Old 03-03-2016, 12:37 PM   #141
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by kevin.nguyen View Post
Is there a way to buy the tiy kit if you already have the ecutek package and try to get the carb legal tune free? Or do you have to purchase the tune?
Also be sure that you get the CARB exemption documentation/sticker with the kit, it will be necessary to pass smog.
ineedyourdiddly
Old 03-03-2016, 12:48 PM   #142
Rapiddan45
Rapiddan45's Avatar
Drives: 2013 FR-S M/T Ultramarine
Alright here is the first dyno. 240whp/181wtq. Mods done to my car are in my signature.
I'm still waiting on a finalized tune from Delicious, as you can see the AFR gets very rich up top still. Also I'm at 4,300ft elevation so I peak at about 7.2psi opposed to the 9.5 that it would be at sea level. Very happy with the kit though and the overall drive ability.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2.
OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1
C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can
Rapiddan45 is offline   Reply With Quote
The Following 6 Users Say Thank You to Rapiddan45 For This Useful Post:
Aaronimoe (03-03-2016), CSG David (03-03-2016), CSG Mike (03-03-2016), CxG (01-12-2017), Jmonty (03-14-2016), MisterSheep (03-03-2016)
Old 03-03-2016, 02:30 PM   #143
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Definitely an option available but it must be requested upon order. We'll definitely need the EcuTek Dongle ID like what Jackson Racing said.
Originally Posted by Jackson Racing View Post
We offer the Factory Tuned system minus Ecutek if you already have one. You have to call in to order, and must have your Ecutek Dongle ID ready.
-Jackson Racing Staff
CounterSpace Garage is offline   Reply With Quote
Old 03-03-2016, 05:32 PM   #144
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
so what exactly is a carb legal tune? Is that just another saying of an off the shelf tune?
bkblitzed is offline   Reply With Quote
Old 03-03-2016, 05:52 PM   #145
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
CARB legal means that the California Air Resources Board has deemed the product with this calibration, Legal for street/highway use. If you are in a state that requires emissions, and you have any other tune flashed on the ECU, it is no longer CARB Legal is not supposed to be on the street/highway.
JDMChris is offline   Reply With Quote
Old 03-03-2016, 08:01 PM   #146
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Damn that's pretty high elevation, I didn't think it made THAT much of a difference. Still pretty damn good numbers for being that high.
Alltezza is offline   Reply With Quote
The Following User Says Thank You to Alltezza For This Useful Post:
Rapiddan45 (03-03-2016)
Old 03-03-2016, 11:15 PM   #147
kevin.nguyen
Drives: Ultramarine FRS
Is anything offered when buying from you. How much would it cost to install and timeframe if done at your garage?
kevin.nguyen is offline   Reply With Quote
Old 03-06-2016, 12:34 AM   #148
bkblitzed
is better than you
bkblitzed's Avatar
ah ic
Old 03-13-2016, 12:13 AM   #149
Raven240
Drives: 2015 Release Series 1.0 FRS
What's a good clutch upgrade for the supercharger kit?
075/1500 2015 Scion FRS Release Series 1.0 / Jackson Racing Supercharger + Oil Cooler / Tom's Red DOT LED lights / 18s staggered Enkei Raijin with RS3 / TRD Short Shifter / 328 Stoptech BBK Front / Velox Motorsports Diffuser / Whiteline bushings / Ohlins RT Coilovers / VIS Carbon Fiber Hood.
Raven240 is offline   Reply With Quote
Old 03-13-2016, 12:23 AM   #150
CSG Mike
CSG Mike's Avatar
You don't need one unless you're running full host of supporting mods.
We use the ACT setup.
CxG (04-08-2016)
Old 03-13-2016, 07:51 PM   #151
dp1
driving smoother faster
Drives: Sold
I remember reading that above ~210 lbft torque the stock clutch can start to slip. Can somebody confirm the number?
dp1 is offline   Reply With Quote
Old 03-14-2016, 12:25 AM   #152
CSG Mike
CSG Mike's Avatar
It varies with the condition of the clutch; some do, some don't.
Remember, most bolt-on FI solutions are already over 210.
dp1 (03-14-2016)
Old 03-14-2016, 12:42 AM   #153
stevo585
Drives: White 2014 BRZ
I'm right around that with the ESC on e85. No slip unless high gear pull from the midrange. A redline shift from 4th to 5th no slip.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
The Following 2 Users Say Thank You to stevo585 For This Useful Post:
CSG Mike (03-14-2016), dp1 (03-14-2016)
Old 04-08-2016, 12:56 AM   #154
CxG
Drives: Pearl White '13 ZN6
if someone had plans to build their FA20 to rev out to 9k, would the C38 still be within operating RPM on either pulley?
CxG is offline   Reply With Quote
FS Bay Area: 2013 Subaru BRZ-L SWP 6MT - Jackson Racing Supercharger - 50 state legal spitz Cars for Sale/Trade 3 02-04-2016 11:59 PM
Jackson Racing CARB supercharger+oil cooler LA blahblah Engine, Exhaust, Bolt-Ons 9 12-30-2015 12:33 AM
(SOLD) 2014 Scion FRS (w/Jackson Racing SC - CARB Legal) - $25,000 - Irvine, CA *LongFella Cars for Sale/Trade 27 04-11-2015 12:35 PM
Best CARB legal SC kit? Jackson? Oem reliable block rebuild? Cayman killer? Yui-Chan Forced Induction 179 03-04-2015 07:50 PM
