doing? He could just use washers.
Old 03-17-2016, 11:45 AM   #990
Uplink
Uplink's Avatar
Drives: anything you let me
I don't think it's a kit related restriction but the common consensus seems to be ~300whp you should be looking at internals, regardless of how you're making that power (turbo/SC/juice/etc.).
Uplink is offline   Reply With Quote
Old 03-17-2016, 12:05 PM   #991
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
I thought it was 400whp? I thought 300 is where the clutch slips and fuel system starts to fall short, 400 the internals and tranny.
That number could be lower when you're making more torque at lower RPM's though.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 03-17-2016, 12:16 PM   #992
Dezoris
Dezoris's Avatar
Originally Posted by Lunatic View Post
Yes I did too. But the car is still giving fault codes and running rough below 1500 rpm. I sent new data logs to Zach at Delicious and he aid there are still vacuum leaks.
It is never the tuning, of course.
Old 03-17-2016, 12:18 PM   #993
MicheleAbbate
Check all your injector plugs. Make sure all of the prongs are straight and not bent.
Old 03-17-2016, 12:30 PM   #994
itsibarra
itsibarra's Avatar
Drives: Supercharged Car
That's an easy one we might have overlooked...
Also, if injectors aren't lined up with metal tabs it could contribute to a rough idle due to the specific spray pattern of the injectors.
itsibarra is offline   Reply With Quote
The Following 6 Users Say Thank You to itsibarra For This Useful Post:
ATL BRZ (03-31-2016), BigFatFlip (03-17-2016), CSG Mike (03-17-2016), Luftwaffel (03-17-2016), taiguy (05-17-2016), Uplink (03-17-2016)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
