Old 03-10-2016, 09:45 AM   #6917
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
Originally Posted by Iamwu View Post
Running a 69mm pulley
My idler pulley is 70mm. For what its worth, the K061010HD (shorter) belt also would not for me whatsoever.. I had to stick with the K061015 belt..
Thought you might be using the larger pulley, and that was why you have contact with the hood. I'm running a 70mm, and haven't had any problems with the hood.
CarzCarzCarz is offline   Reply With Quote
Old 03-10-2016, 09:48 AM   #6918
tegunulgener
tegunulgener's Avatar
Drives: Dark Side
Is there any photo of snapped belt? Maybe tensioner is not correct?
Sent from my HTC One M9 using Tapatalk
tegunulgener is offline   Reply With Quote
Old 03-10-2016, 11:06 AM   #6919
stockysnail
Just the tip
stockysnail's Avatar
I've been running the K061010 non-HD on my 70mm. I though upgrading to the HD would be good so I ordered one. The HD is unfortunately just a little bit smaller and wouldn't fit. The K061010HD non-HD does fit for me however. I bought a K061015 blue racing belt and will put that on to see if it fits well and lives up to it's racing name since I race.
Old 03-10-2016, 12:18 PM   #6920
Iamwu
Drives: 86
So when my belt has been shredding, it's always started by 1 of the 'V' grooves just sheering off the belt. It might be the tensioner... How would I go about checking that ?
@ stockysnail, let me know how the blue belt works for ya.
I'll try to snap a photo of my hood, but it doesn't look pretty at all..
Iamwu is offline   Reply With Quote
Old 03-10-2016, 01:35 PM   #6921
tegunulgener
Drives: Dark Side
Shredding... Are you sure your pulleys are not cutting the belt? Maybe treads are not matching? There must be a certain amount of torque on the tensioner. Maybe it's too much on yours. I don't know how to calculate it.
Old 03-10-2016, 01:36 PM   #6922
tegunulgener
Drives: Dark Side
Did you get any damage internally? What was the behaviour of the car when it's snapped?
Old 03-10-2016, 06:00 PM   #6923
Iamwu
Drives: 86
I've inspected the treads and they all line up just fine. I'm guessing now it is in fact the tensioner not pulling enough tension. When the groove shreds, it pretty much just separates from the belt completely and gets tossed around in the engine bay.
Car runs fine, as all the other grooves are still in tact and the remainder of the belt is engaged on the pulleys.
Old 03-12-2016, 02:20 AM   #6924
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
With my 335 install coming soon, I have a few questions.
First I assume my shop should already know this, but I will just mention it to them ahead of time. If I understand correctly, after install, the tune must be flashed to the car prior to the first startup with the supercharger installed.
How soon will I need new brakes running approx. 300hp? Is it unsafe to be running the stock brakes with this much power? I heard the stock clutch is good up to 350hp.
My oil change is scheduled soon. Is it necessary to chang out the oil when installing an oil cooler?
Coilovers have been purchased for upgraded suspenion. I just have to decide on the right set of rims and tires for my setup.
Chad86 is offline   Reply With Quote
Old 03-12-2016, 02:41 AM   #6925
stockysnail
Just the tip
Brakes are fine unless you race. You'll want a new clutch that can handle more torque. Yes you should change the oil when you add an oil cooler and you'll need more oil than normal as you'll be putting in more to compensate for the extra that will go into the cooler, but the directions should tell you that. Yes tune before starting the engine post 335 install.
Old 03-12-2016, 04:44 AM   #6926
Kodename47
Kodename47's Avatar
Drives: UK GT86
You can idle the car on the standard tune if you want to test that it runs etc.
The reason people say you need better brakes for the power is because you'll reach higher speeds consistently. If you're not in that situation (ie track or similar) then it's not necessary.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-12-2016, 08:53 AM   #6927
Dream20b
Y u do dis?
had this problem on the 210- turned out i had the wrong idler pulley
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 03-12-2016, 10:00 AM   #6928
Chad86
Chad86's Avatar
Drives: Toyota GT86
My next oil change is due soon. Would you recommend I just wait until after the oil cooler and supercharger install? Is it still a standard oil change with an oil cooler or will the dealership have issues?
Old 03-12-2016, 02:16 PM   #6929
stockysnail
Just the tip
I would just wait. If it's the Perrin oil cooler or similar size, they will need an extra quart, but they will also need to follow the directions so the oil is pushed through the cooler. I installed mine myself, so if they follow directions they won't have any problems doing it. After it's installed you'll use the normal pre-oil cooler amount because when you drain the oil, the oil in the cooler will stay there as there's no way to drain it from the cooler. There's enough new oil when you do a change however that you need not worry about having old oil left in the system.
Old 03-14-2016, 03:21 PM   #6930
Iamwu
Drives: 86
Hmm I'll go and check its diameter.
@ StockySnails, let me know how that blue belt works out for ya.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
