Old 03-11-2016, 12:12 PM   #3571
redlined600
redlined600's Avatar
Drives: Fr-s
On the cheap side I ran a Etx-9 all last year without issue. I was a bit skeptical that it would work, but since I had it laying around from my miata I figured I may as well give it a shot. Occasionally it wouldn't start the car if I left it off the tender for more than a week, so it would stay on the tender most of the time. I don't DD my car though.
redlined600 is offline   Reply With Quote
Old 03-11-2016, 10:13 PM   #3572
Uplink
Uplink's Avatar
Drives: anything you let me
I need a new battery. Should I just get a replacement or go for a lightweight one.
I usually just weekend drive my car so it sits 4-5 days at s time and parked maybe 4 months over winter.
I don't mind to buy a tender and remove the battery over winter. But i dont want to have to every week.
I'm in NY like you and have been on the Shorai with KC Machine bracket since April 2015. Car was outside all winter and ironically not driven on weekends, only during the week and never used a tender. Worst thing that ever happened was it took 3-4 cranks for the car to start after an excessively cold night/weekend of not being used but always fired up. CSG Mike suggested turning on the radio and some things to put draw on the battery first to warm it up.
Never gave me a single problem and would do it again in a heartbeat. Saved 23lbs up high in the engine bay too.
Uplink is offline   Reply With Quote
Old 03-11-2016, 10:27 PM   #3573
Uplink
Uplink's Avatar
Originally Posted by ja1217 View Post
I'm taking the plunge and going full race car with my FR-S, but I've run into a small issue. I got a new Sparco Circuit II seat and with the supplied Sparco floor mounts the seat is too high up and I am going to have clearance issues, especially with a helmet and a roll cage.
I've seen some people go with Buddy Club seat rails to lower the seat, but I'm not sure they are up to the task of doing wheel to wheel racing safety wise. I know some people have them re-welded to make them stronger, which is an option I'm considering, but I'm wondering if there is a better option out there for something to lower the seat while being strong enough to rely on in wheel to wheel racing.
Thanks!
I had a similar issue with my C4 Vette. Absolutely NO seat rails would let me drive the car in a helmet without pressing against the roof in my Sparco Pro 2000's. Not sure what the floor of the twins looks like but my solution was 1/8" channel steel. It's as flat as you can get with rigidity along the edges. Notch as needed, drill where appropriate and coat with Westley's undercoating for a factory finish look. Yes, you lose the ability to move the seat, but if 99% of the driving is done by you it doesn't matter.
Old 03-12-2016, 02:28 AM   #3574
CSG Mike
CSG Mike's Avatar
Thanks!
Nagisa or Bride? (CSG carries both, as well as others).
Do your seats use standard L brackets for mounting?
If you go Buddy Club, re-weld their spot welds to ensure they don't break in a collision, or even long term use.
CSG Mike is online now   Reply With Quote
Old 03-12-2016, 02:30 AM   #3575
CSG Mike
CSG Mike's Avatar
Originally Posted by LOLS2K View Post
Please post your results in your build thread. A buddy and I have been going back and forth about lightweight batteries lately. Buddy wants to get something different than Odyssey this time around and they only other experience I have is with AntiGravity.
Try the KC Machine Shorai. Far, far more cranking power than Braille.
If you're set on a AGM battery instead of a LiFePO4, then get the Deka. Deka is the OE for Braille, similar to how Precision Instrument is the OE for SnapOn torque wrenches.
PM to order the Shorai.
Old 03-12-2016, 02:44 AM   #3576
juliog
juliog's Avatar
Drives: 86
Another happy KC Machine + Shorai kit user here
juliog is offline   Reply With Quote
Old 03-12-2016, 09:46 AM   #3577
ja1217
Drives: 2004 Toyota RAV-4 5M
Yes, I believe that these are standard L brackets:
Could you send me links to the Bride and Nagisa rails? I couldn't seem to find them on your website. Would the circuit 2 fit in the nagisa rails? It is a wider seat and what I could find of the nagisa rails said that they don't fit wide seats.
Also, would you feel comfortable doing wheel to wheel racing with the Nagisa or Bride rails? I definitely want to keep the car safe and although I would prefer to have the adjustability of sliders I am ok going with custom mounts for my seat position, like @Uplink suggested, if none of the sliders are good enough.
ja1217 is offline   Reply With Quote
Old 03-12-2016, 10:55 AM   #3578
CSG Mike
CSG Mike's Avatar
Do you have a width measurement?
Old 03-12-2016, 12:19 PM   #3579
ja1217
Above is the size chart from Sparco. I measured the one I have and it came in right around 17 inches wide.
Old 03-12-2016, 09:35 PM   #3580
Estey
Drives: Scion FR-S, Ultramarine
Mike,
Im planning my first track day at Streets of Willow, and I had a question about ride height. Im running buddy club racing spec coilovers right now, and my fender is 25.25 inches from the ground. My question is, how much should I raise my car to fully utilize the dampers? I believe Im 1.5-2 inches lower than stock.
also, I recently started to get a clunk in the front of my car, and I believe its due to bad strut bearings :/ Will this negatively affect the handling on the track?
Estey is offline   Reply With Quote
Old 03-12-2016, 10:06 PM   #3581
CSG Mike
CSG Mike's Avatar
Originally Posted by Estey View Post
Mike,
I have no idea; I've never set up a car with the Buddy Club Racing Spec coilovers on this platform. If you can get me damper length, damper stroke length (with bumpstop), spring free length, spring compressed length, and spring rates, I can figure that out for you.
Strut bearings? Like the top hat?
Old 03-12-2016, 10:07 PM   #3582
CSG Mike
CSG Mike's Avatar
Remind me to check on Monday...
Old 03-13-2016, 05:02 AM   #3583
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Did someone had the opportunity to test the TRD front and side splitters track efficiency ? The prices for TRD are much less stupid out there than other options.
I would much rather have a lightweight plastic aero kit than a bullshit heavy carbon fiber one.
Edit with pictures :
Would this be a good track solution ? (With proper static oversteer/understeer setup to balance the wing)
Or is it just a marketing car ?
That would help me a lot clearing speed bumps if it works.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 03-13-2016, 04:32 PM   #3584
Estey
Sweet, I'll see if I can get those.
And yeah, in the top hat. I put my car up on stands and turned the wheel to replicate the clunking sound and I tracked it down to the top hats. I figured you would be the best person to ask. I plan on replacing them, but probably not before I hit the track.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
