Old 03-13-2016, 08:38 PM   #2045
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Originally Posted by xwd View Post
Has anyone tried running a 18x9 with the 265/35/18? There are almost no wheels out there but I did see Enkei is going to start selling the GTC01RR in the US, it has an 18x9 +40 version. Unfortunately it's also $550/wheel.
Rota makes plenty of reps in 18x9
BUT I doubt it's faster than 17x9 with 245.
Old 03-14-2016, 01:51 PM   #2046
renfield90
The Stig's German cousin
Originally Posted by 48Spoons View Post
Should fall under the comfort and convenience section. As long as you're replacing it and not just taking out the weight it should be fine.
Single DIN will be lighter. But protesting over an honest stereo upgrade is crazy talk.
Old 03-14-2016, 06:43 PM   #2047
xwd
I looked at Wheeldude after shortly making the post. The only 18x9 Rotas readily available in our fitment are the G-Force at about 23.5lbs per wheel.
I also don't think it would buy you much if anything, but it would be an interesting experiment. The RX8s always ran that size and it looks like the 128i guys are going to be running that size as well.
Old 03-14-2016, 07:12 PM   #2048
48Spoons
Drives: Ultramarine FR-S
Yeah, was more so going as long as you replace it instead of leaving a hole because the radio wave and transmitting the signal from the aliens through your fillings.
Was contemplating stuffing a 7 inch tablet in place of the stock radio for a bit the then ended up being lazy.
48Spoons is offline   Reply With Quote
Old 03-15-2016, 10:50 AM   #2049
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
What would you guys consider to be the essential mods for competing at Nationals? I'm planning to go with a couple of friends this year and would like to make sure my car is as competitive as possible. By September my tires will probably need replacing, so I'll probably be going with RE-71R's when the time comes.
Here are the mods I've made for STX so far: RCE Tarmac 2's, Enkei RPF1 17x9 +35, Hankook RS3 V2 245/40/17, JDL UEL header, Perrin 2.5 catback, OFT 93 tune, K&N filter, Whiteline 20mm front bar, Whiteline Lower Control Arms
smg1138 is offline   Reply With Quote
Old 03-15-2016, 11:43 AM   #2050
justint5387
Drives: 4 wheels
I think there were only 1 or 2 RX8s that ran 18x9. Jeff Hurst was on 17x9 with 235 Toyos when he ran. Kyle had 17x9s as well on his 128. I would rather optimize the unsprung weight unless you are really loading the tires in the corner to need the wider tires.
justint5387 is offline   Reply With Quote
Old 03-15-2016, 12:12 PM   #2051
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Essential Mod: Seat Time
Your car sounds pretty well prepped for STX
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 03-15-2016, 12:16 PM   #2052
ハチロク
ハチロク's Avatar
Drives: 2014 Ultramarine FR-S
What's the rule for wheel offset in stx class? Is there a limit like there is for stock?
ハチロク is offline   Reply With Quote
Old 03-15-2016, 01:13 PM   #2053
smg1138
smg1138's Avatar
That's what I was hoping to hear. I'm wanting to concentrate on driving this year. Hopefully the only thing I'll need are new tires.
Old 03-15-2016, 01:45 PM   #2054
renfield90
This is a solid start. Strongly recommend you ditch the RS3s, they were last year's tire...last year.
The next step from here would be a dedicated 2.5" ID coilover setup. After that it's lots of niggly little things that all add up, and a proper race diff ($$$).
Old 03-15-2016, 01:46 PM   #2055
renfield90
Offset is unrestricted. However you are not allowed to roll the fenders or have holes in your wheel well liner due to tire rub.
Old 03-15-2016, 01:58 PM   #2056
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Work on a good setup, you didn't mention camber plates or LCA so I'm going to assume you have neither and need more camber. Develop your alignment, tire pressures, sway bar settings, ride heights, damper settings, those can transform a car from dead last to ttod. I've driven cars with identical parts that feel like different animals because there are dozens of adjustments you can make.
ineedyourdiddly
Old 03-15-2016, 02:17 PM   #2057
smg1138
smg1138's Avatar
Crap, I forgot about my LCA's! I have the newer Whiteline LCA's installed in the back. I'm currently using the stock tophats and don't have camber plates. I was going to get some, but I'm able to get -3 camber up front with just the slotted holes on the RCE coilovers. The only benefit I can see from camber plates would be additional caster.
Old 03-15-2016, 02:40 PM   #2058
strat61caster
Everyone I've talked to who has committed to a real number is running more than three degrees, myself included. If the tire temps work for you then keep on trucking.
ineedyourdiddly
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
